Author Topic: CB750 K4 Build - The Cafe Tracer  (Read 121449 times)
Re: CB750 K4 Build
« Reply #475 on: January 02, 2017, 06:22:28 PM »
A buddy had these on his CB400F. Not very good.  The back end was pogoing.
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: CB750 K4 Build
« Reply #476 on: January 04, 2017, 03:57:44 PM »
One of the last pieces of the puzzle.  Hope it fits.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Re: CB750 K4 Build
« Reply #477 on: January 04, 2017, 04:01:27 PM »
Sorry to hear about the shocks, Bud.  Consider Ikons, member Nobelhops is now the U.S distributor.
What exhaust?
Offline Davez134
Re: CB750 K4 Build
« Reply #478 on: January 04, 2017, 05:20:15 PM »
Looks like the yoshi replica from Yamiya
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #479 on: January 04, 2017, 06:42:55 PM »
What exhaust?
I've got some shocks coming.  I had to compromise a little due to finances.  If they turn out to be junk I'll look at upgrading to Ikons.
The exhaust is a Yamiya as Dave stated.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #480 on: January 04, 2017, 07:19:08 PM »
I'm really impressed with the chrome job.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #481 on: January 04, 2017, 08:07:24 PM »
I love the smooth bends of that Yamiya Yosh replica.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #482 on: January 05, 2017, 05:48:14 AM »
Me too.  Kind of funky looking, but I think it will go with my build.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #483 on: January 05, 2017, 06:52:48 AM »
+1...first thing that came to mind when I saw it. Cant wait to hear it, Bud.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #484 on: January 05, 2017, 11:10:20 AM »
Me too.  I got the baffle with the larger I.D.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #485 on: January 05, 2017, 06:39:24 PM »
New shocks = clearance.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #486 on: January 07, 2017, 02:18:30 PM »
I've pretty much got the hand controls sorted out.  Now I can drill the holes for the switches and finish up the wiring.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #487 on: January 14, 2017, 06:21:04 PM »
The wiring is done.  All systems I can test are working.  I haven't tested the ignition yet because I haven't tried to crank the engine yet.  I want to polish the oil lines and put some oil in the engine before I try to crank it.  Also, because the engine isn't running yet I can't test the kill switch, but the relay is working, so that's a good sign.
Bud
2021 Indian Scout
Offline palepainter
    • Mike Learn custom paint and airbrush.
Re: CB750 K4 Build
« Reply #488 on: January 14, 2017, 06:32:20 PM »
Looking fantastic.  Really tidy and well planned.
Offline markreimer
Re: CB750 K4 Build
« Reply #489 on: January 14, 2017, 07:38:23 PM »
What shocks did you end up using?
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #490 on: January 14, 2017, 07:59:51 PM »
They were sold as Cyclesmith shocks, but I'm pretty sure they're Emgo shocks.  I went with some 365's to gain some clearance.  I like the stance.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #491 on: January 14, 2017, 08:33:02 PM »
Thanks, Mike.  I planned out where all the big stuff was going to go.  Had to figure out a lot along the way.
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #492 on: January 15, 2017, 09:46:19 AM »
You can test anything with your meter. If it works with it, it will work in the real world. Have confidence! A tidy looking job.
Thanks.  I'm as confident as I can be at this point.  Continuity wise I've tested everything I can think to test, still I won't know 100% if all systems are go until I fire this puppy up.  That moment of truth...
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #493 on: January 15, 2017, 12:17:00 PM »
I'm exhausted.
I also got the brake caliper installed.  Waiting on a new adjustment bolt and spring.
Things left to do:
Rebuild carbs.
Purchase an air cleaner.
Color sand and polish gas tank.
Clear coat wooden rear section one more time, wet sand and polish and install.
Special order and install throttle and clutch cables. (Don't pay attention to the clutch cable that's on the bike now.  It's just there for fitting and testing purposes.)
Install front brake line.
Hook up starter.
Add gas and oil.
Hit the start button.
« Last Edit: January 16, 2017, 07:13:21 AM by budman »
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #494 on: January 15, 2017, 02:32:07 PM »
Hook up a battery, and use your meter to test the voltage at the switches. The engine doesn't need to fire except to test the charging system.
I've hooked up the battery and everything appears to be working properly.  Turn the key on and there's power to the ignition, headlight works, tail light works, brake light works, speedo light works, horn works, the kill switch relay disengages, the starter solenoid is engaging when I hit the start button...I think I'm good.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #495 on: January 15, 2017, 04:00:05 PM »
Looks fantastic Bud!
Offline budman
  • 1914X
CB750 K4 Build
« Reply #496 on: January 15, 2017, 05:48:40 PM »
Thanks Steve.  Hopefully I'll be able to take a trip to the Hill Country on it this spring.  I sure hope this won't be another soggy year.
Bud
2021 Indian Scout
Offline palepainter
Re: CB750 K4 Build
« Reply #497 on: January 15, 2017, 06:46:32 PM »
Congrats on just about wrapping the scoot up.  It sure looks sweet and has a look all of it's own.  Looking forward to some video of it hummin along.  :)
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #498 on: January 16, 2017, 07:12:39 AM »
Thanks, Mike.  I can see the finish line.  Actually I could see the finish line when I began this project 2 1/2 years ago or I wouldn't have started.  At the time I thought it would only take me a year.  I forgot to take into account that I can't leave things stock.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #499 on: January 16, 2017, 07:18:48 AM »
Seems when we do these "rebuilds" for a hobby, it takes much longer than anticipated, especially when we have other ridable bikes!
The Park Racer was to be a quick 3 month refresh, said and done it will probably be a year long project.
Would be nice to ride them both in the Hill Country this spring.
