Author Topic: CB750 K4 Build - The Cafe Tracer  (Read 120241 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: CB750 K4 Build
« Reply #250 on: February 29, 2016, 05:41:12 PM »
My tank and side cover decals arrived today.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #251 on: March 05, 2016, 02:13:58 PM »
Had to make a clutch basket nut removal tool out of 21mm socket.  Worked great.
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #252 on: March 06, 2016, 07:20:16 PM »
I've got the engine pretty much as torn down as I want to take it.  It looks like it's in really good shape.  Doesn't appear to have any extensive work done to it previously.  The no. 2 intake tappet adjustment screw appears to have been replaced at some point.  There was a tiny washer in the no. 2 cylinder, but it looks like it may have been dropped in there recently.  The engine didn't have spark plugs, carbs or an exhaust when I got it.  The no. 3 exhaust valve looks a little burnt compared to the rest.  Might have been running rich on that cylinder.  The Pistons look good.  I thought the engine looked untouched until I got to the cylinder base gasket.  There's some scrape marks and what looks like old gasket sealant on the case.  Other than that I don't think I can complain.
« Last Edit: March 06, 2016, 07:44:42 PM by budman »
Bud
2021 Indian Scout
Offline mystic_1
  • 1970 CB750K
Re: CB750 K4 Build
« Reply #253 on: March 06, 2016, 07:30:23 PM »
Looking good, that cam chain tensioner has seen some miles for sure.
Nice job on the clutch locknut tool.
How were the bores?
mystic_1
- John Augustus Shedd
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #254 on: March 06, 2016, 07:47:16 PM »
How were the bores?
mystic_1
No scrapes, gouges, burning or cracks.  A little shiny, but a quick hone is all I think it needs.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #255 on: March 07, 2016, 06:54:06 AM »
Motor looks pretty clean, Bud.  Plan to paint? Color??
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #256 on: March 07, 2016, 07:54:59 AM »
Yep.  Black or dark charcoal grey cases (probably black) silver cylinders, black head and chrome covers.  I don't want to spend a lot of time polishing aluminum.
Thanks for your help yesterday.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #257 on: March 07, 2016, 02:41:51 PM »
Anytime...
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #258 on: March 10, 2016, 03:34:37 PM »
I dug out the leftover hunk of cow that I used to cover the seat on my bobber and it looks like I have just enough to do the CB750 seat.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #259 on: March 20, 2016, 04:40:21 PM »
I started stuffing some wires today.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #260 on: March 22, 2016, 04:31:53 PM »
Working on the seat.  I got the pan painted and my foam arrived.  Still got some glueing and shaping to do.  Now that I've gotten this far with the seat it looks like I'm going to need some more leather.
Also, took the family to the art museum for a "Sculpted in Steel" exhibit.  Mostly Art Deco cars, but they had this cool old Henderson with the in line four.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #261 on: March 22, 2016, 04:37:40 PM »
That's a very Art Deco Jetson's bike.
Offline budman
  • 1914X
CB750 K4 Build
« Reply #262 on: March 26, 2016, 12:44:44 PM »
Just bought a never-been-used 1974 plate for the bike.  Still has the paper on the back.
« Last Edit: March 26, 2016, 05:41:51 PM by budman »
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #263 on: March 26, 2016, 01:37:46 PM »
Nice touch.
FYI - if you register as an antique vehicle, no need for annual inspection [and unsightly sticker]
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #264 on: March 26, 2016, 01:46:36 PM »
Nice touch.
To run the plate I'll have to register it as an antique or a classic.  I think you still have to have it inspected as a classic and you can ride it anywhere/anytime vs. limited use as an antique...which from what I have heard isn't really enforced.  They don't do the sticker anymore on anything.  It's all in the system.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #265 on: March 26, 2016, 01:49:50 PM »
Nice touch.
It's def not enforced, but unless being used as a daily rider, you can always just say you are "testing" it or headed to a Rally.  I always register as an antique, the plate is good for 5 years [but prorated] and only $60.
Offline budman
  • 1914X
CB750 K4 Build
« Reply #266 on: March 26, 2016, 04:13:23 PM »
Good to know, Steve.
On another note, I now have one rebuilt oil pump.
« Last Edit: March 26, 2016, 05:40:41 PM by budman »
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #267 on: March 28, 2016, 05:22:04 PM »
I've run into a little predicament.  The engine I bought was running an oil cooler and there's a threaded adapter mounted in the lower case.  The problem is the adapter has splines on it where it goes into the case.  I bought a chrome one piece oil filter with an adapter that screws into the case, but obviously I won't be able to use it if I can't get the other adapter out.  There's a second part to the oil cooler adapter that holds the oil cooler housing on that has a big nut on one end.  I don't know if I should try to get that oil cooler adapter out of the case with some vise grips or not.  I don't know how far the splines go into the case and how bad the threads are screwed up.  I wasn't planning on running an oil cooler.  I could plug the holes in the oil cooler housing and use the chrome oil filter I bought, but it's going to stick out an inch.  Anybody have any experience with an oil cooler adapter like this?
« Last Edit: March 28, 2016, 05:24:55 PM by budman »
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #268 on: March 28, 2016, 06:09:07 PM »
I panicked too soon.  I zoomed up on the photo I took and the splines looked shallow.  I was able to remove the adapter by tapping it with a screwdriver and a hammer on the edge of the ID.  It came out real easy.  I've never seen an adapter like that before.  The threads in the case look fine and the chrome oil filter will screw right on with no cooler housing.
« Last Edit: March 28, 2016, 06:11:44 PM by budman »
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #269 on: March 28, 2016, 06:24:18 PM »
I haven't seen me of those before, Bud. Glad it worked out.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #270 on: March 28, 2016, 06:32:03 PM »
Yeah, it's weird.  I was looking at some other oil coolers online and all of them had a one piece adapter that held the housing in place.   The splines had me worried.
« Last Edit: March 29, 2016, 06:24:07 AM by budman »
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #271 on: April 02, 2016, 04:38:43 PM »
I decided since I was this far along I might as well split the cases.  My engine stand brackets worked great for flipping the engine over.  A few blocks of wood to support it and it's sitting just right.  Everything looks pretty good in there.
I should have my cylinders and head back on Wednesday.  I sent them out to be rebuilt.  The cylinders needed to be bored so that means new 1 over pistons.  I'm getting a new primary chain tensioner too.
Also been working on shaping the seat foam.  Gonna try and work on that some more tomorrow.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #272 on: April 02, 2016, 07:57:59 PM »
Seat looks great, Bud.
Offline mystic_1
  • 1970 CB750K
Re: CB750 K4 Build
« Reply #273 on: April 03, 2016, 08:32:21 AM »
Looking good, glad you decided to go the rest of the way!   ;D
Motor stand adapter works well indeed.  Sell a few sets to fund you build!  8)  Looks like when the engine is flipped like that, it ends up at a nice height for working on while standing.
Your internals look to be in good shape from what shows in the pics.  Sludge isn't even all that bad.
mystic_1
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #274 on: April 03, 2016, 02:29:52 PM »
mystic_1
Yeah, it's pretty clean.  Just a thin layer of grime inside the cases for the most part.  There was some thick stuff in the oil pan, but it's gone now.
With the cases spilt and up side down the work height on the stand is just about perfect for me while standing.  I'm 6' tall.  With the engine in normal position I sit on a stool I'm good.  The height is adjustable though.
« Last Edit: April 05, 2016, 09:51:10 AM by budman »
Bud
2021 Indian Scout
