Author Topic: Dome displacement  (Read 5092 times)
Dome displacement
« on: November 29, 2014, 05:14:01 AM »
How do piston manufacturers calculate net dome displacement? I understand nowadays they are designed using computer programs and the displacement is likely one available factor.
What about days gone by, before computers, how did they come up with the advertised compression ratio? Can someone here explain how to calculate the net displacement of a piston dome. I can (and have many times) physically measure by liquid displacement, but I'm curious if it's possible mathematically and whether, or not, a dummy like me can do it?
« Last Edit: November 29, 2014, 05:15:47 AM by bwaller »
Offline Old Scrambler
Re: Dome displacement
« Reply #1 on: November 29, 2014, 04:35:47 PM »
http://www.monolithic.org/calculators/dome-calculator
I don't try to subtract the dome area of the piston unless fill-capacity is needed to calculate flow efficiency - which is only maximized at WOT
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: November 29, 2014, 05:11:40 PM »
Can you use a ring stuck to the piston with grease, then a glass plate above that.. Filled up with liquid, like used to cc heads.
 After you do that, stick the ring on a flat surface, and repeat.
 Deduct piston measurement from full cylinder measurement.
« Reply #3 on: November 29, 2014, 05:44:49 PM »
With computers Brent. ;D You do need to know chamber volume etc. Sorry.....I'm a dick.  ::) ;D
« Last Edit: November 29, 2014, 05:46:43 PM by MRieck »
« Reply #4 on: November 29, 2014, 09:54:39 PM »
The liquid displacement method is a hell of a lot easier to do than the math, especially when you try to add in the valve reliefs and odd shaped crowns. ;)
Offline turboguzzi
« Reply #5 on: November 30, 2014, 11:13:58 AM »
hei brent
Been into engineering long enough to remember pre-cad.....
 In similar situations i dealt with when i was into aeronautic engineering, you'd simplify the shape into easy to calculate volumes like cones, cylinders, balls, etc. and make approximations.  Think about measuring a flat surface by breaking it into several big and small rectangles and you'll get the idea.
I built in the past the heads of a G50, CB500/4 and the GPZ in CAD, but even then it's all approximate unless you send the heads for 3D scanning. Compared to measuring with a pipette, i got within 5% of the actual volume.
« Reply #6 on: November 30, 2014, 01:13:08 PM »
Make molds with clay that can be filled with proper liquid? Just stamp clay with the piston making a print....
« Reply #7 on: November 30, 2014, 05:07:52 PM »
When I had these pistons made the manufacturer told me the net dome displacement was +2.39cc's. I sent them back for final touches (deepened reliefs 1mm, plus some tracing) and then was told the ndd was -0.495. I had trouble understanding this but they're the experts.
At that point four years ago I measured by liquid displacement twice and came up with nearly equal figures of 3.2cc's....WTF? Last week I tried again with the same results. All the clearances are very tight, piston/head/valves but there is some room top center for more dome height and I'd like to increase compression some. I need to know exactly what this original piston value is so I can redesign the dome.
One manufacturer tells me he can tell me what the dome of my original piston displaces, the other says no, just tell him what dome displacement I want & they'll build them accordingly. I guess I'll send one to the first guy and see what he finds.
« Reply #8 on: November 30, 2014, 06:20:30 PM »
Just for consideration..............tall piston domes may impede swirl and the flame..........Lots of aftermarket pistons for British and early Hondas were too tall and lost mid-range power.
Could you gain a few thou at the base-gasket?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #9 on: November 30, 2014, 07:05:20 PM »
Thanks Dennis. Because the chamber is so small (13.4cc) these can be flat top for the reason you mention.. . I can still add some height and keep it flat. It likes 28 degrees ignition advance so the result is obvious. They're at 0.030" piston/head now so I can't change gasket thickness either.
« Reply #10 on: December 01, 2014, 07:31:50 AM »
An old-school trick was to weld the top of the dome and grind (mill) to make each chamber equal. Depending on the plug location, you may want to mill that added material at a slant.........something like incorporating a wedge-head into a hemi ;D
I would be VERY careful with that MJR head.
Another consideration is your ignition.........I don't know what it is..........but if it can be programmed............maybe a few more degrees in the mid-range would help........and then retard for high-rpms..............just thinking out-loud here  ;) ;) ;) ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #11 on: December 01, 2014, 07:39:05 AM »
Integrals existed before computers  ;)
More info for instance here:
http://www.wyzant.com/resources/lessons/math/calculus/integration/finding_volume
« Reply #12 on: December 01, 2014, 08:17:55 AM »
Sounds faster to cc it than to do all the old math..
« Reply #13 on: December 01, 2014, 08:26:28 AM »
I think you're right Frank. Truth is I have and it didn't agree with what I was told.....therein lies my problem.
OK thanks guys, on to bigger & better things.
« Reply #14 on: December 01, 2014, 08:45:21 AM »
I don't doubt that and it is not like I would be able to do it now, but they sure drilled me on it in college  :)
« Reply #15 on: December 01, 2014, 08:54:58 AM »
The problem i see with the math , a few calculation, easy to make a mistake, and how do you measure a partial valve cutout with a radius in the corner.
 As usual..leaving nothing to doubt or chance...usually builds a good motor..
« Reply #16 on: December 01, 2014, 09:09:26 AM »
I'm sending a piston to Wiseco for an accurate measurement of the dome.
Offline Big Jay
    • CBRzone
« Reply #17 on: December 06, 2014, 09:48:41 PM »
Easy these days with a CMM maching
« Reply #18 on: December 07, 2014, 06:18:29 AM »
Thanks Big Jay, I hope so. I need an accurate number to start with.
Offline faux fiddy
  • bike in a box
« Reply #19 on: December 10, 2014, 12:24:40 PM »
This sounds like it would work, if you knew stack height of everything else.
I know people use a small ball of clay to find just the clearance under heads they are working on by putting it in and bolting things down and rolling the motor over once. If it was all conforming  shapes you could use area and thickness of the squeezed out clay to get an estimate.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Tintop
« Reply #20 on: December 16, 2014, 09:56:01 AM »
Here's a whole pile of race calculators, something for everyone ;) - http://www.wallaceracing.com/Calculators.htm
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #21 on: December 16, 2014, 06:22:44 PM »
Thanks TT :) :) :) :) :)
I need a better header ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
