Author Topic: My 73 barn find with 15k original miles!  (Read 18602 times)
Re: My 73 barn find with 15k original miles!
« Reply #25 on: October 02, 2014, 08:10:24 PM »
I made my slave tank from an old riding plastic riding lawn mower hung in a bird cage holder.  :o  Works well. That gas tank had a crap job done with Red-Kote. Good product if done correctly and with the petcock off the tank  :D I have fixed a broken carb like that before, happens when the emulsifier tube.main jet is cranked down too hard, but think your better off getting a replacement on that one crusty sucker. Good luck.
Offline sulphurdave
« Reply #26 on: October 02, 2014, 08:30:39 PM »
That's a good idea with the hanging tank. Yea the inside of my tank looks like Freddy Krueger's face after a dry shave. I should have my tank usable again soon though. I also found a #1 carb body in great condition for $45 from a member on here.
Offline sulphurdave
« Reply #27 on: October 09, 2014, 06:49:17 PM »
Received the replacement #1 carb body today (on the left) so now I'm one step closer to getting the bike running again. Now I need rebuild kits. I think I'm going to skip putting the stock jets back in since I know I'll be using pods or velocity stacks and high flow exhaust almost immediately. Question is do they sell rebuild kits with these bigger jets included? Also, pros/cons of pods vs velocity stacks?
« Last Edit: October 09, 2014, 07:12:02 PM by sulphurdave »
Offline sulphurdave
« Reply #28 on: October 12, 2014, 05:33:53 PM »
Anyone?
Offline sulphurdave
« Reply #29 on: October 24, 2014, 01:34:29 PM »
Surprise of the day...
Offline calj737
  • I refuse...
« Reply #30 on: October 24, 2014, 02:43:40 PM »
And a few others...
Offline sulphurdave
« Reply #31 on: October 24, 2014, 06:24:28 PM »
Wow. I never would have guessed that was hiding under that paint! Makes me wonder what else is hiding in the motor!
Offline sulphurdave
« Reply #32 on: November 21, 2014, 07:47:45 AM »
Some progress on the tank
Offline sulphurdave
« Reply #33 on: November 21, 2014, 07:50:40 AM »
Al the dents and pinholes have been repaired and its been sanded smooth and primered. Now all that's left is a new liner and I'll have it back to start putting the new petcock, fuel lines and rebuilt Carburetors back together
Offline sulphurdave
« Reply #34 on: November 21, 2014, 07:52:14 AM »
Cleaned carburetors ready to be put back together
Offline Bankerdanny
  • Endeavor to persevere
« Reply #35 on: November 21, 2014, 10:30:31 AM »
How did you repair the holes in the tank?
Offline calj737
  • I refuse...
« Reply #36 on: November 21, 2014, 10:36:36 AM »
The pinholes on the bottom were cut out and a patch installed and welded. The crease in left front, suffered a tear out when the dent was pushed out due to rust-rot of the tank. Cut a patch and welded it in too. Ground everything smooth then used a teaspoon of bondo, sanded smooth, followed by Etching Epoxy primer (sanded between coats). Voilà
Offline sulphurdave
« Reply #37 on: November 21, 2014, 12:21:30 PM »
Ta Da!
« Reply #38 on: November 21, 2014, 02:39:02 PM »
Nice!
« Reply #39 on: November 21, 2014, 08:35:04 PM »
Saw this on FB posted by Yule B. Ondis.  aka Sulphurdave?
Offline sulphurdave
« Reply #40 on: November 21, 2014, 09:36:57 PM »
Yea that's me
Offline sulphurdave
« Reply #41 on: December 01, 2014, 08:29:52 PM »
Carbs officially rebuilt. Still waiting on the tank and a new petcock. Getting closer.
Offline sulphurdave
« Reply #42 on: December 01, 2014, 08:33:14 PM »
...also filled the motor with Marvel Mystery oil from the top of the head down to the crank case to give the internals a bath.
Offline sulphurdave
« Reply #43 on: December 03, 2014, 01:58:29 PM »
The carb kits didn't come with new o-rings for these so I went down to the store and bought these viton o-rings that's suppose to be safe for fuel. I didn't know the exact size but these seem to look and fit right. The old ones were so old and worn they were flat and hard like plastic. We'll see how well these work.
Offline sulphurdave
« Reply #44 on: December 03, 2014, 05:43:34 PM »
Not that anyone is following this anymore but the o-rings are too big I guess. They won't slide in.
Offline goldarrow
  • one day, i'll be an
« Reply #45 on: December 03, 2014, 06:03:01 PM »
I have some of those orings around, pm me if you need.
CB550 K0
Online Stev-o
« Reply #46 on: December 03, 2014, 06:03:56 PM »
We're following....
Offline Slinky
« Reply #47 on: December 03, 2014, 06:16:12 PM »
is that a factory seat? I need one like it :)
Offline goldarrow
« Reply #48 on: December 03, 2014, 06:17:50 PM »
We're following....
You need those orings?
CB550 K0
Online Stev-o
« Reply #49 on: December 03, 2014, 06:26:07 PM »
We're following....
No, Dave does.  But Thanks Mr Lestor.  You open those boxes yet?
