Author Topic: Stripped Sync/Plug Screw  (Read 1448 times)
Offline DennyK
  • Just kill the one with the sword first. R. Shaftoe
« on: November 14, 2014, 01:50:20 PM »
Folks,
My son and I are bringing a 1974 CB750 back to life.  This past summer we got the bike running; that entailed rebuilding the carbs and front brake along with a lot of other basic maintenance items plus buying plates and insurance.  The engine is strong but we need to do a lot to the bike to get it really roadworthy and we have started on our list of improvements.
One of the things I noticed in cleaning the carbs was that one of the sync screws was slightly stripped.  We attempted to balance the carbs and I don't think we did a real great job, but we learned.  Going forward I want to be sure we can balance the carbs correctly and I think this sync port needs to be fixed.  A good friend who has done a lot of motorcycle repair work recommends using a Helicoil to make the repair.  The set screw is a 5m and you can get a Helicoil for that size.  My question is has anyone out there used a Helicoil in a carb body or are there other ideas?
Cheers
DennyK
Offline Vinhead1957
Re: Stripped Sync/Plug Screw
« Reply #1 on: November 14, 2014, 02:37:23 PM »
How bad is it stripped ? Does the screw tighten? If so I would chase the threads with the proper size tap and use some Teflon tap on the screw for a short term solution. Long term, yes a helicoil
Offline dlhoulton
« Reply #2 on: November 14, 2014, 02:52:44 PM »
Might consider after repairing using something like the Motion Pro permanent brass adapters so that you wont have to be worried about something like that happening again in the future. They come in different lengths so access wont be a problem. Here is one source to consider.
http://www.amazon.com/Motion-Pro-Permanent-Brass-Adapters/dp/B0012TTA5E
Offline DennyK
« Reply #3 on: November 14, 2014, 03:06:01 PM »
Thanks for the quick replies guys.  Since I am going to have the carbs off the bike for the winter; I am going to go with the Helicoil fix and then get a set of those Motion Pro adapters to avoid any further issues with the other three carbs.  Thanks for the link, that makes it easy.
« Reply #4 on: November 15, 2014, 05:44:34 AM »
Maybe if your lucky it will just be the threads on the screw/plug that are bad as I believe they are made of a softer brass alloy.
Offline DennyK
« Reply #5 on: November 15, 2014, 02:21:06 PM »
Thanks for that comment. I will confirm that before taking next steps
Offline chewbacca5000
  • I polish covers!
« Reply #6 on: November 15, 2014, 02:36:03 PM »
I would go with a solid threaded insert like these http://www.ezlok.com/Home/index.html
All you do is tap and screw in.  I do not like using springs as fasteners at all.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: November 17, 2014, 07:14:41 AM »
My #2 carb has this same problem. Whenever I go to sync my carbs I have to be VERY careful putting in the brass sync tube because it hits the choke linkage and makes it go into the hole sideways. I think I just need to chase the threads.
Slight hijack, but does anyone have a tip for getting those long brass inserts to NOT hit the choke linkage?
--Evan
1975 CB750K "Rhonda"
« Reply #8 on: November 17, 2014, 07:46:00 AM »
I recently Helicoiled my #4 carburetor - after using silicon tape for two years.    It works.
