Author Topic: Which webers?  (Read 4610 times)
Offline afkrejci90
Which webers?
« on: November 27, 2014, 03:55:42 PM »
Looking to purchase a set of webers dcoe, 40 or 45?  What's the difference between them and will I see any benefit from one over the other?  Stage 3 head, hi comp, 1000cc.
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline BPellerine
Re: Which webers?
« Reply #1 on: November 27, 2014, 04:45:03 PM »
most people run the 40s ,with the right chokes and jets would be more than enough carb I think.bill
1978 CB 750K ard and webers
another anfob
Online scottly
Re: Which webers?
« Reply #2 on: November 27, 2014, 06:24:46 PM »
1+ for 40's. You can fit chokes as large as 36mm, if you think the motor needs that much air. ;)
Re: Which webers?
« Reply #3 on: November 27, 2014, 08:18:50 PM »
Pretty sure 45 bodies are bigger, won't fit in there..
Offline ivanhoew
Re: Which webers?
« Reply #4 on: November 28, 2014, 12:09:28 AM »
« Last Edit: November 28, 2014, 12:14:24 AM by ivanhoew »
just do it .
Offline Tintop
Re: Which webers?
« Reply #5 on: November 28, 2014, 06:03:01 AM »
45's are definitely bigger, you will have problems with frame / tank clearance.  Finding a manifold will be an issue as well, unlike with the 40's.
That chart is in various Weber books, take it with a grain of salt as it represents the absolute perfect set-up.  From what has been posted on the Forum, 80 CFM would appear to be a 'wish list' upper limit for the best CB 750 head.  As for choke size, I run a 40DCOE with 34's on my 750 twin sidecar engine.  The chart says I could / should be using 36mm or 38.  If I did I would have no mid-range at all.  Actually thinking of going to 32's to improve overall tractability, and throttle response.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Re: Which webers?
« Reply #6 on: November 28, 2014, 07:56:42 AM »
That is the beauty of the Webers, just change it around to suit your needs.
Offline ivanhoew
Re: Which webers?
« Reply #7 on: November 29, 2014, 01:35:07 AM »
i agree tintop ,
i think something to bear in mind is pk bhp rpm , not what will it rev to rpm .
eg if a bike has a 10k rpm, its pk powr may still be at 8700 rpm , so thats the place on the weber chart to refer to .
also , a 10k rpm  r1 engine is going to flow a lot more than a 10k rpm honda 1000 sohc .
it would be better if they did a bhp line on the x axis .
just do it .
Offline afkrejci90
Re: Which webers?
« Reply #8 on: November 29, 2014, 03:22:41 PM »
OK, I'm going with the 40's then.  Thank you for the help everyone.
'80 CB750C - Sold
'06 CBR600RR
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
Re: Which webers?
« Reply #9 on: November 30, 2014, 11:52:30 AM »
If you need manifolds, I'll be fabbing up a set sometime soon. I have measurements for early K carb adapters and late K carb adapters.
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
Offline Lostboy Steve
Re: Which webers?
« Reply #10 on: November 30, 2014, 12:45:17 PM »
Want to do a 550 while youre at it?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Re: Which webers?
« Reply #11 on: November 30, 2014, 01:05:32 PM »
I could probably be persuaded to do so. Have measurements from the carbs? Would want the C-C distance (spacing) of the outer set, the OD of the carb outlet, and the ID of the carb outlet as well.
I saw the post on the single weber though, that'd be out of the question for the way these manifolds work.
'75 CB750 - Racer
'69 CB350 - Racer
Offline jaguar
Re: Which webers?
« Reply #12 on: December 01, 2014, 07:15:37 AM »
What style manifold are you going to be making?
cost?
Re: Which webers?
« Reply #13 on: December 01, 2014, 10:52:43 AM »
They're a new style adapter manifold, bolts onto the weber, accepts a CB750 carb rubber and is CNC ported to match both. My proto set is off getting anodized, will post up pics when they're back.
'75 CB750 - Racer
'69 CB350 - Racer
Offline Tintop
Re: Which webers?
« Reply #14 on: December 01, 2014, 02:07:53 PM »
I'd be interested in one.
77 CB550 Cafe build
Offline afkrejci90
Re: Which webers?
« Reply #15 on: December 01, 2014, 03:24:17 PM »
I was thinking of doing the same, I'd like to see how yours turn out.
'80 CB750C - Sold
'06 CBR600RR
Online scottly
Re: Which webers?
« Reply #16 on: December 01, 2014, 06:39:28 PM »
Ivan, I've never seen that airflow chart. According to it, the max flow doesn't change much from the smaller chokes to the larger ones?
Online seanbarney41
Re: Which webers?
« Reply #17 on: December 01, 2014, 06:44:22 PM »
subscribed
Re: Which webers?
« Reply #18 on: December 01, 2014, 07:39:32 PM »
Sounds like a great project. Hopefully there will be a few sets made while you're at it. Economy of scale. I have a RC set off the bike if you need any measurements, etc.
Re: Which webers?
« Reply #19 on: December 01, 2014, 09:56:47 PM »
I'll see what I can do, lets hope it works out first! I actually started this project because I didn't like the RC Carbs adapters because mine had cracks and were all welded up in places.
'75 CB750 - Racer
'69 CB350 - Racer
Offline ivanhoew
Re: Which webers?
« Reply #20 on: December 02, 2014, 10:45:30 AM »
yes  i agree scott , its a bit odd that there would be on benefit from 36 to 40 on the 45 too.
regards
robert.
just do it .
