Author Topic: How to(with dyna s electronic ignition) adjust cam chain tensioner please  (Read 703 times)
Offline millispartners08
  • cb750 four k1-k2 enthusiastic enthusiast
  • cb750 four K0/K1/K2 O.C.D
Have cb750 k2'73 model australian- I need step by step help please (accurately) to safely and correctly adjust the cam chain tensioner and to seperately adjust the valve clearances also- note that I have dyna s electronic ignition fitted. Please help. Please give me step by step spelt out directions from start to end.(are a mechanical novice best of times and don't want to stuff anything up most importantly as is important to us all).-thanks in advance.
"have much, and be confused; have little, and gain everything" chinese proverb.
Offline flatlander
Re: How to(with dyna s electronic ignition) adjust cam chain tensioner please
« Reply #1 on: November 10, 2014, 01:22:47 PM »
i'm not a 750 guy but rest assured, cam chain tensioner and valve clearence adjustment work as described in the honda manual even with electronic ignition. there's no connection.
« Reply #2 on: November 10, 2014, 01:25:11 PM »
Please advance on 'there's no connection' if possible. Could you please clarify meaning of those words for me please.
Offline flatlander
« Reply #3 on: November 10, 2014, 01:29:21 PM »
the fact that you have installed an electronic ignition has no influence on how to adjust cam chain tension or tappet clearance. if you pick up a manual and follow the instructions, they're valid.
« Reply #4 on: November 10, 2014, 01:38:39 PM »
+1
follow the shop manual procedures.
« Reply #5 on: November 10, 2014, 01:40:47 PM »
Ok. Thanks for clearing that up for me. I didn't fit the dyna s, terry from Australia kindly did for me a few years ago. But I live pretty far away from him now unfortunately. Just out of curiosity- what pages in manual is the valve clearances adjustment explanation well described? I think I spotted the cam chain tensioner part in the supplement notes part. Could you help here please or could you get someone else you know with cb750 four to respond please to my query.
« Reply #6 on: November 10, 2014, 01:50:40 PM »
pg 42/43
pg 181
« Reply #7 on: November 10, 2014, 01:52:16 PM »
Thanks heaps mate.
