Author Topic: CB 750 K2 exhaust muffler problems  (Read 722 times)
Offline total_70
« on: October 21, 2014, 02:49:14 PM »
Hi,
I'm trying to fit new exhaust mufflers to CB 750 K2. On right side they fitted well, left side not. The upper and lower muffler holes are not on same line and pillion bolt does not go to the hole when mufflers are connected from the end with that rubber thing. The upper mufflers hole is about 2mm upper than lower one's.
I'm wondering what can cause this? The mufflers are new originals as far as i know..
Only thing i can think for solution is to take off some metal from the tubes inside the rubber thing with angle grinder..but i would not like to do that to new mufflers.
Has anyone any ideas about that issue?
-tommi
