Author Topic: Has anyone replaced the seal in the cam chain tensioner housing on a CB750?  (Read 2506 times)
Offline markb
  • When I finish my current project I might be a
I need to use the housing because it is sandcast (to be correct for engine E100) but the seal looks questionable to me.  It appears that the steel retainer would have to be pulled out to replace the seal.  Has anyone ever done this and know what seal is required?
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Need an extra to practice on ? Be a later 71-76 model   Eric
Offline Whaleman
http://forums.sohc4.net/index.php?topic=52277.msg1532158#msg1532158
Here is a post I made years ago. I used a distributer rubber to seal the end from water. Maybe this could work if it was leaking a small amount. I don't think many leak. Dan
Offline markb
Thanks for the offer.  I have several, later diecast ones I can experiment with.  If I can get the steel retainer out maybe it's as simple as swapping the retainer and seal with the one in the sandcast housing.  Might be hard to find a replacement seal.  Looks like I'll have to make a special tool to get it out.
Great idea.  Some good info in that link.  I had done a search but didn't find it.  Unfortunately it doesn't help for what I'm trying to do.
Offline Old Scrambler
Mark.............try soaking the unit in wintergreen oil for a day or so.  I have also had good success with other rubber parts by soaking in Marvels Mystery Oil or JOY or DAWN dish-soap but it takes 10-days or more to get results. I had rock-hard intake rubbers return to 'like new' after a month of DAWN treatment.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline markb
Hmmm, I might try that.  I'm guessing there isn't a lot of pressure against that seal.  I haven't tested it to see if it leaks but that would be easy enough.  I still think I'll take one apart.
Offline markb
I had some time today so I made myself a little puller.
Here’s how it fits into the housing.  I had to put the fingers in first and then put in the screws to hold them.
Then I put it in the arbor press with a rod through the housing and the seal cup came right out.
There it is.  So it can be done.  It took me a couple of hours and I realize this is a big waste of time (because there are plenty of adjusters available on eBay for $5) unless you have a sandcast adjuster that needs to be saved.
Offline Whaleman
markb, I'm confused. Why did you waste your time? Is the one you are working on sandcast? i did not even know these were sandcast on sandcast case engines. If it is can't you just buy an ebay one and change the seal to your special one? Dan
Offline markb
This is the sandcast one and yes, they are different that the diecast ones you see on eBay.  If I could find a sandcast one I would buy it.  The seal was bad on the sandcast housing.  What I actually pulled out is the metal cup that holds the seal.  Then I pulled a good cup and seal out of a diecast one and put it in the sandcast one.
Offline markb
I was looking on the Yamiya site and stumbled across this.  They make a puller for the metal cup and seal for the cam chain tensioner housing.  Unfortunately they can only sell it in Japan.  But it shows I wasn’t the first one to think about doing this.   ;D
Offline Ellz10
  • ZZ
  • Knowledge is Power
I know uts been 7 years, but I just checked and purchased this tool. It's now available to us in the States. I'm getting my housing vaporblasted and need to pull the cup so this was relevant. Tha k you for your post, I wouldn't have been able to find it anywhere else; trust me I've been actively looking lol.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
