Author Topic: Cam Shaft shells scored/marked  (Read 863 times)
Offline Roadrage23
« on: September 29, 2014, 02:09:25 PM »
Hi Everyone,
I'm currently restoring the engine on my CB750F1 and have noticed scoring on my camshaft shells. The camshaft is in good condition and the engine has done 37'000 miles on the clock.
What do you guys think? Is this acceptable?
Regards,
Roadrage23
Re: Cam Shaft shells scored/marked
« Reply #1 on: September 29, 2014, 02:49:19 PM »
I'd reuse those...
just be sure to put the caps back on the same location they came off.
Offline Roadrage23
« Reply #2 on: September 29, 2014, 02:53:04 PM »
Hi Flybox1,
Thanks for the quick reply... I was hoping for that answer  ;D!
Regards,
Roadrage23
Offline iron_worker
« Reply #3 on: September 29, 2014, 03:01:57 PM »
Ya they look decent to me too. The bearings are just aluminum so they can get marked up pretty easily.
IW
« Reply #4 on: September 29, 2014, 06:48:36 PM »
Those are fine. Keep the oil and filter changed to keep the microscopic buggers from heading up top.
Online Don R
« Reply #5 on: September 29, 2014, 09:13:27 PM »
I like to use a little assembly lube so they are good until the oil gets there.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #6 on: September 29, 2014, 10:59:11 PM »
Top tip.
+1 on re-installing, I've put worse than that back in!
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline trueblue
« Reply #7 on: September 30, 2014, 05:40:46 AM »
A groove or score is acceptable, it will only hold more oil. What you have to look for is a lump, these cause clearance  issues. What you have there looks fit for service. ;D
1979 CB650Z
Offline garyS-NJ
« Reply #8 on: September 30, 2014, 10:19:30 AM »
mechanical failure resulted in one trashed rocker holder (and a trashed cam & caps) in my 1978750F3 but luckily I have a basket motor with a nice cam and rocker towers but no cam journal caps...  UGH, everywhere I read the caps must be matched to the tower.  Is this because of the smaller inner journals and is there anything I can do besides buy new/used towers??
76 harley stroker FL
83 Yamaha XJ550 Maxim
78 CB750F3
« Reply #9 on: September 30, 2014, 10:50:37 AM »
ideally you want them matched so they continue to wear at the same rate.  new caps, or the same caps put in a different location, will see accelerated wear on the cap and the cam.
My F3 valve train was in buckets when i got it.  My journals and caps were all just lightly worn.  I fit them properly to the towers (look for the tapered end of the cap), and lubed them up well during assembly and break-in.
Offline Roadrage23
« Reply #10 on: October 01, 2014, 11:12:33 AM »
Hi Guys,
Thanks for all the replies, I will reuse them and use the appropriate assembly lube  ;D.
Regards,
Roadrage23
