Author Topic: My version of a 77 CB750F Resto/Mod  (Read 3922 times)
Offline dlhoulton
« on: September 04, 2014, 06:04:51 PM »
I picked up this bike (1977 CB750F) a couple of years ago from a PO that clamed it was 90% complete for $500. He said he also had a 78 CB750F that had been in a fire and he was using for a parts bike. Got it for a $100. What a deal $600 and two CB750F's. They set in my shop for a couple of years before I finally decided to get started. I figured since I didn't know very much about these bikes I would start on the 78 parts bike. It had a good motor and frame but missing tons of parts. I used the 77 (that was supposed to be 90% complete) as a visual guide. That bike was finished and I have a thread on here under the name "Tin Lizzie". She's the bike in my avatar. The 77 set for another year before I finally got off my but and started building it. I wanted to do a complete restoration with some modification. My goal was to try to get it looking like it rolled off the show room floor (to the untrained eye). For the majority of folks here I'm sure you can spot lots of things wrong. Anyway that was my plan. Here are some shots of the beginning of tear down.
Here are some shots of frame ready for powder coating.
Then it was time to get into the motor. The PO said he had it running but did not have a battery at the time, so I bought it without actually hearing it run. I did kick it and it felt like it had good compression. If he had it running it would not have run very long because when I got the motor out and the valve cover off this is what I found.
So I got busy and tore down the entire motor. Top to bottom, inside out. Nothing was left un-touched. Here are some shots of the empty motor case getting cleaned, stripped then bead blasted.
When it came time to paint the motor I decided against painting the usual "F" black motor. I wanted it to be a little different. I decided to go with Dupli Color "Cast Iron" engine paint. I new with the chrome and polished covers, caps and bolt kit it would make it pop. So here are some pictures of the motor going back together with its new color and accents.
The motor got lots of new parts: roller, guides, cam chain, etc. You name it, it got it. Pistons were spec. out and were reused. Someone must have just done some work on it because it had a "second" overbore done. I took the manuals over to a friends shop that specializes in motorcycles and all pistons and cylinders were in spec. So while I was there we honed the cylinders and installed new rings. He also spec. out the valves and while we were there we did a total top end rebuild: valve guides, seals, etc. I took everything home and put the motor back together with fresh new gaskets, seals, pucks, O-rings, etc. Here are some picks of the finished motor.
Several days later I got my frame back from the powder coater and took on the task of installing motor.
After motor was in frame I turned my attention to all the little parts (brackets and stuff). I read here about DIY powder coating and I thought I would give it a shot. It was very simple and not that expensive. Got a Harbor Freight PC gun. Figured out how to make a bench top spray booth and also got a counter top oven. I already had a HF blast cabinet. I use glass beads on just about everything for quick clean and prep of parts. Here is a shot of my simple spray cabinet and HF spray gun.
Here is my simple counter top oven.
After prepping everything I spent the day powder coating everything in site as well as all my bike parts. These are some shots of the parts I powder coated.
Even had room for my battery tray.
The oven was large enough to also do my lower fork legs.
After powder coating I turned my attention to doing some polishing. Tackled my wheels, carburetor parts and a few other things. Some picks of my wheels and carbs.
After polishing it was time for some paint. I had read lots of post on "spray bomb" paint projects and being cheep as I am wanted to try it. Read all the do's and don'ts and what was needed to get the job done. I used Dupli Color primer and paint (black) and a product called "2K clear". I ended up applying two coats of primer, four coats of color (black) and four coats of 2K clear. Doing all the usual wet sanding in between coats. Here are the products I used for the job.
Here are some shots of what got painted (before) and the end results (after).
The tank got two coats of clear then got wet sanded and applied the decals then got two more coats of clear with a wet sanding in between coats.
Also redid the seat pan and it got new cover. Here's a shot of the resto seat pan.
Got new rubber on polished wheels and put them back together.
Next it was time to start putting everything together. Here are some shots of assembly.
The bike's all finished with the exception of the exhaust. Just waiting on funds. Here are some shots of completed product.
Well that's my story. I know it was long but I hope you enjoyed it. Also hope that someone else can learn something from it. Thanks for your patients.
« Last Edit: September 05, 2014, 07:02:07 AM by dlhoulton »
Re: My version of a 77 CB750F Resto/Mod
« Reply #1 on: September 04, 2014, 06:20:02 PM »
WOW, a whole build thread in one post, well done... ;D  Nice bike too mate... ;)
« Reply #2 on: September 04, 2014, 11:09:03 PM »
That's a beautiful restoration!
Offline brandEn
« Reply #3 on: September 05, 2014, 05:23:51 AM »
That is the nicest F3 restore ever. WOW. Great work and awesome post!
Offline dlhoulton
« Reply #4 on: September 05, 2014, 05:44:07 AM »
Thanks for the compliments. I know it was a lot in one post/thread. I wasn't going to do a build thread but in another posters thread I was encouraged to do so. The build took over a year to do. I took lots more pictures than what's shown here. I spent a lot of time in the detail both inside and out. Down to the breather canister and turn signal buzzer. Made sure it even had all warning labels. The bike also got a new wiring harness and I made all new sub harnesses. I cleaned up the handlebars buy running the wiring inside the bars. Installed Dyna S ignition with black 5 Ohm coils. I reproduced Hondaman's fuse block and installed Oregon motorcycle's separate regulator and rectifier.
The bike also got the 530 sprocket and chain conversion. It was a labor of love. Like I mentioned above, my goal was to see if I could make it look like it just rolled off the show room floor. The only hint that it's got some age to it is in the gauges. I decided to clean them up and leave them with the original miles.
« Reply #5 on: September 05, 2014, 08:21:57 AM »
DL,
You are nearing completion with the exhaust. Are you going with a stock style pipe or something different?
Offline dlhoulton
« Reply #6 on: September 05, 2014, 08:41:02 AM »
I have the OEM header but they have a few small scrapes and dents in them. I striped them in prep for re-chroming but the cost was WAY out of my budget (quoted $800 plus buy Browns plating in KY). Also researched having them ceramic coated but buy the time I shipped them, had them coated and purchased a suitable muffler I could get a complete MAC 4 into 1 system. I want to keep the center stand and still be able to change oil without removing exhaust system. So to answer your question I'm going with a Chrome, MAC 4 into 1 kit.
« Reply #7 on: September 05, 2014, 08:44:52 AM »
This is truly an outstanding build. We don't see many SS restorations. Please update your thread as you get the exhaust installed and the bike running.    8)
Don
Offline Steve_K
« Reply #8 on: September 05, 2014, 12:23:33 PM »
What can I say?  What a great looking bike!  The time and work you put into her has paid off.  Very nice motorcycle and kudos to you.
Steve
Steve_K
« Reply #9 on: September 05, 2014, 12:28:49 PM »
Nicely done!
Offline dlhoulton
« Reply #10 on: September 05, 2014, 12:36:35 PM »
What can I say, you guys are to kind. Thanks for the compliments.
You know, this site is where I obtained all knowledge to build my two bikes. I took on these projects without ever before turning a wrench. If you look at my post counter you will see that I don't post very often but if there was a counter for times logged onto this site I would be a senior member with the numbers well into the thousands. This site has such a wealth of knowledge and info for anyone to take on a build.
Offline GNGSXR
« Reply #11 on: September 05, 2014, 12:51:45 PM »
I really like that engine color.
1971 CB750
1980 CB750
1996 Honda CBR 600F3
2006 GSXR 750
1987 Buick Grand National
« Reply #12 on: September 05, 2014, 02:33:24 PM »
I was thinking the same thing. I think it's similar to what I used.
Offline dlhoulton
Re: My version of a 77 CB750F Resto/Mod (Finished)
« Reply #13 on: September 20, 2014, 06:18:52 AM »
Finally finished my resto/mod. Last piece to go on was the MAC 4 into 1 exhaust system. Wanted to go with stock headers but this is a good substitute. Sounds great. Now to put some road time in and read the plugs to see if any jetting is needed. Currently I've got stock jets. Stock air box with a K&N filter.
Offline albertaboy
  • No way I'm a
« Reply #14 on: September 20, 2014, 07:47:57 AM »
Hey,
Beautiful bike. Congrats!  I too really like the engine color. Enjoy it while it's still clean and fresh. :)
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
« Reply #15 on: September 20, 2014, 08:42:14 AM »
Fantastic job!   Nominating you for BOTM....
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #16 on: September 20, 2014, 09:51:05 AM »
My pants man, that is absolutely incredible work. Friggin A. Beauty.
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline BPellerine
« Reply #17 on: September 20, 2014, 05:12:10 PM »
I envy your painting skills nice!bill
1978 CB 750K ard and webers
another anfob
« Reply #18 on: September 20, 2014, 07:13:38 PM »
Dude....you put the star in Comstar 8)   You of course realize....that nothing ever rolled of the Honda assembly line looking anywhere near THAT GOOD!
Offline dlhoulton
« Reply #19 on: September 21, 2014, 04:42:18 AM »
Thanks everyone! It was just like a big puzzle. I just took it all apart and then took each part and concentrated on brining it back like new or better. Once I got started I couldn't stop. Had to try to improve on function or look on everything.
« Reply #20 on: September 23, 2014, 02:46:35 PM »
Is it October yet?  I'll second that!
Offline 77cb750f2
« Reply #21 on: September 25, 2014, 03:57:20 PM »
Great Bike! let us know how your jetting works out.  I'm curious how far away from stock you go (if at all).
Nick
Offline dlhoulton
« Reply #22 on: September 26, 2014, 07:47:06 AM »
77cb7502 and all interested. On this bike I'm running Dyna S ignition and Dyna 5 Ohm coils. MAC 4 into 1 Chrome Megaphone exhaust system (MAC001-1301). The air box and filter are stock. This is a 1977 "F" bike but the carbs are off of a 1978 "F" bike. That's how I got the bike. I'm running stock 78 "F" jetting (Float height:14.5, Main jets: 105, Slow jets: 35, Needle: nonadjustable/non shimmed. I did have to adjust Idle mixture screws to 2 full turns out. I've put around 100 miles (forgot to reset my trip) and I can report that throttle response is outstanding in all positions. No hesitation or flat spots. When throttle is opened it just keeps accelerating. I've been up to 80 plus mph with no problems. I've read the plugs in several RPM/Throttle positions and they are dead on light tan color.  Hope this helps any and everyone.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #23 on: September 26, 2014, 07:56:49 AM »
Awesome build.  Another thumbs up for the engine color.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
« Reply #24 on: October 02, 2014, 04:20:15 PM »
First day and you've been nominated, seconded and thirded for BOTM. Please go to the BOTM nom thread and reply accept!
Don
