Author Topic: CB750 K4 Build - The Cafe Tracer  (Read 120094 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
CB750 K4 Build
« Reply #525 on: February 04, 2017, 02:48:02 PM »
It's the little things that get you.
I had to make a small pin because I drilled out the carb rack in order remove the throttle rod so I could clean up and re-plate all the linkage.  Got the idea from the Hackaweek vids.
I also had to make a new collar that goes on the throttle rod.  I seemed to have misplaced the original.  I can't remember if I zinc plated it or not.  The plan was to have the carbs mounted on the bike today, but not sure it's going to happen.  I'm zinc plating the new collar at the moment and it takes a while.
« Last Edit: February 04, 2017, 08:11:37 PM by budman »
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #526 on: February 04, 2017, 07:45:10 PM »
Any chance you filled that little notch you got in the rod, from drilling the old pin out?
If not; your new pin may get caught in there and lock up your throttle.
Nah.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #527 on: February 04, 2017, 07:46:17 PM »
Just about ready to install on the bike.
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #528 on: February 05, 2017, 04:42:02 PM »
Installed the carbs, but I have to take them back off.  I forgot to install the four washers that go on the choke linkage before the small cotter pins.
« Last Edit: February 05, 2017, 04:44:27 PM by budman »
Bud
2021 Indian Scout
Offline WesTenRacing
Re: CB750 K4 Build
« Reply #529 on: February 06, 2017, 07:20:00 AM »
I've been following this build since I joined the forum.  Very nice job!  I look forward to the maiden voyage.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #530 on: February 06, 2017, 08:09:43 AM »
Thanks. I'm looking forward to the maiden voyage too.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #531 on: February 06, 2017, 03:21:02 PM »
My custom cables arrived.  Sure hope they fit.  Only one way to find out.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #532 on: February 11, 2017, 05:48:11 PM »
For the most part the cables worked out.  I had to send the push cable back and have a little bit a free play added.  It was about 10mm too short.
Today I sprayed the final coats of clear on the wooden tail section.  Next weekend I'm going to cut and polish the tank and tail section.
The carbs are pretty much ready to go.  Just waiting on a tee so I can hook up the fuel line.  I ordered an Airbox from Cognito Moto.  Hopefully I'll have it next week.
I had to take the CB750 off the lift today so I could install a new starter in my Chobber.  The CB750 looks so much better on the ground.  Can't wait to ride it.
Bud
2021 Indian Scout
Offline palepainter
    • Mike Learn custom paint and airbrush.
Re: CB750 K4 Build
« Reply #533 on: February 17, 2017, 07:55:12 PM »
Oh ya.... Looking so sweet.  What tank did you start with?  IT is going to be a sweet scoot.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #534 on: February 17, 2017, 09:50:30 PM »
Thanks.  It's a heavily modified Suzuki GT750 tank.  1975 I think.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #535 on: February 18, 2017, 02:06:13 PM »
Shiny!
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #536 on: February 18, 2017, 03:19:19 PM »
Major milestone.  Just put oil in the bike, hooked up the starter wire, turned the key on and hit the start button.  So smooth.  Only thing better would be to put gas in it and hear it run.  Soon!
« Last Edit: February 18, 2017, 04:55:39 PM by budman »
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #537 on: February 18, 2017, 04:03:35 PM »
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #538 on: February 18, 2017, 05:15:12 PM »
A shot of the tank here, a shot of the tail there, in my day you'd be called a "Pr1ck teaser".... ;D ;)
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #539 on: February 18, 2017, 05:24:00 PM »
Hold on to your ying yang.  You'll see a finished bike at some point.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #540 on: February 23, 2017, 07:28:48 PM »
After some futzing I have a slightly modified Cognito Moto airbox that fits.
Bud
2021 Indian Scout
Offline markreimer
Re: CB750 K4 Build
« Reply #541 on: February 23, 2017, 08:24:57 PM »
Oh I like how that looks!!
Re: CB750 K4 Build
« Reply #542 on: February 24, 2017, 05:08:15 AM »
Shiny!
Simply beautiful, Bud!
What main jets do you plan to use with that airbox and exhaust?
What else is needed to fire her up?!
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #543 on: February 24, 2017, 05:52:01 AM »
Thanks, Steve.  I ordered a spec'd jet kit and for the first attempt they recommended 115's for the two outside carbs and 117.5's for the two inside carbs.  If it's too lean they said to move the 117.5's to the outside and use 120's on the inside.
I need to redo one of the oil lines.  It leaks.  I didn't have enough line up inside the compression fitting to get a proper seal.  After that I think all I need is gas.  My sync gauges and IV bottle arrived yesterday.  Unfortunately, or depending how you look at it, it's my son's 18th birthday on Sunday.  I'm taking him to the Lone Star Throwdown Truck show in Conroe tomorrow and doing the birthday thing on Sunday.  I probably won't get to do much on the bike until next weekend, but I'm supposed to go on a ride that Sunday.  I still need to polish the gas tank.  I'll get there.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #544 on: February 24, 2017, 06:11:13 AM »
You've only been working on this 2.5 years, what's another month or two?!
FYI - I changed the jetting on the Park Racer a couple times, it's got 115's now and seems right.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #545 on: February 24, 2017, 06:29:51 AM »
Good to know about the jets.  The engine is basically stock except for the bolt on stuff.
I'm in no hurry.  I'm just trying to make everything as right as I can before the first fire up.  Any pointers you can give for that first start?
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #546 on: February 24, 2017, 06:34:34 AM »
Basically stock except for the most important things for jetting: intake and exhaust.
Before start up, be sure you are getting oil to the top end.  Crank it with the kill switch off [if possible], pull your valve adj caps and look for oil there. Good luck!
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #547 on: March 02, 2017, 05:14:13 PM »
I couldn't get the stainless steel oil lines exactly like I wanted.  Tired of messing with it.  Those stainless lines are very unforgiving.  For now I'm going to run hose.  Maybe someday I'll revisit it...maybe with copper.
I'm going to try to start the bike for the first time on Saturday.  Fingers crossed.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #548 on: March 02, 2017, 05:44:20 PM »
Sorry to hear the ss lines didn't work out.
Good luck on the start up!
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #549 on: March 02, 2017, 06:04:51 PM »
Thanks, Steve.  It's all an experiment so if that's the worst of it I'll take it.  I noticed the oil lines on the Park Racer.  Don't look stock.  Where'd they come from?
Bud
2021 Indian Scout
