Wow.. that's a lot to take in. Are they saying this does not go back together and I need to fabricate a new part or this is only for some bikes? You don't have to answer but I will start reading this in deeper detail as I should be working now!
Thanks all.
Back together as getting new head bearings on the triple tree? Just take your time and you will be fine. Use the old race, piece of pipe and hammer to drive the inner race back on - in this order. The old race is to protect the new ring from getting damaged.
I was bored once and calculated the dimensional change in bearing cooling or heating and ever since I dont bother to cool or heat bearings. The difference in diameter is so small that it makes zero sense. Clean and polish the surface, much better use your time than abusing wife's oven or freezer
I tapped on a bearing for the input shaft of np435 transmission without heating/cooling too and that is a much bigger job than steering head on a motorcycle.
