The reason for my post was, I have had the HM ignition hooked up for about two years now and it worked really well at first. now my 750 doesn't seem to start as easy and almost feels like its not firing on all four for about a minute when she is first started then it feels like all four kick in and it runs smooth. also the idle isn't what it was so I pulled the carbs and re cleaned them for the first time in about two years they really weren't bad. I am thinking of reseting the valves, points, and timing next but I just wanted to make sure I had the HM ignition hooked up correctly.
