Author Topic: Thinking of buying 75 CB750, need opinions  (Read 16856 times)
Re: Thinking of buying 75 CB750, need opinions
« Reply #125 on: November 13, 2014, 11:41:55 AM »
The seats I have had the trim is molded in and attached to the seat cover, not just a seperate piece of trim..
« Reply #126 on: November 13, 2014, 03:36:28 PM »
Are some of the re-pop seats using plastic for the seat pans ?
Yes, and I wouldnt buy one.
Offline jprochnow
« Reply #127 on: November 15, 2014, 04:36:30 PM »
Got some work done on it today. First picture is the fairing and sissy bar off. Second one is where I ended the day. Does anyone have a recommendation to an aresol cleaner that I can use for cleaning the frame up. There is lots of rust residue and o oil all over the place.
« Reply #128 on: November 15, 2014, 06:34:59 PM »
Looks better already. WD-40 is actually a pretty good cleaner that you may already have.
« Reply #129 on: November 15, 2014, 06:42:59 PM »
I usually wash them down with a hose and degreaser before I tear them down too much weather permitting. In the winter time its elbow grease with a rag. Kerosene is pretty good at cutting off the first layer of major goo with a follow up of other commercial cleaners like Greased Lightning etc. Lacquer thinner is a favorite also and smells good also, mixes well with my whiskey  ;)
PS-Remember to save those front turn signals off that fairing to re-use per my earlier post.
Offline jprochnow
« Reply #130 on: November 15, 2014, 06:55:42 PM »
Yup I kept the turn signals and the headlight lens. After removing the fairing I found that I need the rest of the bucket assemble. The present bucket is broken. Next step for me is to remove the pipes. I'm also in need of a rear and front fender. Both were pretty bent. Looks like I'll need some elbow grease to get this thing clean.
Offline Johnie
« Reply #131 on: December 03, 2014, 12:32:55 PM »
Gosh, the fenders don't look that bad on the pics. How bad is the dent? I have a good chromer up here that does wonders.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
