Author Topic: Hole in motor!  (Read 1331 times)
Offline Calumjs
Hole in motor!
« on: December 03, 2014, 04:31:43 PM »
Can anyone tell me what the hell is poking out of my motor??!!
Offline chewbacca5000
  • I polish covers!
Re: Hole in motor!
« Reply #1 on: December 03, 2014, 04:39:58 PM »
I don't see anything.  Point to the problem and post another pic.
Offline Vinhead1957
Re: Hole in motor!
« Reply #2 on: December 03, 2014, 04:43:57 PM »
Year and cc?
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
Re: Hole in motor!
« Reply #3 on: December 03, 2014, 04:55:10 PM »
that's the 12mm bolt on the end of one of your transmission shafts on a CB400F, pull the cover (drain oil first, it holds oil) to see what's going on....hopefully it's not bad....
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
Offline Calumjs
Re: Hole in motor!
« Reply #4 on: December 03, 2014, 04:55:30 PM »
You can't see the bolt smashing through the clutch cover?? Cb400
Offline Calumjs
Re: Hole in motor!
« Reply #5 on: December 03, 2014, 04:55:53 PM »
KiefRichards
Re: Hole in motor!
« Reply #6 on: December 03, 2014, 04:57:56 PM »
this?
Offline Calumjs
Re: Hole in motor!
« Reply #7 on: December 03, 2014, 04:58:19 PM »
Offline Calumjs
Re: Hole in motor!
« Reply #8 on: December 03, 2014, 04:59:19 PM »
this?
Yeah it was the bolt that bolts on the gear in the bottom right hand corner, what does that gear do?
Re: Hole in motor!
« Reply #9 on: December 03, 2014, 05:05:31 PM »
It is the drive gear for trans/primary...you should make sure there's no damage on the back of your clutch basket or on the bearing behind that gear. There are also probably now shavings throughout your motor so you'll want to clean the oil screen at a minimum.
'75 CB750 - Racer
'69 CB350 - Racer
Offline Calumjs
Re: Hole in motor!
« Reply #10 on: December 03, 2014, 05:09:35 PM »
It didn't happen whilst riding it happened when I was trying to start it. I dropped the oil and found no metal in the oil and when I took the engine cover off there was no shavings in there either,but I did find this little thing in there, any ideas as to what it is?
Offline Calumjs
Re: Hole in motor!
« Reply #11 on: December 03, 2014, 05:10:24 PM »
Offline oldhatt45
Re: Hole in motor!
« Reply #12 on: December 03, 2014, 05:27:10 PM »
Look at the picture in reply #6.
Toward the top of the picture just to the right of center you can see what looks like 2 more of them.
Maybe the piece is a third one?????
Charlie
Re: Hole in motor!
« Reply #13 on: December 03, 2014, 05:29:23 PM »
Looks like a piece broken off the shift stopper (Y shaped piece behind the clutch surrounding the shift drum). It's been a long time since I've worked on 400F's so I'm really fuzzy =\
'75 CB750 - Racer
'69 CB350 - Racer
Offline Calumjs
Re: Hole in motor!
« Reply #14 on: December 03, 2014, 05:48:07 PM »
Yeah looks like the stopper part number 176. Where the hell will I find one of those?
Offline Calumjs
Re: Hole in motor!
« Reply #15 on: December 03, 2014, 05:49:13 PM »
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Hole in motor!
« Reply #16 on: December 03, 2014, 06:39:48 PM »
« Last Edit: December 03, 2014, 06:41:24 PM by 05c50 »
Wear a helmet,the life you save may be your own.Ask me how I know.               CB650C,CB550F,GL1000,CB750A
Re: Hole in motor!
« Reply #17 on: December 03, 2014, 10:37:24 PM »
did the bolt just back out?
Offline Calumjs
Re: Hole in motor!
« Reply #18 on: December 03, 2014, 11:52:14 PM »
Certainly did, backed out and pushed through the cover.
    • http://forums.sohc4.net/index.php?PHPSESSID=d6ju11091s3h2ie5qu4bcsvd40&/topic,60973.0.html
Re: Hole in motor!
« Reply #19 on: December 04, 2014, 10:32:07 AM »
mine 400 f have rubbed.. some marks there..but not broke through.
.a kommon problem..lockteit after cleaning all oil of the threds...but renember to heat if it ever have to be removed later..it make the lockteit soft
got the parts broken tig veldet..then you are fine..and new oil filter and  vash engine inside..and you are ready for next seson
« Last Edit: December 04, 2014, 10:38:08 AM by strynboen »
Offline Kevin
Re: Hole in motor!
« Reply #20 on: December 04, 2014, 10:48:35 AM »
Exact same thing happened to me (after I rebuilt my engine).....Live and learn!
The really crappy part was that I had polished and clear coated that cover. I still have it hanging on the wall in my shop.
Bummer...:-(
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline Calumjs
Re: Hole in motor!
« Reply #21 on: December 04, 2014, 04:22:24 PM »
Thanks, I live in Australia so every day is riding season!
Re: Hole in motor!
« Reply #22 on: December 06, 2014, 10:05:33 PM »
 I see,  and once it contacts the inside of the cover it just grabs the cover and spins right through.
