Author Topic: Sandcast CB750 gurus  (Read 1790 times)
Offline Honda Just
« on: November 02, 2014, 07:22:59 am »
Hi Guys,
I'm sitting on some sandcast CB750 parts, and was toying with the idea of using them in a CR750 build. Some say its a waste and that I should rather sell or keep, but not use on the CR. I am finally tending to agree on this. So, could the guys who are in the know please help me spot which parts below are sandcast bits. (As I said in the other post I was born 10 years after Dick Mann won the Daytona 200 - so my knowledge is not first hand, but googled  :-[ ).
KOS, Sam, H2Eric, TurboGuzzi - can I pick your brains on this one?
Can you see which is sandcast and what sort of values attached to these items?
Any help would be much appreciated.
Justin
Offline Bill/BentON Racing
    • BentON Racing
Re: Sandcast CB750 gurus
« Reply #1 on: November 02, 2014, 07:32:21 am »
Head and cylinder not early, have front bolt hole. Cases are by serial # up to 4000+. Around 45-4700 were sandcast. kmb69 on here knows his sandcast well! G'luck, Bill
BentON Racing Website
BentON Racing Facebook
« Reply #2 on: November 02, 2014, 08:08:12 am »
Looks like just the cases.. And they look hand stamped..which may indicate replacement sandcast cases.
Offline kmb69
« Reply #3 on: November 02, 2014, 08:39:59 am »
Bill is correct - maybe the cases. All other parts pictured are later versions. Frank may have noticed the case numbers are suspiciously low on the pad and are a bit more "uneven" than normal but they appear to be the genuine Honda font. Need a picture of the right side, clutch side, of the cases to know for sure if they are SC cases. The clutch cover pictured is not a SC cover.
Offline Honda Just
« Reply #4 on: November 02, 2014, 10:54:29 am »
Pity... I was hoping more than just the cases, but it does mean parts can be used for CR750 build then. The serial is 1003858?
Offline Honda Just
« Reply #5 on: November 02, 2014, 10:57:09 am »
Thanks 754.
Thanks KMB, I'll go take a few pics now...
Offline Honda Just
« Reply #6 on: November 02, 2014, 11:16:01 am »
Here's a pic of the RHS
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7 on: November 02, 2014, 11:22:59 am »
Definitely sandcast.  There is no bolt hole in the bottom front corner..9 holes total instead of 10.
Offline Honda Just
« Reply #8 on: November 02, 2014, 11:31:16 am »
Thanks Greggo - I see you have a link to a sandcast resto, going to check it out now. Any idea on the value of such cases? Should I sell or keep for future sale?
Offline Old Scrambler
« Reply #9 on: November 02, 2014, 11:48:09 am »
+1 with the others.............cases only ...............but quite valuable.  Take a look at completed listings on ebay.
For interested buyers..................I have a a running early motor (#1016xxx) with the correct barrels and head to match those cases..............would be willing to sell the barrels and head.  I have plans to keep the balance and build a street legal CR750 replica.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #10 on: November 02, 2014, 12:52:59 pm »
Are the cases. OK in chain are..any other damage?
 It will matter in the value..
« Reply #11 on: November 02, 2014, 01:13:53 pm »
Make it easier on yourself, sell the cases with KO cases (or more) as part payment.. Later KO stuff is not as pricey nor as hard to find.....and it can still have the right looking motor in it.
 But your head is 73 or later..
Offline kmb69
« Reply #12 on: November 02, 2014, 07:18:31 pm »
Definitely Sandcast cases. Bare cases in that serial range, with no chain damage, or any damage for that matter, average around $2,000-2,500. Complete engines, $3,500-4,500 depending on condition.  Not always, but if they are in the range somebody needs to match a frame they may be worth more to them.
« Reply #13 on: November 02, 2014, 07:36:03 pm »
Frank............I agree............and have the pieces.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline Honda Just
« Reply #14 on: November 03, 2014, 12:52:50 am »
Ok great, thank you! I've put an ad on Vintage bike Ads - and will only sell to someone with a frame within range, not for value, but to make someone's build that much more accurate.
Really appreciate all of the info guys, thank you kindly.
Cases seem to be in great condition - and no chain damage. I can take some more pictures for interest's sake
Offline Honda Just
« Reply #15 on: November 03, 2014, 01:33:38 am »
Here are some pics
« Reply #16 on: November 03, 2014, 12:58:30 pm »
I would post them on the Sandcasts only forum.... ;)
http://cb750sandcastonly.com/smf_forum/index.php
Offline Honda Just
« Reply #17 on: November 04, 2014, 04:43:13 am »
Will do, just waiting on the log-in, thanks.
« Reply #18 on: November 04, 2014, 09:51:24 pm »
 The rocker cover is late too, I bought a 10033XX sandcast rocker cover. I can't tell it from my 104xxxx cover. The one on my sandy #5511 is chrome but reportedly original, looks like I'm stripping it.
 The cast peg on the inside of the tach drive is in the wrong place and the front center is flat on the front not rounded like a Sandcast. There may be x's cast into the inside of a sandcast rocker cover too.
    • BentON Racing
« Reply #19 on: November 05, 2014, 01:02:44 pm »
Damn, only got $1200.00 for # 1579! Were in good shape too! About 3-4 years ago. :D
