Author Topic: Show me your 350/400F, Little F'ers thread? Small blocks Project status reports  (Read 51627 times)
Online Don R
Re: Show me your 350/400F, Little F'ers thread? Small blocks?
« Reply #125 on: June 02, 2015, 10:43:45 PM »
I'm not sure why but they make me smile, I gotta buy back the one down the street too, it's really nice.
Offline ivanhoew
« Reply #126 on: June 03, 2015, 12:07:54 AM »
some smokey old pics of my one , and the graph ..built in 1980 .still have it ,last ridden in 2002.
just do it .
Offline redlabel
  • Honda CB400f F0
    • brunsame
Offline straat-toe
  • Everybody knows about the bird.
« Reply #128 on: June 03, 2015, 02:34:43 AM »
Here's mine!
 Uuugly. Busy restoring/modifying it for the last 2 years already. Starting to make some progress now.
  http://forums.sohc4.net/index.php/topic,117861.0.html
No School, No Job, No Worries.
Offline straat-toe
« Reply #129 on: June 03, 2015, 03:33:13 AM »
TURBO!
Offline redlabel
  • Honda CB400f F0
    • brunsame
« Reply #130 on: June 03, 2015, 05:24:55 AM »
AH now I see! :)
    • http://forums.sohc4.net/index.php?PHPSESSID=f2qr807u0fnfh7dukbo4vpude3&/topic,60973.0.html
« Reply #131 on: June 03, 2015, 07:06:37 AM »
hov can you hold the rods inside the engine?? have you balanced pistons to get a perfekt balance.
..all old stories said at over 9000 rpm it split the engine after a short time..
Offline ivanhoew
« Reply #132 on: June 03, 2015, 07:31:20 AM »
strynboen,
totally ignorant of that fact , i used to rev it to 13k all the time , especially when i first built it and had boost coming in at 7200.. its better now with boost at 5200 rpm.
rods were fine , top piston rings used to go , but with the yosh big bore it was fine . for the last 10k miles.
robert.
just do it .
« Reply #133 on: June 03, 2015, 12:56:13 PM »
in Volvo dt 42 tractor turbo engines the pistons have a cast iron" sleve" cast in the piston holding the top ring,,?is that the vord..for the top ring..so it not veared the groove for the ring..it vas most the pistov veared aut..so the ring got slack and broke.the piston ring vas strong..but the alu piston cut not hold it in posision..have not seen it on mc..engines..but bigger rings/pistons are stronger and have more meat..it make good sense..
« Last Edit: June 03, 2015, 12:58:17 PM by strynboen »
Offline ivanhoew
« Reply #134 on: June 03, 2015, 01:33:25 PM »
i think it was more the fact that ,due to needle jet flow i was running out of fuel at the high rpm .. and so it was lean , overheated the pistons , then the rings grew and butted up ,and then fractured  ,then worked their way up past the piston and went out of the exhaust !
it had a power limit of 60 bhp due to fuel flow limits .... so i fed fuel to the throat with a pipe off the float chamber drain , and power went to 85 bhp in the end , that was when the clutch gave up and span as if it was in neutral.
with the 60 bhp run , pk power was at 11000rpm.following the power band up with the higher boost , i deduce that with the 15 psi ,and the extra fuel ,it would have been around 100 bhp if the clutch had gripped.
 engine also had a drastically ported head , stock valves ,and a yoshi big bore kit ... i think it was 450cc , but it may have been bigger .cam was stock .but retarded. cr was 8.5:1.
robert.
just do it .
Online Don R
« Reply #135 on: June 03, 2015, 03:41:19 PM »
I had a Lectron carb that had the high speed jet fed from the float bowl. We ran it on methanol on our jr dragster. We were guessing 25 hp.
Offline kap384@telus.net
« Reply #136 on: June 03, 2015, 05:03:21 PM »
Here's a video of mine after baffle blew out.  Garage work on hold as i fractured my tibial plateau dirt biking and am off my leg for 6 weeks.  Links to projects in sig.
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Online Don R
« Reply #137 on: June 03, 2015, 08:14:57 PM »
 Mine needs rims and spokes, does anyone have a favorite source? I wouldn't mind aluminum rims.
Online Don R
« Reply #138 on: June 03, 2015, 09:14:07 PM »
 This little beauty is being rebuilt for someone else to love, sun rims would get me close to 1K for tires and rims. This one's on a budget but it does have to be nice. I'm getting a price on chrome DID's and stock type spokes, I would like to go slightly wider on both rims but stock will do on this one.
Online Don R
« Reply #139 on: June 18, 2015, 02:18:37 PM »
 The DID's are still on the way from Japan, the seller offered to pay shipping if I bought all the things I'd inquired about. I ordered a red seat foam and gaiters for my Sandcast too.
 What's everyone's favorite aftermarket shock for the 400F? These are rusty, they might polish up but I'd prefer to improve the shocks, it's like the rims, better is better than best in this case.
Online Don R
« Reply #140 on: June 18, 2015, 03:09:49 PM »
 It seems like shocks are $80, $280, $500 or $700. I was hoping to find some decent ones around $200, it appears the $185 plus $85 for springs progressives might be closest to my budget. The worrisome part is some of them list them as fitting a GL1000 too, really?
Offline MoMo
  • Ride like you're invisible
« Reply #141 on: June 18, 2015, 04:03:59 PM »
Hagons Don...Larry
Online Don R
« Reply #142 on: June 25, 2015, 07:54:57 PM »
 Fresh from Japan, new rims and spokes for the cb400F. I can't wait to take a bolt cutter to the old spokes.
Offline geigeb
« Reply #143 on: June 28, 2015, 07:27:45 AM »
Circsa 2011
Online Don R
« Reply #144 on: September 10, 2015, 02:57:15 AM »
   I bought the yellow one back, the neighbor is buying a house and needed the down payment. The best part is my wife is his realtor. Win/win He rode it all summer for $300 and so far I've made $1300 buying and selling it.
  I almost sold it again at the swap meet but the buyer found a 350 silver cafe all finished and bought that instead.
« Last Edit: September 10, 2015, 03:31:46 AM by Don R »
Offline Vestjyden
« Reply #145 on: September 15, 2015, 01:35:10 AM »
My CB350F 1975 from Denmark  8)
1975 Honda CB350F
Online Don R
« Reply #146 on: September 16, 2015, 06:56:31 AM »
 Nice ride, thanks for sharing the pictures,
« Reply #147 on: September 16, 2015, 12:59:37 PM »
biggest brat seat,, 8) im ever seeen...nice to have some more danes inn..
Offline knowsnothing
« Reply #148 on: September 17, 2015, 08:16:19 AM »
My CB375F  ;D  Desperately needs paint.
1978 CB750k Blue - for sale
Online Don R
« Reply #149 on: September 17, 2015, 09:18:56 AM »
 I'm a fan of  a little patina. Of course it's all personal taste. I had good luck pulling dents with the hot glue kit. if the glue is good enough it doesn't harm the paint.
 Is there rhyme or reason to which 400F's came with paint matching side covers and which ones were black?
