Author Topic: 3 prong flasher  (Read 1182 times)
Offline marko59
3 prong flasher
« on: September 14, 2014, 05:15:37 PM »
1976 CB 550...so the flasher has positive, negative and "L" (load?) so what color wires do I attach to? thanks
Re: 3 prong flasher
« Reply #1 on: September 14, 2014, 05:17:30 PM »
Neg. will be green, there shoulld be a plug for the other two. The Old Man Honda site used to have color wiring diagrams.
Re: 3 prong flasher
« Reply #2 on: September 14, 2014, 05:25:03 PM »
You mean it is not marked per this chart?
Offline marko59
Re: 3 prong flasher
« Reply #3 on: September 15, 2014, 04:42:05 AM »
don't see it on the chart, it has the plus, minus signs and L. thanks
Offline Stoli
Re: 3 prong flasher
« Reply #4 on: September 15, 2014, 05:01:46 AM »
On a 750 it would be:
+  black
-   green
L   gray
I assume the 550 would be the same. At the very least, the + and - would be the same so connect whatever is left over to L.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Bodi
Re: 3 prong flasher
« Reply #5 on: September 15, 2014, 05:06:16 AM »
Green to "-"
Black to "+"
Whatever's left to "L" (grey I think: I could look at a wiring diagram but there are only 3 wires...)
There are a lot of different 3 terminal flashers, only a few will work. Some will just blow the fuse immediately when you turn the key on. Yours sounds OK from the terminal letters but most have the European wire numbers as well to confirm.
