Author Topic: any old honda stuff  (Read 4862 times)
any old honda stuff
« on: November 11, 2014, 03:02:00 AM »
how good is any old Honda stuff?i found an old Honda generator the other day,its missing the fuel tank,air filter and one engine cover,i picked it up for its copper but thought id toy with it first,gave it a quick look over and it started 2nd try no #$%*!puffed a little blue smoke then ran clean,i ran a lamp of it and a drill,i gotta tinker with the governor yet,ill end up making a new frame affair for it etc,ditch whats left of the plastic plug board,it looks like crap but its another great running Honda!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: any old honda stuff
« Reply #1 on: November 11, 2014, 04:13:03 AM »
Nice find! I'll give ragged out old Honda generators a second look from now on...
The Honda generators tend to be some of the quietest as well.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline honda_dog
« Reply #2 on: November 11, 2014, 05:16:32 AM »
I've got an old Honda tiller, passed down to me from my father. It's better than 25 years old, still starts first pull....
1978 CB750K
1981 CB900F
1978 Suzuki GS1000E
1981 Suzuki GS1100EX
1980 Suzuki GS1000S (Wes Cooley replica)
1982 Suzuki GS1000S Katana
1982 Suzuki GS1100EZ
1983 Suzuki GS1100ED
1983 Suzuki GS1100ESD
2014 Honda F6B Deluxe
« Reply #3 on: November 11, 2014, 05:55:17 AM »
It's unbelievable what you find in the bins, Dave.
« Reply #4 on: November 11, 2014, 06:03:24 AM »
May even find a body someday     :o
« Reply #5 on: November 11, 2014, 07:08:27 AM »
I *think* he may have found his wife!
« Reply #6 on: November 11, 2014, 09:08:03 AM »
Ive got my dads honda mower (HR214)  The deck is a little beat, but it starts easily 1-2 pulls.
Its gotta be 30+ years old....
Offline Killer Canary
  • Typical Bran Muffin
« Reply #7 on: November 11, 2014, 11:43:03 AM »
Hard to believe this stuff is so old. I still remember when "Made In Japan" was the kiss of death.It took them a while to start building cars that didn't rust out prematurely.
Kawi GPz900, H1
Offline TwoBigCats
  • Hobbyist beekeeper
    • TwoBigCats
« Reply #8 on: November 11, 2014, 06:29:52 PM »
my honda generator is 25 years old, runs like new. mower is 15, runs like new.
if honda made a toothbrush, I'd buy it.
GL1800 | 750 K6 | '69 CB/CL 160 | '70 CT 70
« Reply #9 on: November 11, 2014, 06:43:23 PM »
I don't know, I have a 1967 Mazda 1500, very little rust , nothing structural, immaculate interior and still has the original, untouched running gear...She's a very solid car....
Offline faux fiddy
  • bike in a box
« Reply #10 on: November 11, 2014, 10:40:44 PM »
I have a dead coleman generator, but I think it is revive able from what I read.
You take a drill motor, plug in style and plug it in to the gen set. Then you spin up the drill to create a current that activates the fields of the generator to make it works.
It will probably need done if it sat unused for a long time.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #11 on: November 14, 2014, 03:09:44 AM »
I haven't had a bike project for a while but im always tinkering around with similar stuff,so this is my latest Honda project?not worthy of the project thread so ill dump it here,i decided to knock up a steel frame using the power panel cut off from the stock plastic body for ease,it has all the labels for stuff then,not much to it,ill get some decent rubber feet for it,might paint the thing aswell,under that plastic Honda cover these are unpainted!its only a 1000 watts at 240 volts,it runs 1100 watt 125mm angle grinder fine even loading it up heavily,for a joke I tried my welder and it hardly made a spark!still have to figure out a decent tank and mount for it,all the tanks I find on old lawn mowers and weed wackers are odd shapes to suit the housings with dumb plastic clip set ups that are always broken etc and look crap to mount easily,im working on it.
Offline ThomasD883
« Reply #12 on: November 14, 2014, 08:53:23 AM »
Why not use an old 500 tank. Dosent have to be pretty , just hold fuel , right?
Diesel deeds, done dirt cheap
« Reply #13 on: November 14, 2014, 12:47:05 PM »
ha yeah,i want it to be compact,unless I use a knee dented tank and a pod and open pipe and make a café generator out of it?
Offline demon78
  • After work to the "Wets"
« Reply #14 on: November 14, 2014, 01:01:31 PM »
Great stuff Dave.
Bill the demon.
Online seanbarney41
« Reply #15 on: November 14, 2014, 03:50:25 PM »
just make sure it's got enough juice to run the coffe pot!
« Reply #16 on: November 14, 2014, 04:18:26 PM »
And use pods for stainers to make the coffe?
« Reply #17 on: November 15, 2014, 03:02:18 AM »
is it worthy of a couple of fake bullet hole stickers?i also found a year or so ago one of those Honda four stroke weed wackers,the shaft was bent and what not but I kept the engine to see how it could run upside down and not flood oil into the combustion chamber,anyway I got it running fine and put it on gumtree (like craigs list) as an engine to power a skate board or bicycle and got 30 bucks for it!it ran fine!they have a weird cam shaft and rocker set up where a single lobe runs both valves with an under over looking rocker arm pivot jigger,almost a desmo set up?
« Last Edit: November 15, 2014, 03:08:43 AM by dave500 »
Online scottly
« Reply #18 on: November 15, 2014, 06:19:40 PM »
The oldest machine I ever resurrected was a Graham-Paige roto-tiller, made in about 1946. I bought it for 5 bucks, and after cleaning the tank of the foul smelling fuel residue and replacing the steel cable for the re-coil starter got it to run. After tilling the old man's back yard, I sold it for $30, which was a nice profit for a 14 year old at the time. I found a pic of a similar model...
Offline jerry h
« Reply #19 on: November 15, 2014, 09:40:10 PM »
Hey Dave, you going to powder coat the frame?
« Reply #20 on: November 16, 2014, 12:03:37 AM »
We used to have those baby Honda gennies when I was in the Army Dave, they were pretty useless as 1000W wouldn't run a fridge or a kettle, but it'd be OK for a drill or an angle grinder, in fact I've got a Bunnings 800W gennie that I'd use when we had a power outage to run some lighting and the TV.
I bought another Bunnings gennie (3KVA, from memory) for 200 bucks on special a few years ago, it'll run anything in my house, so in summer when all my neighbours fire up their refrigerated aircon and blow the local transformer up, I can still enjoy cold beer or a cup of coffee, lighting and TV. Interestingly enough, the larger Bunnings Gennie is a Honda knockoff, and appears to be pretty good quality. Cheers, Terry. ;D
« Reply #21 on: November 16, 2014, 12:59:58 AM »
love it,i used to scrounge the dump as a kid and get old lawn mowers going,never sold them but just got the engine running and toy with it,old push bikes etc,thats how I started out,now I have free access to old #$%* all the time and im the original "Steptoe"!
« Reply #22 on: November 16, 2014, 02:06:50 AM »
got a tank mounted up,ill make some rebar loops as lifting handles from the frame each end and rubber feet, a lick of paint and the café racer generator will be done.
    • http://forums.sohc4.net/index.php?PHPSESSID=u12nr0tof0o96g5e86slkem222&/topic,60973.0.html
« Reply #23 on: November 16, 2014, 02:43:28 AM »
nice tank..used on italy"aspera"s lavnmowers...in europa..i have one ,,just the same..for kaburettor vaccum syncro..and stasonary test of kaburator banks for leaks
« Reply #24 on: November 16, 2014, 11:30:57 AM »
that tank came off a Suzuki lawnmower.
