Well, got the carbs off, finally, using the ratchet strap method, different to say the least.
Guess you can't reuse the float bowl o-rings, couldn't get those back in.
Carbs are back on, battery charged, dash lights bright, but hit the starter button, and get click, dash lights go dim for a moment, then come bright again.
Click is coming from the starter relay, and when jumped over from post to post, just minimum sparks.
If it ain't one thing , it's another........
