Hey guys, get this:
I called around, and my local shop was able to squeeze me in today for helicoil install. I take the bike apart and inspect the thread.. That's funny- they look perfect, as does the screw! I know I had the bracket on all the way, and the screw tightened, then loosened, and repeated 3 times- I was sure it was stripped. Looking at the screw showed a bit of aluminum on the threads. I was sure I was in trouble. I took the fork leg to the shop to have them look, just in case I was not seeing some obvious crazyness.
They tested the threads by using a spacer between the bolt head, and the fork leg. Sure enough, the screw held perfect, with plenty of hold, no signs of strippage or damage!
Now I am really feeling stupid (yet happy the fork leg is still "virgin"
What the heck do you think happened? I gotta wait until nighttime to install. The shop said the threads were not tapped all the way to the bottom, and thought maybe I was missing a spacer and the bolt was trying to cut new threads towards the bottom of the hole. Weird- the bolt is the same size as the other side, which had no problems.. I am bolting through the caliper swivel bracket, and the fender/fork brace, plus the stock lockwasher.. Any ideas??? I guess I'll use a couple of washers and space it out a bit more- there is plenty of thread still available for the fork leg..
Sheesh!!
