Author Topic: Senior project for high school - 78 CB750K  (Read 177970 times)
Offline edwardmorris
  • Youngish
Re: Senior project for high school - 78 CB750K
« Reply #750 on: March 16, 2015, 05:59:52 PM »
Thanks, ordered.
Offline Restoration Fan
  • My wife will never call me
« Reply #751 on: March 17, 2015, 06:57:16 PM »
Logan and I finally decided to register the bike in Vermont.  We had considered just registering it here in Georgia but decided to do the Vermont thing and then register it in Georgia to try and get a title for it.
So I'm filling out the form right now but not sure how to calculate the fees so I can send in a check with the application for the proper amount.  Anyone know how to calculate that?
« Reply #752 on: March 17, 2015, 07:12:15 PM »
Yes, call them at 802-334-3363 and they will tell you the value of the bike and the fees.
« Reply #753 on: March 17, 2015, 07:15:21 PM »
Excellent.  Thank you, Stev-o.
Offline martin_uk
  • CB750F1 CB750K8
« Reply #754 on: March 18, 2015, 02:18:00 AM »
Honda part number 07954-3000000 (from the manual). The single part number includes both pieces (as indicated in the manual) since two pieces are required to do the job. With shipping it was $48.66.
Thanks, have used car type piston ring clamps and tricky to remove once piston is engaged, so ordered a set from DSS, but in UK almost double the US price  :'(
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline Bill/BentON Racing
    • BentON Racing
« Reply #755 on: March 18, 2015, 05:35:49 AM »
Guys, they are awesome. Stock bores they are the bomb. Bigger bores need 450 Honda ones 292 middle part number. 915 and bigger....back too clamps!  K, Bill
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #756 on: March 18, 2015, 05:41:57 AM »
Like this one from Honda of Atlanta Northside Dr. and a few other shops... Roswell Honda. Had it since 82! All you need, but Ron I want a stand!  8) ;D Bill
Offline oldhatt45
« Reply #757 on: March 18, 2015, 05:43:33 AM »
Hey Bill,
Just curious because I've never taken the cylinders off my 750.  Will the larger 450 type work on stock bores?
Just thinking ahead if at some point I might need to bore my cylinders.  Also if you might know, will they work for a GL1000?
Thanks
Charlie
    • BentON Racing
« Reply #758 on: March 18, 2015, 05:46:23 AM »
Should be the ones for a GL 1000. I'll try mine on a stocker, but think not enough compressing of rings, Bill
Offline oldhatt45
« Reply #759 on: March 18, 2015, 05:52:25 AM »
Thanks Bill!
Charlie
« Reply #760 on: March 18, 2015, 06:49:59 AM »
What he said!
I'll never touch doing piston rings again without one of these.  Once we had finished, I returned Bill's to him and it was the next day that we discovered we had put the cam chain tensioner guide on backwards.  We were able to take it apart and put it back together without taking the head back off.  But if we HAD needed to remove the head again, I had already told Mike and Logan that there was no way I was going to do it without the tool.  If necessary, I was going to drive 45 minutes back to Bill's house, borrow the tools and then return them back to him once we were done.  It just simply makes the job that much easier.
The chamfer on the top of the tool is perfectly suited for the chamfer on the bottom of the cylinder sleeve.  You just get the rings compressed, let the head slide down gently onto the chamfer and lightly tap it a few more times until the rings are inside....then pull the tool out.  It's night and day less effort, stress and worry about breaking a ring.
« Reply #761 on: March 18, 2015, 11:39:58 AM »
Got the tank sanded down and it's ready to do the skim coat of bondo on the 4 or 5 small low spots in the tank.  We couldn't resist sitting it up on the bike along with the seat.
Gotta say, I'm digging the "raw" look.  We aren't going to leave it like that but it is kind of sexy.
Very little left to do on the bike other than painting the tank and side covers.  Still have to finish the wiring.  We'll bleed the brakes tonight.  Chain guard needs to go on.  Then it's pretty much sit back and wait for the carb rebuild kits to arrive on Friday.
Offline AintNoEasyWay
« Reply #762 on: March 18, 2015, 12:27:48 PM »
Did you finally decide on a tank/side cover color?
« Reply #763 on: March 18, 2015, 12:38:32 PM »
We did.  We're going to do....TWO DIFFERENT COLORS!  :D
LOL, well first we're going to do the Candy Gold color.  Logan and I both love that color but the problem is getting the decals to go on the tank.  We don't think that either of the 2 decal sets that go on the 78 tank will look good with the gold.  So I'm meeting with a friend who has a decal business this week to discuss having him make me a custom set of black ones that match the pattern of the 78's but don't have the other colors to clash with the gold.
Then, I think I'm going to go ahead and fix up the 2nd tank and buy a 2nd set of side covers and another petcock.  That set will be Planet Blue Metallic and use the decals that normally go on the black 78.
So, what I'll end up with is a gold bike for a while.  Then when I get tired of it being gold, I'll swap out the tank & side panels and go to the blue color!  8)
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #764 on: March 18, 2015, 02:34:22 PM »
I like your thinking Ron, being able to change the look when you want to. It's a bit like my choice in clothes - I have one blue pair of jeans, one black pair of jeans, and a dozen or so black T-shirts so I can mix and match. Don't need anything else. Shame I can't get the wife to see it that way ;D
I know what you mean about the raw look - I nearly went that way with mine, but the tank just had one too many dings in it.
With all this progress you'll soon be twiddling your thumbs. Got another project in mind?
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #765 on: March 18, 2015, 03:00:43 PM »
The bike is looking great.  I think with the shape of the tank, the Planet Blue is going to look fantastic.
« Reply #766 on: March 18, 2015, 03:29:43 PM »
Yes, I like it too. Here is my current K7 project...
Offline callmejarob
« Reply #767 on: March 18, 2015, 03:42:08 PM »
Man you are FLYING on the bike build now that the engine is assembled!  Makes me excited to get mine done!  I need to order a ton of electronics though...
Im ordering those piston clamps RIGHT NOW!
« Reply #768 on: March 18, 2015, 05:35:16 PM »
Well, I'm taking the Motorcycle Safety Foundation class April 9-13, after which I intend to put some miles on Stella.
But, I've already been scouring the interwebs looking for the next bike.  I've got my eye on a few that may turn out to be contenders but I doubt that I'll do anything until late summer on buying another one.  I coach a travel baseball team during the summer and we have games literally every single day of the summer.  The team is a bunch of 17 year olds so I spend some time with them and then a good bit of time with the college coaches who are scouting the players.  From mid-May when we start until that winds down in mid-July, I don't have a lot of free time on my hand.  The good news is that I will be riding Stella to a lot of the games this summer.
« Reply #769 on: March 18, 2015, 05:39:27 PM »
I'm glad you posted that.  I've been toying with the idea of going ahead and putting the exhausts onto the bike but there are a few things we need to finish before we do that.  So, you posting your photo with the pipes on is a really big help.
Also, thank you very much for the info on the Vermont title.  I had a great chat with a guy from the Vermont DMV and then dropped off my check and application in the mail today.
Edited:
Steve-o, can you do me a favor and take a photo of the rear turn signals and how/where they connect to the bike on the K7?  I have some rear signal lights with stems but can't figure out how to make them attach correctly along with this grab bar I have on it.
« Last Edit: March 18, 2015, 05:46:39 PM by Restoration Fan »
« Reply #770 on: March 18, 2015, 05:41:30 PM »
Here's a brilliant example of gold with black stripes...
http://forums.sohc4.net/index.php/topic,131724.425.html
As for your next project, look no further than Bill's backyard! Plenty of great candidates there and, as you know, he's got everything you'll ever need to build a real dream  :D
Thanks, cal.  And you have a point; I might just go see about buying one from Bill.
The problem with that gold one is that's a pre-77 tank so that stripe looks different on there than on a 78 one; which is the big honking tank.  That is a beautiful bike though.  It's bikes like that which made us decide on the gold.
« Last Edit: March 18, 2015, 05:43:58 PM by Restoration Fan »
« Reply #771 on: March 19, 2015, 08:11:41 AM »
Take her out to the ball games, Ron. Sounds like a lot of fun.
« Reply #772 on: March 19, 2015, 03:33:16 PM »
Sure, but I don't have the grab bar and not putting one on. This is nowhere near a stock restoration, more like a get it running and back on the road so I can sell it! Hope this helps...
Offline Bankerdanny
  • Endeavor to persevere
« Reply #773 on: March 19, 2015, 03:48:54 PM »
Dont fix the temporay tank too high above carbs when bench testing as can cause pressue to be too high.
I think you are wrong there. The weight of the fuel pressing down is what creates the pressure on the float and that doesn't change in any measurable way even if the tank is 10 feet off the ground.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #774 on: March 19, 2015, 06:09:13 PM »
Those are located and oriented properly. The base of the signal rests on the outside of the frame, the grab bar mounting bolt captures the signal bracket and threads into the fender through the hole in the end of the frame. The wires just route up under the seat to the harness connectors closer to the front of the fender. Ignore the extra outer bracket in the picture below, that is one of the mounting points for my rear luggage rack as well.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
