Author Topic: 1973 CB750 Four K3 -- Project "Terry's Fault" -- BUILD RESUMED  (Read 60495 times)
0 Members and 16 Guests are viewing this topic.
Offline edwardmorris
  • Youngish
Re: 1973 CB750 Four K3 -- Project "Terry's Fault" -- TEAR DOWN
« Reply #125 on: March 28, 2015, 03:54:49 pm »
Got some work done, managed to squeeze the crank in my puny 4" bench vise  ;D to get the dynamo rotor off. Gordon's tool made quick work of it. Pic 3 is for Ravie, that's where the seal goes (if you're still following this build).
  • Youngish
« Reply #126 on: March 28, 2015, 03:58:50 pm »
Taped and cut off the section for installing the new Gordon's Frame Kit.
Drilled the "quiet memo" holes and once again behold! there was a flood. A lot of it fell off on the floor by the time I ran back inside to grab the camera, but you get the idea. If you haven't yet, I'd recommend you check for the presence of these critical drain holes as your frame may be full of water and other crud, decaying away from the insides. Last time I did this, I left it over night to settle and there was still some left, then I toasted it with a propane garage heater. Will let this one dry out for 24hrs, shake it down, toast it the same way and do the Eastwood internal treatment.
  • Youngish
« Reply #127 on: March 28, 2015, 04:00:18 pm »
Drove out the old lower steering bearing race, what a PITA.
Sprayed the sprocket carrier clean, turns out its chromed as well, but I just don't feel like dealing with that retainer. Anyone want to trade a shiny one for a regular  :P?
« Reply #128 on: March 28, 2015, 07:27:29 pm »
What is this "silent memo" stuff you keep talking about?  Guess I missed that one...I would trade for that sprocket carrier if you have chromed hub and brake panel too.  Hell, I am thinking about about trading anyway.
  • Youngish
« Reply #129 on: March 29, 2015, 01:21:15 am »
both hubs are chromed, the brake panel completely lost its chrome though.
The quiet memo is a hondaman info gem, i'l dig up the thread and post here. Long story short, factory rush, missed making critical vent and drain holes in frames, bad schit hapened.
  • Youngish
« Reply #130 on: March 29, 2015, 01:23:35 am »
Goodies from Marcel had arrived by the time I got home, too excited so I freaking finished the gauges  :o I better get some sleep...
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #131 on: March 29, 2015, 05:17:53 am »
Found it!
Those holes are the upper "breather" holes for the lower frame. The other "end" of those holes should be down by the bottom front engine bolsters, on the bottom of the frame. They often get clogged up with rust flakes.
Like Momo said, "tap testing" is a good way to check for thin spots, or put some rubber in the jaws of slip-joint pliers and firmly (not HARD) squeeze the frame along the runs to see if it crushes. The worst spots on the 750 frame are at the bottom of those engine bolsters, if they were painted or crudded shut. The frames are easy to fix, I've done several myself.
On the 1970-71 K1, many of the lower holes were forgotten in production (even some K2 bikes were this way, before it was over). There was a "quiet" service memo sent out to have dealers watch to see if the holes were missing at the lower bolsters, and the instructions were to drill a 7/32" (3mm) hole behind each one, if not present. More than one of the ones I did had water come out during this 'mod'. I usually took an oil squirt can and squirted a bunch of oil into the holes you show, until it oozed out the [new] bottom ones, hoping to extend the frame life. Now, when I have frames out of bikes, I spray CRC into the holes until it RUNS out of the lower ones, then turn the frame over and do it the other way. That will stop any rust, almost forever, right where it is.
--Evan
1975 CB750K "Rhonda"
Offline Bill/BentON Racing
    • BentON Racing
« Reply #132 on: March 29, 2015, 06:16:06 am »
Rafi, I've got some sprocket carriers if interested, Bill
BentON Racing Website
BentON Racing Facebook
« Reply #133 on: December 03, 2015, 08:47:34 am »
Woohoo. I have it on good information that this project and thread is being resurrected into active status.
« Reply #134 on: December 03, 2015, 02:46:17 pm »
Pics or it aint happening!
  • Youngish
« Reply #135 on: December 03, 2015, 04:04:31 pm »
Haha, thanks for the bump Don. Yes, its winter and there are bound to be some days I'm stuck at home because of snow and will be needing to do some wrenching to keep busy ;D No pix of any major progress yet Stev-o but I do have some to report. Early this year, the K2 and K3 builds were running in parallel until it warmed up and I was totally focused on the K2. Got that done, dialed it in, and just kept logging miles as I made time.
So last when we left off, I had the frame out at the welder's for installing the GFK. After cutting the frame, I did my usual Eastwood Internal Frame coating, drilled out the missing "quiet memo" holes, cut off the nasty welded on foot pegs and grab rail mounts. Frame is back with the kit installed and ready for PC.
Swingarm went to Mark/Hondaman and has returned with a new life. From the pix earlier in the thread, you can tell the swingarm collar was toast, so Mark made me a custom one matched up to the newly installed bushings, good stuff! Also ready for PC.
I had the center stand shortened for the K3 too, but as I learned during the K2 assembly, this simply doesn't work for the 18" rear wheels. So, I now have two shortened center stands, one PC'd and one bare that I can't use. These may work well for those who go with 17" or 16" (what the K3 came with) rears, so PM me if you need one of them. Another center stand has been added to my list for Santa!
Kick stand has been elongated just a little. This has worked out really well on the K2 (eventhough I do have the stock size one for it), so I'm keeping it elongated for the K3 as well.
Most of the missing bits came from Billy B some time in March, but I can't find them for the life of me. I've gotta clean up shop box by box as I'm missing many critical bits.
Found me a good sprocket carrier for like $9 on ebay, total fluke.
Engine obviously is all blasted and stripped, but needs a compulsive clean. The K3 head has small fin damage that I couldn't find any local guys to fix. A replacement K3 head is on its way from Billy and this one is going to Mark/Hondaman for one of his builds.
Right now, I'm just boxing up stuff to get to the powder coaters, hoping to save some $$ off-season.
The one thing that worries me a little about this build (even more so now after the K2 BOTY win) is that it is going to disappoint many. It isn't even in the same galaxy as a stock build, but its not going to be cafe/chop/punk. I'd call it a pro-stock build as it will retain some of the stock look with beefed up internals. I wanted to build this to be purely my own, and its based on one of my fav vid game beasts (I know, super lame). I almost got booed off of here when someone mistook a gold shine to be rust on the K2  . When they see this one I fear the worst :P :P
« Reply #136 on: December 03, 2015, 06:15:01 pm »
Not every build needs to be at a concourse level or even close. Just build what you like. We will still be here.
  • Youngish
« Reply #137 on: December 03, 2015, 06:57:12 pm »
Haha, thanks Don! On that note, any tips on cutting up the front fender? I'm going for a smaller arc than stock...
« Reply #138 on: December 03, 2015, 11:17:12 pm »
Good to see this thread "back on the road" Rafi, keep up the good work, and enjoy your build. Cheers, Terry. ;D
« Reply #139 on: December 04, 2015, 08:46:25 am »
Use a masking (painter's) tape on the cutting area and draw/pen out your arc.  Use a new cutting wheel and go at it.
  • Youngish
« Reply #140 on: December 04, 2015, 09:36:48 pm »
Thanks Don, I can't find my angle grinder. I think the wife hid it because she thinks its a flame thrower that will burn down the garage  :o:o ;D . I did some digging to see if I could use a hacksaw and found this
http://forums.sohc4.net/index.php/topic,91026.msg1017788.html#msg1017788   (Cool shot of Phaedrus 1).
So I did that, then marked the rounded ends using the cut-offs, then free-hand dremel cut. Came out OK I think, need to go over to the in-laws over the weekend to grind it down smooth.
Took the forks to the local auto shop and borrowed their 3/8" air impact with and allen style socket to knock loose the bottom bolts. Took them apart at home and found there wasn't a copper crush washer on either of the bolts, but the drain bolts on the side did have them. Whatever drained out of there wasn't oil, and stunk like sewage. Took off the circlips and put the lowers through the parts washer (ahhh! that sweet smell of simple green  ;D ;D) then rinsed them off with hot water. Left them in the hot water for a while then removed the seals fairly easily. The sealing surface looks ok, so these are good to go. Will need new tubes though.
Everything is ready to go to the powder shop, but I'm missing a center stand. Hopefully Bill can get it out soon :) Will be attempting to remove the cylinder-case studs over the weekend, have them soaking in penetrating oil for now. Gave them all a good tap on the head, will do the usual double nut with vice-grip at the bottom and heat.
Offline tweakin
  • tear down
« Reply #141 on: December 05, 2015, 05:57:53 am »
Build the bike for yourself not to please the forum and you cant go wrong.  Looking forward to following along.
  • Youngish
« Reply #142 on: December 05, 2015, 02:07:32 pm »
Haha, thanks Tige. (I'm just kidding btw if anyone missed it ;)) This will be more like one of yours or Branden's 836s minus the high-end stuff (CRs/Motogp/BackcutTrans..etc.). I know its been a while Tige, but your pointers on the LED back-lit gauges were awesome! They turned out just like I wanted them! All that is left on them is to solder up some old school connectors to wire them up with the harness.
Haven't done much yet today except for clean up the garage a little to reclaims some workspace. Ended up with yet another bag of Honda part wrappers that fell through the cracks during the K2 assembly :o These things just have wayyy too many bits and bobs  ;D
  • Youngish
« Reply #143 on: December 08, 2015, 08:11:22 pm »
Got the studs out last night but couldn't post pix. Pretty much all survivors except for the outer front two exposed to the elements. Those were corroded and bent a little when twisting loose. Thankfully no harm to the gasket area anywhere except for the stinky mess PB blaster made. Time to clean clean clean it all up and prep for PC. Replacement head should be here any day now.
Offline calj737
  • I refuse...
« Reply #144 on: December 08, 2015, 08:20:53 pm »
if you are having it powder coated, it doesn't really need to be that clean. A pro will prep it well beforehand.
  • Youngish
« Reply #145 on: December 08, 2015, 08:24:26 pm »
I am that "pro" for this one, I'm doing all the initial cleaning and taping/masking as I don't trust anyone but Bob (main guy a the shop) doing it. He's too busy but told me he'd let me use his supplies, then review it after I brought it back masked up. I sorta insisted he does the engine himself. The rest of it, I trust his staff, they did ok with the K2 except for butchering the VIN plate for which Bob has apologized and expressed regret.
  • Youngish
« Reply #146 on: December 11, 2015, 03:41:14 pm »
Hoping to get more stuff done and prepped this weekend, but lets get another discussion out of the way shall we? ;)
Engine: I no longer have the patience to re-plate all hardware nor the money to replace it with all NOS stuff. Any cause for concern going all stainless throughout? I know that the super long 120mm and 140mm main bearing ones will not be easy to find but I plan on using APE HD main bearing studs anyway so not an issue. Rest of the sizes seem readily available. Two minor concerns I can think of are slimmer nuts (like front suspension) and small OD washers (OE ones have two part numbers for 8mm bolt washers).
Good news with the main bearing studs is that the newest batch from APE are a few mm longer so the issue of them being a little short is addressed. However I haven't yet received confirmation of the same issue being resolved for the cylinder studs. Anyone have any trouble in recent times with the HD cyl studs being too short?
« Reply #147 on: December 11, 2015, 04:27:12 pm »
I typically use ss hardware when replacing old hardware.  I see it as an upgrade.
Unless your rebuilding a NOS bike, which I havent.
Offline Restoration Fan
  • My wife will never call me
« Reply #148 on: December 11, 2015, 05:55:29 pm »
Oh boy.  SO very in for this one.
Looking forward to it, Edward.
One piece of advice that slightly echos what others have said.  Don't worry about a concourse level restoration, or even a BOTM candidate restoration.  Every one of us rejoices when a single one of these old SOHC's is put back on the road again.
  • Youngish
« Reply #149 on: December 11, 2015, 10:04:34 pm »
Thanks Stev-o. Ron, yes this is going to be mine, something that won't need a lot of upkeep and is more fun. lol its early enough, lower your expectations on this one now, folks  :P
OK, so some searching around and looks like SS in Alloy is quite the debate, one even spun into a torquing technique debate  :o SS it is, gotta dig out my hardware sheet. No luck on the studs concern though  :(
Goodies from Bill arrived, was waiting on the center stand to get the frame+h/w sent off to PC. The replacement head is here, cleaned out some casting flash between the fins (very little on the early ones). Gotta do the same for the cylinders and wrap it up. Going through my list, bearing removal is next, not fun but needs to be done :(. Lesters are getting coated too!
