Author Topic: apple cider vinegar ok on paint?  (Read 6119 times)
Offline J-Dawg
« on: November 17, 2014, 09:03:26 PM »
Need to bath inside of my tank in apple cider vinegar  for rust removal, but is cider vinegar OK on paint?
Offline chewbacca5000
  • I polish covers!
Re: apple cider vinegar ok on paint?
« Reply #1 on: November 19, 2014, 05:05:50 AM »
Should be fine if it drips on it.
Offline iron_worker
« Reply #2 on: November 19, 2014, 07:23:17 AM »
X2
Any drips or splashes won't hurt it. Just wipe it clean once you're done filling.
IW
« Reply #3 on: November 19, 2014, 07:33:15 AM »
A coat of unbuffed wax, like Turtle wax or such is a good idea also to add a little extra protection.
Offline Whaleman
« Reply #4 on: November 19, 2014, 08:09:29 AM »
Is vinegar better or easier than the works? Thanks Dan
Offline jprochnow
« Reply #5 on: November 19, 2014, 08:24:42 AM »
I have been told that white vinegar is great for tanks.  You need about 5 gallons and about a week worth of time. Fill the tank and let sit for a week. Empty tank an then check you see the rust situation. If good dump a baking soda water mixture into the tank which neutralizes it.
« Reply #6 on: November 19, 2014, 11:15:23 AM »
If you want to get it done in an afternoon use the Works. Read up on drying it, flash rust, getting gas back in quickly, types of hole plugs  yada yada.
Offline C5paul
    • C5 Performance
« Reply #7 on: November 19, 2014, 04:39:52 PM »
Good idea. White Vinegar WILL remove paint!!!
I use it to strip paint from carburetors. The wax idea is brilliant. They also make a coating for painting cars that does a good job of protecting the stuff you don't want damaged. It peels off when you are done.
« Reply #8 on: November 19, 2014, 05:06:53 PM »
If you get any vinegar on the paint, just wipe it off as soon as possible.  Ekpent's got it.  Vinegar will take at least 24 hours, much longer depending on the amount of rust.  The Works can be done in an afternoon...
Offline Djfob
« Reply #9 on: November 19, 2014, 06:18:50 PM »
Best stuff I've used and safe on paint is metal rescue.
78 CB750k
Offline DaveBarbier
« Reply #10 on: November 20, 2014, 02:53:52 PM »
I've also used that three times on different tanks. Works well, but it's a little expensive. I lucked out when I ordered 2 gallons for my CB125...Amazon sent me 6 gallons by mistake!
It is safe on paint but be careful with red paint. A lot of reds are made with iron oxide as a pigment. So in that case, it will fade it.
1978 Honda CB550K
« Reply #11 on: November 20, 2014, 03:19:37 PM »
My view is , if its no part of, or  not a product thats used on paint , don't put it on paint... ;)
