Author Topic: Brush for interior engine cleaning... Need some advice  (Read 2072 times)
Offline bambuhiphop
« on: November 21, 2014, 02:56:13 PM »
Ok, Getting ready to clean out the interior of the case before I glyptal it. It has already been soda blasted. Going to wash it a few times and then I want to take a cleaning brush to the interior before it gets wiped down with denatured.
So, my question is which brush should I get/use???  http://www.dremel.com/en-us/Accessories/Pages/SubCategories.aspx?catid=2064&catname=Polishing+Brushes
Should I go with Nylon, Carbon Steel, Stainless Steel, or Brass?
« Last Edit: November 21, 2014, 03:47:56 PM by bambuhiphop »
Re: Brush for interior engine cleaning... Need some advice
« Reply #1 on: November 21, 2014, 06:10:33 PM »
id use nylon?how clean you want it?
Offline bambuhiphop
« Reply #2 on: November 21, 2014, 06:22:48 PM »
OCD clean
« Reply #3 on: November 21, 2014, 06:27:07 PM »
take it to your dentist!
Offline calj737
  • I refuse...
« Reply #4 on: November 21, 2014, 08:25:23 PM »
Spray bottle of Degreaser, nylon brush and follow with Denatured Alcohol.
« Reply #5 on: November 21, 2014, 08:27:20 PM »
then floss and follow with PH neutral facial beauty wipes?not that ive ever used them!be a waste on my face!
« Last Edit: November 21, 2014, 08:29:09 PM by dave500 »
Offline bambuhiphop
« Reply #6 on: November 21, 2014, 10:00:51 PM »
Basically my plan. Thanks
Offline bambuhiphop
« Reply #7 on: November 21, 2014, 10:01:33 PM »
I would but my wife would kill me again.... I mean I to have never used them!
« Reply #8 on: November 21, 2014, 11:00:11 PM »
don't lie,you and I are both handsome!
« Reply #9 on: November 22, 2014, 03:46:12 AM »
I save used toothbrushes and use them for cleaning jobs.
Offline Bodi
« Reply #10 on: November 22, 2014, 07:43:34 AM »
Put on a rainsuit and goggles at the local coin-op car wash, set engine cases on the ground (a rubber mat is helpful), and have at it. The pressure washer really blows out all the passages and bolt holes. You need protection because the damned spray comes right back at you off the concave hollows and bolt holes.
Online Don R
« Reply #11 on: November 23, 2014, 11:00:44 PM »
 One more lap through the dishwasher and it's good to go.
Offline bambuhiphop
« Reply #12 on: November 24, 2014, 04:00:35 PM »
Thanks Guys, think I have a good process in mind now.
