Author Topic: Cable and pipe advise cb750k1 please?  (Read 552 times)
Offline cakey
  • 5% recipe and 95% process
« on: September 20, 2014, 07:57:41 PM »
Just about to fire the beast up and putting the final parts on. Need a bit of seasoned advise on where a lot of the fuel lines, hoses and cables get routed through the maze
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
Offline cakey
Re: Cable and pipe advise cb750k1 please?
« Reply #1 on: September 20, 2014, 08:00:15 PM »
Two pipes off the tee pieces on the carby I have going up over the air box and they come out and hang down the back of the oil tank
Offline cakey
« Reply #2 on: September 20, 2014, 08:03:26 PM »
The four drain tubes on the bottom of the bowls I have cable tied together and then over the back engine case and swing arm but I don't know where to place them.
The top breather pipe off the top rear of the oil tank goes down between the oil tank hoses and out between the engine case and swing arm. Bottom rear oil tank hose goes to the back of the engine case breather.
« Last Edit: September 20, 2014, 08:06:41 PM by cakey »
Offline cakey
« Reply #3 on: September 20, 2014, 08:09:16 PM »
Speedo cable goes down behind headlight bucket and fork ears, through the bracket on front guard and on the outside of the fender guard.
Offline cakey
« Reply #4 on: September 20, 2014, 08:23:21 PM »
Clutch cable goes between the case and frame and up behind the headlight bucket and to the clutch handle. I don't seem to have much adjustment left on the cable though.
Offline cakey
« Reply #5 on: September 20, 2014, 08:26:41 PM »
Throttles cables go through the hole in the top yoke and through and over the coils, through the hole in the middle of the frame and onto the carby rack.
Offline cakey
« Reply #6 on: September 20, 2014, 08:28:42 PM »
Thanks for any advice. Probably seems pretty obvious to most but my bike didn't have a lot of this stuff on it when I got it so I don't have anything to base it on. Get this finished, put the points on, oil in and go bang.
Offline Dunk
« Reply #7 on: September 21, 2014, 05:05:16 AM »
Thanks, I was unsure of some of this and took a few guesses to get it right where the cables seemed to naturally go and be out of the way. Are you certain that is the correct clutch cable routing? I have mine currently going through the hole in the upper tree as opposed to the left side of the tree. That does kind of make sense to ensure no obscuring the gauges though as mine is a little close.
