Author Topic: Senior project for high school - 78 CB750K  (Read 174311 times)
Offline calj737
  • I refuse...
Re: Senior project for high school - 78 CB750K
« Reply #1025 on: April 22, 2015, 02:30:41 PM »
Can you shoot a picture of the connection of the 1/4 coil where you crimped/attached the BLK/WHT and RED please?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #1026 on: April 22, 2015, 02:32:35 PM »
Or a bad Pamco trigger/sensor for 1/4. Switch the Pamco ignition trigger connections to the coils (swap 2/3 green with 1/4 green) and see if the spark follows. If it does, then the Pamco pickup is bad. If the spark stays on the same cylinders then the coil is bad.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Restoration Fan
  • My wife will never call me
« Reply #1027 on: April 22, 2015, 03:07:30 PM »
Offline calj737
  • I refuse...
« Reply #1028 on: April 22, 2015, 03:13:56 PM »
And both coils are wired the same way? If so, and you're comfortable it's wired correctly, (appears so in pictures and from your description) then follow Wilburs steps to determine where the fault is.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #1029 on: April 22, 2015, 03:18:13 PM »
Ya, you've chased and wired it perfectly. Follow Wilber's suggestions and you will know for sure where the problem lay.
N.
I have a motorcycle problem.
« Reply #1030 on: April 22, 2015, 03:19:09 PM »
The male bullet connector (with the red and black/white wires) is not crimped. Did you solder that one?
Also, if you follow my suggestion and determine the coil is good, you might still want to check the wire from the coil down to the trigger (at the points plate) and make sure you have a continuous circuit before deciding the trigger is bad.
TAMTF...
Wilbur
Projects:
« Reply #1031 on: April 22, 2015, 03:41:05 PM »
Wilbur,
I re-did that connection after taking the picture because it didn't appear to be very solidly in there.  I put a new bullet connector on and crimped it down well.
So....it appears I have a bad 1/4 coil.  Before swapping them, I confirmed again that I had spark on 2/3 but not on 1/4.  Then, we swapped the green/blue connections.  Afterwards, I'm still getting spark on 2/3 but not on 1/4.
I suppose the best thing now is to try and send a PM to Pamco Pete and see if I can get a replacement coil?
« Reply #1032 on: April 22, 2015, 03:44:21 PM »
 I confirmed again that I had spark on 2/3 but not on 1/4.   Afterwards, I'm still getting spark on 2/3 but not on 1/4.
Ron - is this a typo?
Offline calj737
  • I refuse...
« Reply #1033 on: April 22, 2015, 03:51:48 PM »
No, it means coil B is firing whether it's attached to Blue or "Yellow". Which tells me it's not the coil, but the trigger.
« Reply #1034 on: April 22, 2015, 03:54:40 PM »
That's what I was thinking - not the coil.  "Coils rarely fail" as they say...
« Reply #1035 on: April 22, 2015, 04:05:30 PM »
Ahhh...yeah I see where my logic was bad now.  Crap.  I was hoping it was the coil because I still have the 2 coils I pulled off the bike before and could substitute one of those.
I bought the PAMCO from VintageCB750.com.  I guess I need to get in touch with them tomorrow and get a new one shipped out asap.  Logan has his "stand and deliver" tomorrow, which is his presentation to just his teacher.  We wouldn't have used the bike for that anyway and just used the PowerPoint.  But his final presentation is a week from today (next Wednesday) so I'm hoping that they can get me one shipped out overnight.
Worst case, we can trailer it up there and just let them look at it without cranking it.  But it sure would be nice to be able to let them hear it crank.
« Last Edit: April 22, 2015, 04:07:33 PM by Restoration Fan »
Offline calj737
  • I refuse...
« Reply #1036 on: April 22, 2015, 04:21:32 PM »
Just for giggles, inspect very closely the ignition plate. Any chance a red wire is grounding out or is damaged at the connection?
« Reply #1037 on: April 22, 2015, 04:41:44 PM »
It doesn't appear so, cal.  The connections aren't in a bind and look to be very solid.  And I can't see where it would be shorting against anything either.  Where it passes through the hole, the wire is in good shape and doesn't look to have any tears.
Offline Maurice
« Reply #1038 on: April 22, 2015, 04:45:04 PM »
Have some points laying around? They're not that hard to set up, in the meantime...
Offline calj737
  • I refuse...
« Reply #1039 on: April 22, 2015, 04:46:03 PM »
More proof that you and Logan are 1:1,000,000. Probably the only folks I've seen receive a effective Pamco unit. Rotten luck, but I think your diagnosis is conclusive.
Stella has her groove on for sure-
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #1040 on: April 22, 2015, 04:57:01 PM »
Damn! FYI, vintagecb750 is based in Canada, while cb750supply is based in the US. You might be able to return this set to vintagecb750 and order a new one faster from cb750supply. They are essentially all the same stuff.
--Evan
1975 CB750K "Rhonda"
« Reply #1041 on: April 22, 2015, 05:31:28 PM »
Good info.  Thank you.  I'm going to call them tomorrow and see what's available.  I don't mind them charging my card for a new unit and then refunding it when they get my unit back if that will help speed things up.
Thank you to all of you guys for the insight and the help with diagnosing what's going on.  We really appreciate the support, advice and help that we have received from other members of this forum.
« Reply #1042 on: April 22, 2015, 05:45:40 PM »
Now I'm confused.  ??? If you connect trigger (points) "A" (or blue) to coil "B" and the coil fires, and then you connect trigger (points) "B" (or yellow) to coil "B" and the coil fires again, then that means both triggers are good (they both signal the coil to "fire"). Connect each set of triggers (one at a time) to coil "A" only and see if coil "A" will fire on either set of triggers. If coil "A" will not fire on either set of triggers then the coil (or it's connections) are bad.
Now I'm getting a headache...  ;)
« Last Edit: April 22, 2015, 05:49:02 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #1043 on: April 22, 2015, 05:51:37 PM »
Wilbur,
This points to a bad coil to me...
TAMTF...
Wilbur
Projects:
« Reply #1044 on: April 22, 2015, 05:54:08 PM »
Pm Peter, he'll sort you out... ;)
Offline calj737
  • I refuse...
« Reply #1045 on: April 22, 2015, 06:00:06 PM »
Wilbur,
I'm confused, Wilbur.
Coil A is connected to 1/4 and BLUE, but does not fire
Coil B is connected to 2/3 and GREEN, and does fire.
Move GREEN to coil A and 2/3 still fire (proof that coil A fires)
Move BLUE to coil B and 1/4 still won't fire.
Gotta be the triggers, no? Coils when wires swap problem follows the wire, not the coil.
Or am I missing something?
« Reply #1046 on: April 22, 2015, 06:38:33 PM »
Wrong. Coil A is still connected to 1/4 spark plugs, only now we're connected to the 2/3 trigger. you've only swapped triggers, not spark plug leads. We've proved that both triggers will "fire" coil B (still connected to cylinders 2 and 3). They are now out of time, because we are firing out of sync, but we've shown that both triggers will fire coil B.  8)
« Last Edit: April 22, 2015, 06:41:01 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #1047 on: April 22, 2015, 06:58:54 PM »
That's correct.  I didn't swap the spark plug leads; just the triggers.   As a matter of fact, I'll admit to a little cheat.  Rather than taking the time to actually unscrew the spark plugs, I took another spark plug I had and just popped the spark plug wire off the plug that was still in the hole.  Then, I'd connect it to the extra plug and use that to test the wire.  Saved me a bunch of times of unscrewing the #2 and #3 plugs...which are a pain in the wompus to take out.
« Reply #1048 on: April 22, 2015, 07:01:26 PM »
So hook up that spare coil and start that puppy!  ;)
TAMTF...
Wilbur
Projects:
Offline calj737
  • I refuse...
« Reply #1049 on: April 22, 2015, 07:13:35 PM »
Yup, you're dead right, as usual Wilbur. Thanks for pointing that out.
