eigenvector - I was advised by another member that you can theoretically inspect cam chain slack by moving the crank and watching the delay, if any, of the valve movement up and/or down. Maybe bogus, maybe it's a good way to check.
Instead of checking sprocket movement while moving the bike, I checked in the oil fill plug at the clutch pack while moving the crank in gear, no slack either way it seems.
Steer me in any way necessary. Unable to reproduce this at idle as it only happens under load around 2500 rpm and whilst moving.
Redid the valve adjustment, still within specs. Rode it with the timing 3-5 degrees retarded and advanced, no change either way.
I had an oil pressure gauge for the longest time and it always showed good readings. About 40-50psi on cold start up and lowered to about 15psi at idle and proportionally went up with engine speed. I took it off a few month ago.
In my desperation I started to look into pinging due to carbon causing hot spots or higher than usual compression ratio that even 95 octane couldn't overcome. So I saw a good layer of the stuff in the cylinders. Got some pics.
Is this too much carbon?
I poured some atf/seafoam/marvel mystery oil cocktail into the cylinders and let it sit a few days, started her up and revved the piss out of her and rode around. Still rattling. Almost seems more evident now. It might take a few sessions of this to clean it up enough to rule it out. I thought about trying the water spray through the air box, and I've heard about the rice in the cylinders too.
Just an update I guess at my struggle. I still have yet to bite the bullet and open up the oil pan and check it out. My head gasket is seeping very little as are some of the lower covers. If, and when, I fix this, I'm looking into a reseal and cleanup of the engine. Thank you fellas for all the input. I'll continue putting the advise into action and keep trying.
