Author Topic: Fiberglass fender + metal fork brace  (Read 5169 times)
Offline Scott S
Re: Fiberglass fender + metal fork brace
« Reply #25 on: January 17, 2015, 04:50:50 AM »
 I used this stuff. The body shop told me they attach roofs, etc., with it. It's not on the bike yet, but he swears it ain't going nowhere!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline arogers88
« Reply #26 on: January 17, 2015, 05:24:59 AM »
Adhesive bonds are only as good as the prep. Today's modern urethane adhesives hold to about 750 PSI, but only if the correct primers are used depending on what you are bonding. Otherwise, you can pretty much peel it off by hand.
Windshields are bonded to coated steel, aluminum, ect, and they have to stay bonded in the event of an accident, air bag deployment, roll over, ect.
Prep it right and you're good.  :D
Offline 78whiteorbs
« Reply #27 on: January 17, 2015, 06:04:17 AM »
sure looks clean- :-)
Actually working on a popup camper project at the moment and was researching adhesives for bonding certain materials.
Where did you get that Scott ? how much did it run. I think the *toughest* part for me to wrap my head around would lie in the prep area.
I am just imagining a curved smooth finished surface (chrome plated?) just not having anything to grip to bond to. I surely believe what you guys are saying is possible . Prep would be the crux I suppose. Anywho hows the bike coming along Scott?
Offline Scott S
« Reply #28 on: January 17, 2015, 06:26:54 AM »
 Bike is coming along slow. Shooting for a Spring debut.
 The fender brace wasn't smooth chrome. If you've ever removed the brace from the outer fender, you'll most likely encounter a rusty, rough surface. Look back at the first picture in this thread. I treated the rust, but it definitely wasn't smooth.
 The back side of the fender was also rough fiberglass. I took 80 grit to that and roughed up that area, too. The curves matched up pretty well and I used pressure and tape to hold it where I wanted it while the glue cured.
 The body shop gave me this tube and let me use their gun to apply it, but I think that stuff isn't exactly cheap. I can say that it feels very, very strong. I don't think it would come apart without destroying the fender. Time will tell, I guess.
'71 CB500 K0
'81 Yamaha XS650
Offline bjbuchanan
« Reply #29 on: January 17, 2015, 06:39:10 AM »
3m may have a product more specific for chrome. Prep and the right product is super important as you start mixing and matching and getting away from just mild steel
