SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
550 clutch grab issue
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 550 clutch grab issue (Read 949 times)
Tews19
I am no
Really Old Timer ...
on:
October 02, 2014, 07:59:26 AM »
I have been trying to use the search function but it is a little funky. No longer does it isolate the word or phrase and rather grabs every post with any word in it.
Anyways this is my issue. I thought I put the gears in wrong on my 550 but I have been able to figure out that is not the issue. My clutch seems to be fighting itself and me. I followed the procedure per manual. I loosened the 10 mm nut on the cover.
Then I lined up the marks on the arm and the clutch cover. When I do this there is no grab. If I move the arm marking way below the mark on the clutch cover I can get it in gear but then the neutral light is always on. The bike will get into gear immediately and have absolutely no power to it. I can't even make it up my driveway. It is as if it wants to stay in between gears?
Any ideas what to do?
Last Edit: October 02, 2014, 08:02:45 AM by Tews19
Logged
1970 Honda CB750 survivor.
calj737
I refuse...
Re: 550 clutch grab issue
Reply #1 on:
October 02, 2014, 08:21:28 AM »
Unless an expert comes along, sounds to me like your clutch springs have come undone. Did you properly torque them down? Sounds as if youre getting no engagement regardless of the gear shift position.
Logged
'74 550 Build
http://forums.sohc4.net/index.php?topic=126401.0
'73 500 Build
http://forums.sohc4.net/index.php?topic=132935.0
Tews19
I am no
Reply #2 on:
October 02, 2014, 11:38:13 AM »
Took a few pics. Everything looks normal. I will put in the spare clutch basket to see if that fixes it.
Logged
Tews19
I am no
Reply #3 on:
October 02, 2014, 12:55:29 PM »
If I pull in the clutch drop it into first. Once I let it up just a tad on the lever the bike moves forward. I did put in a different clutch basket and same issue.
What am I missing?
Logged
Tews19
I am no
Reply #4 on:
October 02, 2014, 03:44:46 PM »
I figured out the clutch issue. Now onto the head gasket.
Logged
bwaller
Reply #5 on:
October 02, 2014, 03:55:15 PM »
Well done. By the way, I never go by the marks and always adjust the screw with 1/4 turn of free play.
Last Edit: October 02, 2014, 03:57:53 PM by bwaller
Logged
calj737
I refuse...
Reply #6 on:
October 02, 2014, 04:17:42 PM »
So what was it?
Logged
'74 550 Build
'73 500 Build
Tews19
I am no
Reply #7 on:
October 02, 2014, 04:20:48 PM »
If you look at the top angle view of the clutch basket. It looks like a space in between the plates. The other basket had no gap. I installed that basket and relocated the cable itself. Simple and I feel like a dummy. But oh well. Took her around the neighborhood with the leaky head gasket. Back to full power.
Logged
calj737
I refuse...
Reply #8 on:
October 02, 2014, 04:24:24 PM »
I saw the gap in the pictures and was scratching my head, but had to deal with some other stuff... What caused that gap? We're the plates hung up on the fingers, or is that a 550 basket, or what?
Logged
'74 550 Build
'73 500 Build
Tews19
I am no
Reply #9 on:
October 02, 2014, 04:26:45 PM »
It's the metal plates between the plates. Which still has me curious cause I have another clutch basket and it is the same way as the first basket.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
