Bike is a CB750k1. On a previous thread I spoke about on one of the bikes first rides after rebuild I went 9 miles down the road then stopped the bike for a while to get it inspected at the rego department. On the way home the bike started playing up, almost like it was starving for fuel at about 50 m/hr. Twist the wrist a bit and it sprang to life and then held it constant ant it spluttered and slowed until gave it another twist. Stopped at the lights a few mile down the road and then it didn't do it again. I couldn't find filters that would fit on the fuel lines but tank has been coated inside, new petcock and new Carty kits throughout. Doesn't play up at any other time.
Went to the show and shine today. Didn't play up at all on the way there other than the new neutral switch failing which is in another thread. Sat the bike for a few hours. Won the trophy for best Jap bike
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
and then on the way home exactly the same Symons again, feels almost like starving for fuel until you give the wrist a twist. Only does it around that 50m/hr range.
Do the fuel tanks get air locked or like vacuum problems? I have new tank cap and latch fitted.
Can it be air screws or is that only for idle?
Really not sure what problem could be. I have done the clear tube method with the bowls. I have no leaks, all new gaskets, o rings and brass wear.
Anything I should be looking for hear, bike has done a total of 41 mile after rebuild and is running great except for this one issue, the neutral light and front squealing brake.
