Logo merchandise is available at the SOHC/4 Shop
0 Members and 7 Guests are viewing this topic.
Is there a secret to splitting the front part of the speedometer from the chrome rear part of it?
The bottom line is that you really don't have to take it off if you don't want to. It does make the reassembly a little easier by reducing the weight of the crank shaft.
Quote from: Stoli on October 30, 2014, 07:51:03 PMThe bottom line is that you really don't have to take it off if you don't want to. It does make the reassembly a little easier by reducing the weight of the crank shaft.The manual says to remove the stator as well as the gear shift levers etc to the right of the stator before splitting open the top and bottom of the case. Is that not necessary?
First of all, I could have my terminology wrong but I thought the "stator" coil is mounted to the inside of the cover. The "rotor" is mounted to the end of the crankshaft. The rotor, and rest of the alternator, sits in oil and there is no seal behind it. There is an oil seal on the other end of the crank by the points. You don't have to remove the rotor to change a seal or crack the case. It just makes reassembly a little easier but not much. You do want to remove the gearshift mechanism. Still no oil seals that I am aware of but if memory serves, you wouldn't be able to remove the transmission unless you took off the gearshift mechanism. Take lots of pics while you do that. Will make reassembly easier.What oil seals are you referring to grcamna?
As a reminder, be ready to drill out some or all of the screws that hold on the countershaft bearing holder. Those puppies are staked in there pretty tight and don't like to give up very easily, even with an impact driver there is a good chance you will strip the heads.
I'd replace the spokes with either stock units or stainless units from Buchanan's.
I'd replace the spokes with either stock units or stainless units from Buchanan's.Love the Benz!I am partial to the Avon RoadRider or Metzlers. Lots use Bridgestones, Dunlops and others Shinkos. You choose!
<snip>You do want to remove the gearshift mechanism. Still no oil seals that I am aware of but if memory serves, you wouldn't be able to remove the transmission unless you took off the gearshift mechanism. Take lots of pics while you do that. Will make reassembly easier.What oil seals are you referring to grcamna?
