Author Topic: 1973 CB750 Four K3 -- Project "Terry's Fault" -- BUILD RESUMED  (Read 65309 times)
Offline edwardmorris
  • Youngish
Re: 1973 CB750 Four K3 -- Project "Terry's Fault" -- RECONDITIONING
« Reply #225 on: January 17, 2016, 08:22:15 PM »
Question: Are there any bolt on aftermarket options for the clutch and brake levers?
You mean just the levers themselves or the whole assemblies?
Just the levers that fit into existing MC and LHS controls. I'll admit I haven't done much searching on the topic yet, was hoping someone knows.
  • Youngish
« Reply #226 on: January 17, 2016, 08:25:12 PM »
Yes, but why would you want them? "Dog leg" style was popular back in the day...
http://www.ebay.com/itm/HONDA-CB-Vintage-GP-Dog-Leg-Clutch-Lever-BLACK-ball-CB750-CB-550-450-400-7mm-/231624902985?hash=item35edeb8949:g:bTUAAOSwHnFVsl-Z&vxp=mtr
Wow that was fast, want a set in chrome and found this based on your link
http://www.ebay.com/itm/Honda-Chrome-Lever-Set-CB450-69-78-CB750-75-76-CB750F-75-77-GL1000-NEW-/331700531545?hash=item4d3ae47159:m:m-9ddlINHUhCFSFIC7jqXGg&vxp=mtr
Really not feeling like polishing anything this time around/plain lazy so the chrome set will do. Are they any good though?
« Reply #227 on: January 17, 2016, 08:30:09 PM »
I've never had dog legs, I prefer polished stock. But they supposedly help someone that has small hands or make it easier to pull in on a bike with a heavy clutch.
  • Youngish
« Reply #228 on: January 17, 2016, 08:58:44 PM »
I do love the look of the ones I polished for the K2, but I just don't like keeping it up. Chrome is a good lazy option ;D I can live with the dog leg style, I've got big hands but it doesn't bother me. I'm thinking these with the highest rise renthals with bar ends and progrip two color grips should do it.
  • Youngish
« Reply #229 on: January 19, 2016, 09:26:00 PM »
Final bits for the PC shop almost ready, still gotta mask up the tappet cover threads and crank drain cap threads. One final wipe down with acetone, then drop off.
The finned cap for the dip stick came in, looks half decent polished, but not quite as good a finish though.
  • Youngish
« Reply #230 on: January 21, 2016, 09:12:33 PM »
So the seat pan is saved, got new foam via a coupon email from z1 too. Gotta find me my electric carver and get choppin soon. Need to find some edge liner first too.
  • Youngish
« Reply #231 on: January 22, 2016, 09:10:17 PM »
Found my electric carving knife, so I had at it. I practiced on the original foam that was on the pan, not sure what quality it is but it was very soft and I could free hand shape it like hot knife through butter. The z1 repop foam is a different animal, MUCH firmer. I know nothing about this stuff so I can't say if firmer is necessarily better or worse. It took some force to get the knife to bite and cut through, which meant imperfect cuts. I slowed down and left plenty of cushion to manually scrape later. Despite that, ended up with two small spots that were cut a few mm deeper than I wanted, so I glued back some thin strips and shaved them off to level again. Starting to look like what I want it be but has more work to be done.
I'm having no luck finding the proper sized edge trim. Most places only have fat ugly car door crap that's useless for this. Any suggestions?
Offline rddcw
« Reply #232 on: January 23, 2016, 04:36:15 AM »
http://www.ebay.com/itm/120934462094?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Not sue if this is what your looking for ?
Also HVCcyle has some too.
« Reply #233 on: January 23, 2016, 10:14:49 PM »
I used one of these on a seat recently. It looks OK. It's not quite wide enough (for "purist" rebuilders like me!?), but it does a nice job of accenting the seat line. :) I'll use it again on the K4 when I get to it.
Where did the foam come from, EM? I need one for the K4, and maybe for my own butt, too....
« Last Edit: January 23, 2016, 10:16:56 PM by HondaMan »
  • Youngish
« Reply #234 on: January 24, 2016, 09:55:43 AM »
@rddcw: Thanks, but that's the trim that goes OVER the final cover. I'm looking for one much thinner that goes on the pan edges to keep it from knifing through the foam and cover. I do not have plans for using an outer one for this seat (even the gas tank isn't getting those trims).
@Mark, the foam is form Z1
http://z1parts.net/seat-foam-honda-cb750-k2-k3-k4-k5-k6-1972-1976/
Its pretty tough, almost comparable to the NOS stocker on my K2. I happen to be on their mailing list and bought it using a coupon for 15% off or something like that. Had the same luck when buying new fork tubes too, very good site ;)
  • Youngish
« Reply #235 on: January 26, 2016, 04:12:00 PM »
Picked up the final bits from the coaters'. Somehow I had forgotten the cam chain tensioner cover, so still have to make one more trip to grab that. Trivial amount of touch up is needed on the valve train cover as seen in Pic 2. Better that, than having to chase out powder from them pesky threads. Finned oil cap for the added 1.5HP with extra oil cooling and better thigh burn patterns  :P :P :P
I tore up the seat that came on this K3 and dropped of the seat pan today. Will save it for a future build or something. Still have the chrome set of covers collecting dust, so if someone wants them, PM me please. No dyno and clutch covers though, rest are all there.
Need to get back to finishing up the seat, current hold up is a custom order Luimoto Gold Gel pad kit (coming from Vancouver I think) and edge protector. I may just end up saving the old one as I'm not having any luck finding one that will crimp/bite on to the bare pan well enough.
  • Youngish
« Reply #236 on: January 27, 2016, 09:30:16 PM »
Broke down and bought a bearing race and seal driver kit. No caveman approach with precious Lesters ;D What a breeze! No heat gun, no nonsense. Quick and clean test install. I'll have to find and clean up the spacers for the Lesters before I can install the new SKFs on them. So went back to the seat for a bit, smoothed out the sharp corners and sanded it level. There is still a very small depression on the pillion side that needs filling, or alternatively cutting down the seat some more. I will just level it flush with a thin foam sheet. The rider side is pretty flat and the teeny depression there will go away when I make the cut out for the gel insert (I know, need to account for it when measuring the cutout).
  • Youngish
« Reply #237 on: January 29, 2016, 11:23:33 PM »
Custom order Gold Gel Kit from Luimoto arrived today! Quick test on a chair, this thing is comfy! The final lining foam is what was a pain in their kits, the 750 seat needed different dimensions.
  • Youngish
« Reply #238 on: January 29, 2016, 11:28:28 PM »
Marked and cut the gel pad to fit, then cut up the area in a grid to peel off small squares. Their instructional video is excellent. I don't have a razor blade scraper and had to improvise, not perfect seating surface but its leveled right for the gel pad. I sanded it down to smooth it some more and make the pad sit a hair lower. This way when the foam around it gets compressed when pulling over the liner and cover, the gel pad won't stick out. The pad is adhesive backed but the foam isn't. Need some final finishing touches to ensure nice and flat surfaces on both sides, then finish it up. Found a local guy who does motorcycle seat work, will have a cover made through him.
  • Youngish
« Reply #239 on: January 30, 2016, 11:57:44 PM »
Well, I got the seat as far as I could take it. Time to let a pro do the final top cover. After much back and forth, I decided to shave down a few more mm for the gel insert and add a layer of thin foam below it for added cradling. I guess I've been reading too much ;D Anyway, love the adhesive backed gel pad, super easy clean install. Gluing the foam to the pan is what was messy, damn spray glue >:( I bought the 74 which is supposed to be the tough bonding with fast curing kind, and boy they aren't kidding! Had very little time to line things up and only at this point is where I realized that the Z1 foam is not 100% perfect. But hey, this was way better than starting from scratch. Installed you can't tell where the issues are, but they're annoying during assembly. After the pan went on, checked for flatness for the umpteenth time, then misted the foam with the spray glue and added the gold gel foam liner. Have to cut off some excess and clean up the nose a bit, then I'll be dropping it off at MTZ Customs for the cover.
I was thinking about doing the cover myself too, but the missus won't let me anywhere near her sewing machine.  Sharing the Singer Mineral Oil is about all I can do  ;D ;D Anyone know of a good source for buying heat stamped pleated vinyl?
Offline Restoration Fan
  • My wife will never call me
« Reply #240 on: January 31, 2016, 04:28:44 AM »
Rafi,
That's going to be the most thoroughly engineered seat ever on a SOHC.  Well done, my man.
Maybe you can market it?  The Buttmaster 2000 perhaps?  :D
« Reply #241 on: January 31, 2016, 07:53:44 AM »
Rafi,
+1!  Curious to why, though?   Do you find the stock seat that uncomfortable, Candyass?! (As my Dad use to say.....ha!)
« Reply #242 on: January 31, 2016, 08:18:34 AM »
LOL! Or, Powder-puff Panties as they say where I live  ;D ;D ;D
Haven't heard that one but like it!
  • Youngish
« Reply #243 on: January 31, 2016, 12:11:46 PM »
Yea, the stock one on my K2 isn't too comfortable for extended riding. The Z1 foam is tougher still. This only gets worse for me because I have a bad disc and chronic lower back issues.  I'm not getting any younger and at my age, I need all the bum support I can get  :P  :P
I do have a second seat pan that is at the PC shop right now, so if someone really wants me to, I can possibly make another provided the supplies are taken care of. The Buttmaster 2000 sounds familiar, wasn't that a toilet bowl cushion? ;D ;D
  • Youngish
« Reply #244 on: February 01, 2016, 07:20:12 PM »
Seat rubbers cleaned up nicely, although I may look around for better ones later depending on budget. Lesters got new SKFs today, once again, installation was a breeze thanks to the proper tool. I did realize however, that the snap ring retainer for the rear hub is missing. I can't remember exactly but I think I destroyed it on removal. Gotta go resurrect that Lester thread to ask for replacement info. Need a good tax return this year, them Lesters need some Roadriders  8)
Also noticed that the brake drum meat is not integrated like the stock hubs, so possibly replaceable if too worn out? I do intend to get the drum cut and trued now that the bearings are in. Thoughts?
  • Youngish
« Reply #245 on: February 06, 2016, 01:45:07 PM »
Quick Op. Poll: Against the black magic powder, what would look better?
Yellow chromate (high contrast) or
Clear/Blue (subtle contrast)
« Reply #246 on: February 06, 2016, 02:26:40 PM »
I vote clear/blue
  • Youngish
« Reply #248 on: February 06, 2016, 09:32:55 PM »
Hmm, clear/blue is pretty popular ;)
Anyway, Tom Gugliotta and I had been chatting about ways to get a more bright finish so we changed up the recipe a bit. Ditched the corn syrup and added vanillin instead. Not only is the finish much much brighter than last time, the pieces smell like candy ;D ;D
Chromate passivation will dull this, but I don't want to plate them again, so no biggie. Started with a few easy large pieces while we had a relatively warm day. Had to set up the lab indoors with a space heater (not idea, best done out in a garage in summer, but I'm on a deadline now). Pic 2 without flash, Pic 3 with flash.
  • Youngish
« Reply #249 on: February 07, 2016, 07:56:01 PM »
Not a bad weekend, managed to finish all the easy pieces. Saving the smaller stuff for another weekend. By popular choice, its clear/blue chromated. I still may do the center stand pivot and c-bracket gold because the new spring will not be clear/blue. Even experimented with targeted plating before wrapping up, wanted the end that sticks out for the  kickstarter shaft plated, came out good. Need to rig up the shifter shaft somehow next time.
