Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
if the bikes been sitting as you say a few decent rides should see the compression come up,use the same guage as that's your baseline.
Quote from: dave500 on October 23, 2014, 12:14:44 AMif the bikes been sitting as you say a few decent rides should see the compression come up,use the same guage as that's your baseline.^^^ That. Very likely you will be happy with it after you put some miles on it.
two pumps from a smll oil can, 2 to 3 cc
