Author Topic: Seafoam down spark plug holes?  (Read 3657 times)
Offline Scott S
« on: November 26, 2014, 02:31:45 PM »
 I've been doing a lot of searching and can't quite find this exact scenario/question.
 I have a bike that's been running really rich and has some carbon build up on the piston tops. I'll be addressing the rich running and giving it a full tune-up, but I was wondering if I could squirt a little SeaFoam down the spark plug holes and let it sit for a bit to loosen the carbon. Then, fire it up and run it for a bit before changing the oil.
 Just a one time thing to try to help loosen and remove some of the carbon without doing a tear down. It's not horrible carbon, but could definitely stand to be cleaned out if possible.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Seafoam down spark plug holes?
« Reply #1 on: November 26, 2014, 03:01:20 PM »
before my rebuild, i soaked carbon coated pistons in seafoam.
It did loosen it up but they were better after a scrubbing.
IIWM, i'd just get it tuned right, (correct AF mixture across the throttle range) and then run the snot out of it.
"This is my CB. There are many like it, but this one is mineā€¦"
Offline calj737
  • I refuse...
« Reply #2 on: November 26, 2014, 05:05:47 PM »
If you do use SeaFoam, they make a "Deep Creep" formula that will work better. But, I doubt it would de-coke your engine in the way you're thinking. There are other methods for doing this, a search across Google or YouTube provides pretty good methods and steps.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: November 26, 2014, 06:22:23 PM »
Berryman's makes a pretty good carbon remover. Pretty much dissolved right off. And like Fly says run the snot out of it that's what will keep the cylinder clean.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #4 on: November 26, 2014, 06:27:59 PM »
Don't hydro-lock your engine please
Offline goldarrow
  • one day, i'll be an
« Reply #5 on: November 26, 2014, 07:02:28 PM »
I say save that money from buying seafoam and invest in brass hardware for the carbs
CB550 K0
Offline chewbacca5000
  • I polish covers!
« Reply #6 on: November 26, 2014, 07:11:46 PM »
Nothing works when it is freezing cold out.  I normally fill up with 50/50 atf/acetone and let it sit for 4 to 6 weeks to break up the carbon and varnish.  Take all plugs out kick it over to get mix out then put plugs in and run.
Offline faux fiddy
  • bike in a box
« Reply #7 on: November 26, 2014, 08:52:32 PM »
+1 on the Italian tune-up. Seems to be working for me.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #8 on: November 26, 2014, 09:03:45 PM »
X2 on the tune it and ride it. A proper dose in the fuel will not hurt it. I've soaked arb parts in seafoam with little result. I guess that's not what it was made for.
« Reply #9 on: November 26, 2014, 11:32:32 PM »
... and invest in brass hardware for the carbs
It's not the first time you give this 'advice'. I wonder what makes you so sure. My experience is the contrary: brass parts rarely wear if at all. No wonder if you realise how little gasoline pass these parts on a 500cc engine with no less than four carburetors. In this forum you see often people have returned to their stock brass parts after disappointing results with for instance Keyster parts.
Offline Airbusboy
  • Smooth as buttah.....
« Reply #10 on: November 27, 2014, 05:07:11 AM »
I bought a '83 CB1000C once that a PO had a 'friend' adjust the valves. Well, he didn't know what he was doing and both #1 exhaust valves were shimmed WAY too thick and they didn't close. Though he was lucky enough NOT to burn the valves, LOTS of carbon built up, the valves wouldn't close and compression went south. He sold it to me thinking the #1 cylinder was toast.  The advice from the guys at the DOHC club was to properly shim the valves, put a HEAVY dose of Seafoam in the fuel and then 'Run-it-like-you-stole-it!', and it worked! The carbon cleared out and compression came back to near normal so I'm a BIG fan of Seafoam!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #11 on: November 27, 2014, 05:27:06 AM »
Me too. First ride of the spring is a dose of seafoam and a heavy-right-hand ride.
--Evan
1975 CB750K "Rhonda"
« Reply #12 on: November 27, 2014, 06:15:02 AM »
Think he may have been alluding to the fact that maybe some carb tuning, jet swapping may be in order to help alleviate the rich running condition.
Offline goldarrow
« Reply #13 on: November 27, 2014, 06:45:28 AM »
Not suggesting to replace with keyster kits.  Just new different sets.  All of my bikes run on using stock brass hardware set by the way.
CB550 K0
Offline Scott S
« Reply #14 on: November 27, 2014, 08:56:40 AM »
 I'm not opposed to new brass....IF I thought it would help and IF it was available.
 Tried to find 550F emulsion tubes lately?
 Plus, the parts are all genuine Keihin except for the float valves and the bike has less than 7k miles on it. Not saying it isn't possible something is worn but I find it hard to fathom.
 I WILL check fuel level with a clear tube since the new float valves might not work at the 22mm height.
 Full tune up is on the way and I'll do Seafoam in the gas and a hard right hand when done.
'71 CB500 K0
'81 Yamaha XS650
KiefRichards
« Reply #15 on: November 27, 2014, 11:42:17 AM »
You could also make a quick water injection rig with a small bottle and lines to the sync ports on carb.
Turn it on under full load, it'll knock that carbon right off!
Low volume on the water, though!
The tip from a mig welder shoved into the water feed lines works as a good restrictor.
« Last Edit: November 27, 2014, 11:56:55 AM by KiefRichards »
Offline Feets007
« Reply #16 on: November 27, 2014, 03:19:27 PM »
Yamaha royal stars have a car on problem. I have, and Yamaha pours a bottle of Techtron in it with a full tank of fuel ride it out then oil change.
Offline Builder
« Reply #17 on: November 28, 2014, 05:18:40 PM »
I used to use water on high carbon buildup. Take off the air filter box. Run the bike at a high idle with the throttle and spray water into the carb. Just keep it running. The carbon will steam off and go out the exhaust.
