The SOHC/4 World Tour is in under way.
For Oem cables I use dri slide, most will say it doesn't need lube since it's Teflon lined.
Quote from: Djfob on November 16, 2014, 07:47:08 PMFor Oem cables I use dri slide, most will say it doesn't need lube since it's Teflon lined. use it on all cables, far as I am concerned there is nothing better as it does not coagulate like a petroleum based lube that would attract dirt which eventually makes the cable even harder to pull.(my .67 )...Larry
It's a little motor and likes having the tits revved off it.
