Author Topic: Quick glass-pack question  (Read 943 times)
Offline tfrasca
    • CB550 Project
« on: November 04, 2014, 11:04:12 AM »
I did a search and looked at the exhaust FAQ, but I still have one quick question for any one who has converted their MAC-style baffle to a glass pack baffle.
I found this photo from years ago, but I'm wondering if I need to have something on the front side of this homemade baffle to keep exhaust from going around the packing. Or maybe it just fits into the pipe tightly enough to prevent this? Thoughts?
Thanks.
Re: Quick glass-pack question
« Reply #1 on: November 04, 2014, 03:13:30 PM »
 Just don't wrap the fiberglass around the open inlet of the baffle. Yes a PO did that to my K0. I did an engine swap before I figured it out.
Offline tfrasca
    • CB550 Project
« Reply #2 on: November 04, 2014, 03:24:09 PM »
Wow. Like they totally sealed the exhaust's exit route with fiberglass?
Offline bjbuchanan
« Reply #3 on: November 05, 2014, 07:54:42 PM »
If you match the length and diameter of what you pulled out it should sandwich in there nicely. That's two easy measurements.
« Reply #4 on: November 05, 2014, 09:04:14 PM »
 Yes the engine was black on the inside with trapped carbon. it lives under a shelf now.  it would run a few seconds and die.
Offline tfrasca
    • CB550 Project
« Reply #5 on: November 05, 2014, 09:17:14 PM »
I could do that, but I want to make the glass pack section longer than the original baffle, thinking that will be a bit quieter.
Offline bjbuchanan
« Reply #6 on: November 06, 2014, 12:38:19 PM »
It's not rly gonna get any quieter, baffles and chambers are usually the only thing that does it. It will get mellower but not quiet by any stretch
Offline tfrasca
    • CB550 Project
« Reply #7 on: November 06, 2014, 12:48:49 PM »
I just made the new glass pack section out of some wire mesh and FMF packing. I made the tube about twice as long as the stock baffle. I'd say it's the same volume, but quite a bit smoother and mellower, as you say. Not bad for 20$.
Offline bjbuchanan
« Reply #8 on: November 06, 2014, 07:45:00 PM »
It is definitely worth it to do the job, I have done the same on a megaphone I had. It really helps on the highway at 5k~ rpm, takes the edge off
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #9 on: November 07, 2014, 10:06:53 AM »
i used the innards out of a 28 inch 2 1/12"ID THRUSH glasspack to stuff a Kerker wwith on my 750.  works like a charm
MATT
