Author Topic: Honda dealer/factory tools  (Read 10776 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: October 03, 2014, 02:59:05 PM »
So towards the front of every Honda service manual there is a list of special tools. The front fork oil seal driving weight, for example. Or the valve seat cutter holder, rotor puller, valve spring compressor, etc. I know these can't have been widely distributed - maybe each dealer had a set? Were they ever available for consumers to purchase, and has anyone ever known someone who had one? Hondaman, maybe?
Wobbly
Re: Honda dealer/factory tools
« Reply #1 on: October 03, 2014, 04:07:37 PM »
Over the past 38 years, I had ordered some Honda shop tools just like any other part by using the part number. However, with most SOHC 4 parts not being available from Honda anymore, you might run into the same problem with the tools.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: October 03, 2014, 04:16:34 PM »
as wobbly said the shop tools were readily available to any mechanic that wanted to order.  My shop owner(Al Rifflard of Riff's Cycle Center) charged dealer cost for any tool a mechanic wanted to purchase.  As a flat rate mechanic I found it easier to own my own version rather than go looking for the shop tool.  The money spent for the tool was more than made up for in the time I did not waste.  Still have many of the tools I purchased....Larry
Offline grcamna2
« Reply #3 on: October 03, 2014, 04:27:06 PM »
There's (or was?) a Japanese tool company that sold/supplied lot's of oem dealer tools to dealerships and they're Kowa Seiki,I've been trying to find a timing light inductive pick-up lead wire for my KS timing light and I've googled it but to no avail.
The closest I've come to locating it was from old Subaru dealerships who used that model timing light a lot. There's another company named Kent Moore but I'm not sure if they're around.I'd sure like to know who sells oem tools now
Offline MoMo
« Reply #4 on: October 03, 2014, 04:34:31 PM »
Bill, the Kowa tire irons I bought 40 years ago are still straight as can be, quality tools they were...Larry
Offline Old Scrambler
« Reply #5 on: October 03, 2014, 04:43:08 PM »
I see a few on ebay or at swap-meets.............usually VERY expensive.  The most useful everyday tool for these bikes is a set of JIS screwdrivers and JIS tips for an impact-wrench.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline MoMo
« Reply #6 on: October 03, 2014, 05:00:22 PM »
I recently bought a Vessel impact screwdriver,  impact mechanism built into the handle, wish I had one 40 years ago...Larry
Offline grcamna2
« Reply #7 on: October 03, 2014, 05:52:32 PM »
Larry, Do you know if they're still making tools ?
Offline MoMo
« Reply #8 on: October 03, 2014, 06:18:27 PM »
No  idea but that was the company that made most of the Honda  tools....I last worked at a shop in 1986-Montgomeryville Cycle Center
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
« Reply #9 on: October 03, 2014, 06:56:38 PM »
« Last Edit: October 03, 2014, 07:00:12 PM by bowswell »
Offline grcamna2
« Reply #10 on: October 03, 2014, 06:58:12 PM »
I wonder where dealers get there factory tools from now?
Any current dealership techs. on here,or parts guys ?
The dealers who I use to order parts from had a halfway decent parts guy/girl on there sometimes who told me that they could order some tools for me,hesitantly... but they didn't know how/what to charge so a few of them(the ones I use to order more stuff from than the others) did ::) order a few things.I spoke to a K&L rep./salesman who would tell me their suppliers name...  I finally realized that it's kind of 'dealer only'  ::)  and tough for a private repair shop guy like me to get a hold of 'Dealer Only' factory tools but I was able to get a few here and there.
I sure like to have few $'s and go to a few swap meets to find some old tools,or just try to hear of when a Dealer closes up and try to see if any techs might sell some  ::)
Offline MoMo
« Reply #11 on: October 03, 2014, 07:12:25 PM »
This was one of the coolest dealer tools I got, not functioning though...Larry
Offline grcamna2
« Reply #12 on: October 03, 2014, 07:41:54 PM »
What components did you use to test w/ that Larry? is that from the early 60's ?
Offline MoMo
« Reply #13 on: October 03, 2014, 07:52:54 PM »
60s for sure..  Ohmmeter, voltmeter, plug tester, coil tester,  capacitor tester.  Yamaha had a similar tester-probably Honda did too.  Guess is the same company made all and relabeled for the manufacturer.  They really worked well, especially for testing plugs and coils. Somehow the fuse circuitry was ripped out of this unit.  Someday I may put it up on Ebay to see if it brings some money...Larry
Offline eastyork1977
  • Tuning and building in the Great White North
« Reply #14 on: October 04, 2014, 07:31:15 AM »
So I bought a whole bunch of Honda KOWA tool from an old 60s dealer. Happy to put up some pics for you guys but only if you guys are seriously looking.
Two cases of general tools and there is also a case of GL specific tools as well.
Again for serious enquires only, I will get a post going if there is interest so let me know.
Cheers
'73 CB350G
'75 CB400F
'77 CB550K3 "Swayze"
'78 CB550K Stock
'78 CB750F2 Stock-ish
"take a peak." - Don Cherry
"If I can bounce a wrench off a tyre and it hits you, you're standing too close."
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #15 on: October 04, 2014, 09:27:29 AM »
I have the Honda Kowa electronic tester from around 1968-69.  Works fine...plastic shields on the meters are pretty crappy, but the tool works and I have all the accessory wire connectors and timing light.  The only tool I've ever owned that accurately told if a coil was good or not.  If there's a photo or two that would help you figure out how to McGiver the parts you're missing, let me know and I'll try my best to be a photographer.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline MoMo
« Reply #16 on: October 04, 2014, 03:16:35 PM »
All the fuse stuff is missing.  someone must have taken the top off and removed the fuse holder and wiring..  You'd have to take yours apart to photograph,  too much trouble so don't bother...Larry
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #17 on: October 05, 2014, 07:50:58 AM »
eastyork1977,
I sent you a PM yesterday regarding some of the tools you might have.
I also saw a thread this morning about the PM system having a problem, so I was wondering if you got my PM?
Thanks,
Charlie
« Reply #18 on: October 07, 2014, 08:48:35 AM »
Got the PMs thanks, system is wonky today and I can't reply.
Pics are up as promised.
http://seventeescycles.imgur.com/
Let me know which lot you're after or specifics. You can use descriptions or image links.
This email is best to get right to me. I sometimes take about 1 day to respond as I'm often in the shop. Got three bikes on the go right now.
70scycles@gmail.com
'73 CB350G
'75 CB400F
'78 CB550K Stock
Offline oldfart
    • The Motorcycle Project
« Reply #19 on: October 07, 2014, 10:31:31 AM »
Kowa was indeed the special tool manufacturer for Honda and at different times Kawasaki as well.  You can still get Kawasaki Kowa tools, but not Honda, for some time now.  Kowa U.S. was purchased by Snap-On about four years ago and dissolved into the company (read put out of business).  I have written a few articles about this.  I talked to someone at Kowa in Japan last year.  They are still a going concern, but they do not plan on selling in the U.S. again, and they have pretty much by now made the transition to automotive only, a huge market in Japan, apparently.  See my articles on this at motocycleptoject.com.
Honda dropped Kowa switched to a U.S. manufacturer whose name was three letters, don't remember but it was somthing like TLK.  Anyway, the tools were no where near as good.  The bad news is Kowa is no more in the U.S.  The good news is, for necessary things like bearing retainer tools and special castlated nut (clutch, steering, swingarm) sockets, U.S. aftermarket companies have sprung up to fill this need.  Do a part number search using the correct factory part number for the tool on eBay.  You will be surprised at what you find.  Occasionally someone will have the original tool, but more often, a domestic supplier exists who is reproducing them.  I just purchased a swingarm nut socket for my CBX and it is a better tool than the Honda one could ever have been.
http://www.motorcycleproject.com/motorcycle/text/kowa_tools.html
http://www.motorcycleproject.com/motorcycle/text/tricktools.html
http://www.motorcycleproject.com/motorcycle/text/tools12.html
http://www.gwcbg.org/~gwcbg/index.php?option=com_phocadownload&view=category&download=1%3Agl100-service&id=1%3Agl1000&Itemid=456&lang=en
« Last Edit: October 07, 2014, 10:39:09 AM by oldfart »
Mike Nixon
Why is there never enough time to do it right, but always enough time to do it over?
Offline grcamna2
« Reply #20 on: October 07, 2014, 11:01:01 AM »
Thanks for this post oldfart,I needed to know why nothing comes up on Google searches for me... I sure would like to find a new inductive pick-up/lead wire for my Nice Kowa Seiki compact timing light. Do you know of any Automotive places that I might try that could still possibly sell me this replacement parts ? I've tried Ebay also and it's no picnic getting my hopes up...
Offline oldfart
« Reply #21 on: October 07, 2014, 11:32:23 AM »
Well, inductive clamps are available different places, but I rather think the setup on the Kowa timing light was pretty special, being completely self-powered.  (That timing light, being self-powered, was a rare bird in its time, but I have since seen other ones).  Don't know if that would affect the clamp or not, it seems a pretty standard part.  Fox Valley, Snap-On, etc.
Mike Nixon
Offline grcamna2
« Reply #22 on: October 07, 2014, 11:41:24 AM »
Do you think a Snap-on saleman in a truck would help me ?
Offline fmctm1sw
« Reply #23 on: October 07, 2014, 01:42:17 PM »
That's what I wondered one day.  Can you just run those guys down and buy tools out of the trucks?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Rocky2010
  • Live in Strayla
« Reply #24 on: October 07, 2014, 04:21:44 PM »
In the day I purchased a pair of factory piston ring compressors which are the same as the ones in the manual also some T-bar spanners from a company which was called Bennett & Woods in Australia but they are no longer in business these days that is the extent of my genuine factory tools
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
