Author Topic: second guessing myself: timing advance question  (Read 567 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: November 17, 2014, 06:27:45 PM »
with a strobe, if timing is advanced* then the indicator tab should appear on which side of the T mark?
* that is, SET to be advanced - as in rotating the points plate.
NOT advanced by upping the revs and having the advancer mechanism do it's thing.
Offline Spanner 1
Re: second guessing myself: timing advance question
« Reply #1 on: November 17, 2014, 06:50:50 PM »
With the timing advanced, a strobe light will show the indicator to the right of the F mark, if the T mark is visible with a strobe then the timing is retarded...... Important note; this would only apply at idle r.p.m. as engine speed above about 1,100 r.p.m. will already turn the advancer mechanism  ;)
Offline grumpy
« Reply #2 on: November 17, 2014, 07:36:32 PM »
roger
thanks
