Author Topic: '78 CB750K Cafe Build - Money Pit!  (Read 25007 times)
Offline Restoration Fan
  • My wife will never call me
Re: '78 CB750K Cafe Build - Trials and tribulations
« Reply #75 on: March 15, 2015, 11:37:46 AM »
Those carbs and velocity stacks look sexy!  Really nice job on the carbs.
« Reply #76 on: March 15, 2015, 11:53:25 AM »
I  do love the look of velocity stacks, and I've run them on my 750, but make sure to cover them when not in use, and to avoid riding in dusty or wet (rain) environments.
Offline callmejarob
« Reply #77 on: March 18, 2015, 12:06:32 PM »
I will add foam inserts to the stacks as well to help with restricting the flow somewhat.
I received all of my bolts back from zinc plating today finally and it was worth the wait!  They look GREAT!!!
Now I can plastigage the crank bearing shells tonight and get it together!
Offline Wredas
« Reply #78 on: March 18, 2015, 02:16:59 PM »
You've done an amazing job on this bike. The parts look great, I can't wait to see it done.
Offline callmejarob
« Reply #79 on: March 18, 2015, 02:32:42 PM »
Thanks!
I'm trying to take my time and make this bike perfect in my eyes.  Compared to all the amazing bikes on this site I feel like I've got a long way to go so it is much appreciated to hear that!
Offline callmejarob
« Reply #80 on: March 19, 2015, 06:06:55 PM »
Alright, so I have this random little dowel pin that I have no clue where it goes, and then only one of the large pins so I am missing one large one it looks like.  Other than that, I believe I am ready to put the cases together.
Can anyone help me figure out the dowel pin situation?!
Here is one of the big ones I'm referring to:
Here is the empty spot on the other side where I need one it looks like:
And this is the smaller one that was with my crank case supplies and I have no idea where it goes:
Let get this figured out so I can move along, its getting very exciting!
Ordered my electronics tray and new kickstand today so that I can modify my frame all at once.  Once those come in I will de-tab and chop the frame, weld seat hoop, weld new kickstand, weld seat attachments, and attach new oil tank and electronics tray and get it all painted.
Offline danyo
Re: '78 CB750K Cafe Build - Questions!!
« Reply #81 on: March 19, 2015, 06:17:29 PM »
Small one are used in one of the side covers ( clutch, generator, shifter) and also in rocker towers and rocker cover. You dont need small ones between cases.
Offline callmejarob
« Reply #82 on: March 19, 2015, 06:21:50 PM »
Awesome I should have known that thank you!  Now do I NEED that large dowel/is there one there
« Reply #83 on: March 19, 2015, 06:25:35 PM »
Yes, you need both of the large dowels for when you put the case together.  It's not that oil is flowing through it or anything, but they're alignment guides that make sure the 2 cases go together aligned.
Offline callmejarob
« Reply #84 on: March 19, 2015, 06:26:31 PM »
As much as I don't want to wait for it, I found them and ordered one.  Thanks!
« Reply #85 on: March 19, 2015, 06:41:29 PM »
I had an extra one at one point that I had gotten from Bill Benton.  I was pretty sure I returned it to him when I found my second one.  I just went and confirmed that indeed I did return it to him.  Otherwise, it was going to be yours.  Sorry.
Offline callmejarob
« Reply #86 on: March 20, 2015, 03:54:30 PM »
DFW Honda had the dowels in stock so I went and picked up two today!  Everything has been triple checked for the crankcase and will be assembled tomorrow.  Engine should be finished soon!  I am waiting on a few pieces to get back from plating though..
Offline callmejarob
« Reply #87 on: March 26, 2015, 07:52:58 AM »
I got the cases together with no issues last weekend, transmission still shifts like butter!  Started installing the studs but some were having trouble going in so I'll clean the threads again, for the 4th time..
Most likely this bike will be going on a bit of a break soon, I've invested most of my money in my business this week and might have to wait 3-4 months to order the rest of the parts needed :(
« Reply #88 on: March 26, 2015, 08:19:33 AM »
Jarob,
We've all been there.  These bikes seem to take more money than anticipated when you're restoring or modifying them.  I know we doubled our original estimate of cost.  And there were many items we would have liked to purchase earlier but had to wait for cash flow reasons.
Glad to hear the cases are back together.  Now just have to get those studs in so you can get cylinders, rings, head etc all buttoned back up.
Offline callmejarob
Re: '78 CB750K Cafe Build - Slowing down.
« Reply #89 on: March 29, 2015, 06:25:35 PM »
Hey I've got a question.
I FORGOT TO REPLACE THE OIL SEALS!
So I have to old oil seals on the crank, etc. still but have these fresh new oil seals sitting in a bag on my work bench.
Is it worth tearing the cases back down to replace them?
Offline callmejarob
« Reply #90 on: March 30, 2015, 01:45:46 PM »
Mods vs Rockers this weekend, wish I could have joined!
The fiat all cleaned up at the "shop"
Honing could not have been easier
Waiting on a new base gasket, I might have ripped mine....
And my new custom alloy fender to replace that old giant.
Still debating if I want to crack open the cases again to replace the crank oil seal...
« Reply #91 on: March 30, 2015, 01:48:31 PM »
I haven't seen that honing attachment.
Offline SKTP
« Reply #92 on: March 30, 2015, 02:03:34 PM »
WOW! who did your head and how much?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline callmejarob
« Reply #93 on: March 30, 2015, 02:48:18 PM »
Really?!
It's a flex hone, you order just the right size for your cylinders so that you really dont have to worry about over honing.
http://www.mscdirect.com/browse/tn/Abrasives/Laps-Hones/Hones/Flexible-Hones?navid=12100209
Drill it up and down for about 20 seconds and done.
Offline callmejarob
« Reply #94 on: March 30, 2015, 02:50:19 PM »
The Vapor Blasting?  The head alone would only be about $50
Dan at Vapor Blasting Solutions : vaporblastsolutions@gmail.com
« Reply #95 on: March 30, 2015, 02:53:33 PM »
Really?!
No, I haven't done the machining/valves/porting myself on any of my bikes.
Offline callmejarob
« Reply #96 on: April 01, 2015, 07:52:15 PM »
Spend a good 2+ hours today splitting the cases again and replacing the oil seals, got it all bolted back up and will work on the cylinders this weekend.
Offline callmejarob
« Reply #97 on: April 06, 2015, 07:42:03 AM »
The guilty oil seals, glad I decided to replace them they are hard and worn.
Im practicing the old "use your fingernails and go slowly" method
Getting closer...
Piece of cake!
This valve spring compressor was surprisingly easy to use
And that was my Easter Sunday!
I lost the pin that holds the cam chain guide in place so I couldnt button her up just yet.  A new one is on the way!
Also put an offer on a house this weekend that has a NICE garage and shed, Ill find out today!
Re: '78 CB750K Cafe Build - Money Pit!
« Reply #98 on: April 06, 2015, 07:46:27 AM »
Awesome!  Nice job on the piston install.
And good luck on the house.  Makes all the difference in the world having a place where you can just go in the garage/shed/downstairs and work on the bike for a few minutes at a time.
« Reply #99 on: April 06, 2015, 08:45:52 AM »
Great job on the pistons and valves.  Pretty damn awesome.
