Author Topic: '78 CB750K Cafe Build - Money Pit!  (Read 23115 times)
Offline callmejarob
Re: '78 CB750K Cafe Build - Questions!!
« Reply #100 on: March 19, 2015, 06:26:31 PM »
As much as I don't want to wait for it, I found them and ordered one.  Thanks!
Offline Restoration Fan
  • My wife will never call me
« Reply #101 on: March 19, 2015, 06:41:29 PM »
I had an extra one at one point that I had gotten from Bill Benton.  I was pretty sure I returned it to him when I found my second one.  I just went and confirmed that indeed I did return it to him.  Otherwise, it was going to be yours.  Sorry.
Offline callmejarob
« Reply #102 on: March 20, 2015, 03:54:30 PM »
DFW Honda had the dowels in stock so I went and picked up two today!  Everything has been triple checked for the crankcase and will be assembled tomorrow.  Engine should be finished soon!  I am waiting on a few pieces to get back from plating though..
Offline callmejarob
« Reply #103 on: March 26, 2015, 07:52:58 AM »
I got the cases together with no issues last weekend, transmission still shifts like butter!  Started installing the studs but some were having trouble going in so I'll clean the threads again, for the 4th time..
Most likely this bike will be going on a bit of a break soon, I've invested most of my money in my business this week and might have to wait 3-4 months to order the rest of the parts needed :(
« Reply #104 on: March 26, 2015, 08:19:33 AM »
Jarob,
We've all been there.  These bikes seem to take more money than anticipated when you're restoring or modifying them.  I know we doubled our original estimate of cost.  And there were many items we would have liked to purchase earlier but had to wait for cash flow reasons.
Glad to hear the cases are back together.  Now just have to get those studs in so you can get cylinders, rings, head etc all buttoned back up.
Offline callmejarob
Re: '78 CB750K Cafe Build - Slowing down.
« Reply #105 on: March 29, 2015, 06:25:35 PM »
Hey I've got a question.
I FORGOT TO REPLACE THE OIL SEALS!
So I have to old oil seals on the crank, etc. still but have these fresh new oil seals sitting in a bag on my work bench.
Is it worth tearing the cases back down to replace them?
Offline callmejarob
« Reply #106 on: March 30, 2015, 01:45:46 PM »
Mods vs Rockers this weekend, wish I could have joined!
The fiat all cleaned up at the "shop"
Honing could not have been easier
Waiting on a new base gasket, I might have ripped mine....
And my new custom alloy fender to replace that old giant.
Still debating if I want to crack open the cases again to replace the crank oil seal...
« Reply #107 on: March 30, 2015, 01:48:31 PM »
I haven't seen that honing attachment.
Offline SKTP
« Reply #108 on: March 30, 2015, 02:03:34 PM »
WOW! who did your head and how much?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline callmejarob
« Reply #109 on: March 30, 2015, 02:48:18 PM »
Really?!
It's a flex hone, you order just the right size for your cylinders so that you really dont have to worry about over honing.
http://www.mscdirect.com/browse/tn/Abrasives/Laps-Hones/Hones/Flexible-Hones?navid=12100209
Drill it up and down for about 20 seconds and done.
Offline callmejarob
« Reply #110 on: March 30, 2015, 02:50:19 PM »
The Vapor Blasting?  The head alone would only be about $50
Dan at Vapor Blasting Solutions : vaporblastsolutions@gmail.com
« Reply #111 on: March 30, 2015, 02:53:33 PM »
Really?!
No, I haven't done the machining/valves/porting myself on any of my bikes.
Offline callmejarob
« Reply #112 on: April 01, 2015, 07:52:15 PM »
Spend a good 2+ hours today splitting the cases again and replacing the oil seals, got it all bolted back up and will work on the cylinders this weekend.
Offline callmejarob
« Reply #113 on: April 06, 2015, 07:42:03 AM »
The guilty oil seals, glad I decided to replace them they are hard and worn.
Im practicing the old "use your fingernails and go slowly" method
Getting closer...
Piece of cake!
This valve spring compressor was surprisingly easy to use
And that was my Easter Sunday!
I lost the pin that holds the cam chain guide in place so I couldnt button her up just yet.  A new one is on the way!
Also put an offer on a house this weekend that has a NICE garage and shed, Ill find out today!
Re: '78 CB750K Cafe Build - Money Pit!
« Reply #114 on: April 06, 2015, 07:46:27 AM »
Awesome!  Nice job on the piston install.
And good luck on the house.  Makes all the difference in the world having a place where you can just go in the garage/shed/downstairs and work on the bike for a few minutes at a time.
« Reply #115 on: April 06, 2015, 08:45:52 AM »
Great job on the pistons and valves.  Pretty damn awesome.
Offline Trad
« Reply #116 on: April 06, 2015, 10:31:05 AM »
Killer job. Cracked through all that pretty quick.
The alloy finish on your engine will for sure dull out over time if left unclear coated. To some like me, it's not biggie though. haha. Take the others advice and clear your engine if you want the finish to stay as is.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline callmejarob
« Reply #117 on: April 08, 2015, 12:04:05 PM »
Yea I like that whole aged/patina look.  Plus I have an aircraft polish I will be using on it to keep it looking good.  I spoke with several vapor blasters and they all said its not needed
Offline callmejarob
« Reply #118 on: April 20, 2015, 02:48:42 PM »
I havent updated in a minute but I got a little bit more work done.  Unfortunately I'm waiting for some parts before I can continue so hopefully soon!
Got the frame detabbed and hooped
Got the engine mostly finished.
Also got a fresh set of FINSERTS!
Offline callmejarob
« Reply #119 on: April 24, 2015, 02:16:35 PM »
The engine is essentially finished!  Got the timing and valve clearance set and ready to go!  Now I just need to get my frame back from the shop!
Here is a cool little detail I'm in love with:
A sneak peak of some parts:
Two tools I just got in
AND LOOK WHAT JUNIOR AT RETRO MOTO SENT ME!  Cant WAIT for this thing to get done!
I should have the frame back mid next week to strip and paint.
Im picking up a '72 CL175 this weekend too.  I will be moving into downtown Dallas within the next two months so I need something to putt around town on while the 750 is under the knife.
Offline SKTP
« Reply #120 on: April 24, 2015, 03:10:34 PM »
Did they cost you an arm and a leg? If not, where did you score them from?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline callmejarob
« Reply #121 on: April 24, 2015, 03:14:08 PM »
Nope!  Member "FrankenFrankenstuff" on here makes them for a GREAT price!
Offline Trad
« Reply #122 on: April 24, 2015, 03:45:18 PM »
Nice work. Who's making the gas tank?
« Reply #123 on: April 24, 2015, 03:49:47 PM »
Retro Moto aka Junior Burrell is one of the most talented metal fabricators in the country.  Nice guy, too.
Offline callmejarob
« Reply #124 on: May 11, 2015, 12:54:09 PM »
Broke my dang ol clutch lifter plate!!!
Does anyone have an extra?!
