Author Topic: Oil leak from cylinder stud??  (Read 1950 times)
Offline sniper1
  • SNIPER1
« on: October 26, 2014, 06:44:10 PM »
My '75 550 has oil that is bubbling up from the cylinder stud (Number 11 in the picture). Somehow it is getting through the threads of the nut and spills over. Its not a lot of oil, but very annoying. It gets worse the higher I rev the engine and is worse when the engine is hot. I have torqued the head recently and all are in spec. Anyone ever have this problem? or have any thoughts on what to do to correct?
Re: Oil leak from cylinder stud??
« Reply #1 on: October 26, 2014, 07:37:03 PM »
Here's a picture of what's probably happening, not the same stud but you get the idea. The head gasket is leaking compression close to that stud and a little oil bubbles up through the threads.
Offline sniper1
  • SNIPER1
« Reply #2 on: October 28, 2014, 11:43:51 AM »
The head has been removed about 3,000 miles ago. I can't remember there being O-rings around the cylinder studs there. I may have to crack it open again to take a look. Boy, I hate doing that.....
« Reply #3 on: October 28, 2014, 07:58:51 PM »
There are no O-rings on the studs.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: October 28, 2014, 08:35:59 PM »
No but there is an o-ring between #11 and #10 that could be leaking. Usually it leaks out between the head and the jugs but you never know. Also don't count out that it could be a leaking puck dripping down on top of the stud/nut.
« Last Edit: October 28, 2014, 08:39:21 PM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #5 on: October 29, 2014, 04:14:16 AM »
It'll take a compression leak to show bubbles through the threads.
