Author Topic: Different frame and engine VIN's  (Read 3290 times)
Offline loupoin
« on: September 07, 2014, 12:07:26 PM »
While photographing the frame and engine VIN's for a prospective buyer for my 1976 CB400F, I noticed my frame number was 2 digits off from the engine. As a matter of fact, the last digit on the engine look hand etched, not like the factory stamped numbers preceding it. It is not filed or altered in any way. Are they supposed to be the same, other than the additional 'E' in the engine VIN? The frame # is CB400F-2001427, The engine is CB400FE-200149. I bought bike with a clear TN title and was issued a clear SC title. I've scoured here and the internet and found a wealth of info on VIN's, but nothing as basic as are they supposed to match, which I assumed they should. Thanks for any light you can shed on my mystery. Attached is a photo of the engine VIN.
I take my children everywhere, but they always find their way back home. WCF
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
Re: Different frame and engine VIN's
« Reply #1 on: September 07, 2014, 12:27:51 PM »
quite normal for this generation of honda to mismatch.  I'm not aware of any state (but there could be one I suppose) that uses the engine for title work...always a frame number.  Insurance.....always a frame number.  Stolen vehicle registry.....always a frame number.  Good luck with your sale.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline loupoin
« Reply #2 on: September 07, 2014, 01:25:13 PM »
Thanks for the info guys. As I researched VIN's I noticed all the sites listed frame and engine numbers separately, so I began thinking (hoping) they might be different. Plus if there was a conflict I would think TN and SC wouldn't issue a title if there was a problem.
« Reply #3 on: September 07, 2014, 01:34:05 PM »
Not always.  My CB550 was bought out of Wisconsin and they used the engine number on the title. Others from WI have reported the same.
Offline loupoin
« Reply #4 on: September 07, 2014, 02:08:29 PM »
So that must mean the numbers don't match? Which # they use is not my issue.
« Reply #5 on: September 07, 2014, 03:06:50 PM »
The numbers never match.  The frames and motors were manufactured in different factories and mated later.
Offline dusterdude
« Reply #6 on: September 08, 2014, 03:26:01 PM »
But,my panhead is registered by the engine number(because harley didnt use frame numbers back then),which means i can put my engine in any frame i want.there's benefits to both systems
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline lucky
« Reply #7 on: September 08, 2014, 05:01:31 PM »
Many times the state agencies are not informed.
They are car thinkers too.
The numbers of frame and engine do not match on Hondas.
Offline dusterdude
« Reply #8 on: September 09, 2014, 02:30:02 PM »
Cali,depends,any pre 69 ish engine with title can go in it.after 69 ish,harley had to put numbers on the frame and title using the frame number.i could use a later engine and get a special construction title for the whole bike
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
