Author Topic: How to(with dyna s electronic ignition) adjust valve clearances please  (Read 544 times)
Offline millispartners08
  • cb750 four k1-k2 enthusiastic enthusiast
  • cb750 four K0/K1/K2 O.C.D
Same as previously posted, this time please I need also step by step instructions to adjust valve clearances please-( have dyna s electronic ignition fitted as noted also before), please help me out. Thanks in advance.
"have much, and be confused; have little, and gain everything" chinese proverb.
Re: How to(with dyna s electronic ignition) adjust valve clearances please
« Reply #1 on: November 10, 2014, 01:48:40 PM »
Anyone care to enlighten me please where its best described?( if in shop manual what pages please). I have seen spot in supplement section for cam chain tensioner part but have trouble following/finding best spot in manual for step by step valve clearances adjusting correctly section. Please help me out.
« Reply #2 on: November 10, 2014, 01:53:41 PM »
this is all in the shop manual
check pg 42/43 for valve adjustment steps
also on pg 181
« Reply #3 on: November 10, 2014, 01:58:31 PM »
Thanks again mate. I am a mechanical novice- bare with me.
I'll check out p42/43 and 181 to try and follow valve clearances part. Thanks for pages heads up. It's a big manual for a novice, thanks again.
