Author Topic: Where do I start with power loss at high speed.  (Read 4464 times)
Offline nzdreamer55
« on: December 04, 2014, 08:11:25 PM »
Hello everyone,
I have a '78 CB750F and it has been sitting for a while.  It starts and runs, however when I am accelerating, it hesitates and feels like it is running out of gas maybe.  I have cleaned the petcock and the fuel strainer from the tank, put in new gas with fuel stabilizer.  I am concerned that the carbs maybe plugged with some varnish?  Any ideas of how I can decide if the carbs are the problem without pulling them?
Thanks
-S
Offline tlbranth
Re: Where do I start with power loss at high speed.
« Reply #1 on: December 04, 2014, 08:37:27 PM »
If it runs and idles then fuel is moving through all the right channels which makes it a candidate for cleaning I'd say. Most people on these bike forums seem to favor Sea Foam but I've had better luck with injector cleaner. Try a tankful of fuel with cleaner in it. See if it helps. Also, try using Chevron fuel for a while. I think their Techron additive works to clean the fuel system and backs of intake valves.
All this said, I reckon it's better to first run through the items that require no magic to fix: timing chain, valve clearance, point gap, timing. Then move on to the black art of carburetor massage. Good luck.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline nzdreamer55
« Reply #2 on: December 04, 2014, 08:58:35 PM »
Thanks for the reply.  What type of injector cleaner?
Offline fmctm1sw
« Reply #3 on: December 04, 2014, 08:58:50 PM »
Did those bikes have accelerator pumps?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #4 on: December 04, 2014, 09:25:44 PM »
Yes, if it has the stock PD carbs....
Offline nzdreamer55
« Reply #5 on: December 04, 2014, 09:50:42 PM »
Yes.  I have stock everything.
« Reply #6 on: December 04, 2014, 11:46:41 PM »
check the fuel cap vent.
Offline nzdreamer55
« Reply #7 on: December 05, 2014, 06:32:53 AM »
Good idea.  How do I check the cap vent?  Is it cleanable?
Offline 750cafe
« Reply #8 on: December 05, 2014, 07:35:50 AM »
The strongest fuel system cleaner that is available at NAPA and O'Reilly's is the Berryman Total Fuel System Cleaner in a 15oz. can for about $7.50 each.
Start by using a half can per full tank of fuel. Do not spill any on painted surfaces and DO NOT INHALE! It is VERY STRONG!!!
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline vames
« Reply #9 on: December 05, 2014, 08:13:07 AM »
There is no fuel additive that is equivalent to pulling the carbs and cleaning them. Don't cut corners. You said this bike has been sitting for a while -- I guarantee you that it can benefit from cleaning the carbs. Then do valve clearances, clean and set points, timing, ensure plug wires all have healthy connections, change the air filter, change oil and filter. Then synch the carbs. Your bike will thank you by running very well.
* oh yeah and checking the fuel system -- cap/vent/filters/etc
« Last Edit: December 05, 2014, 08:30:18 AM by vames »
« Reply #10 on: December 05, 2014, 08:52:12 AM »
This is your best advice. I have the same carbs. The accel pump holds such a small amount of gas, it varnishes quick. Once it plugs up no cleaner can get in there. A good carb cleaning along with the other tune up items will make you much happier with the bike.
« Reply #11 on: December 05, 2014, 08:58:30 AM »
Hello everyone,
Thanks
-S
Yes, you'll have an accel pump with your PD carbs, but once you're familiar with the design of the pump, it only pumps fuel with the first 1/4 throttle twist, once you're past that, holding a throttle position or slowly accelerating, it does NOT continue to pump.  It only engages from ZERO throttle twist position.  Its a one time shot.
During gear shifts, if your throttle position hits back at zero(revs still up, tho), it will engage again for that brief moment of accel.
Sounds like you just need a good cleaning of your carbs and jets, nzdreamer55.  main jet is twist out to get to the emulsion tube.  clean all its tiny holes. pilot jet is a press-fit jet.  just pull it out.  clean its holes, too.
separate the halves of your airbox first.  makes getting the airbox top half, and the carbs out, an easy task
« Reply #12 on: December 05, 2014, 07:01:27 PM »
try running it with the cap not latched,but not with a full tank,or when the trouble starts try un latching the cap and see if it clears up?
Offline ozpacman
« Reply #13 on: December 06, 2014, 12:03:38 AM »
Don't forget to have a look at your float levels while you have the carbs off.
I recently had a similar issue with my K7 where it wouldn't pull cleanly.  Pulled the carbs off and found that the float level on the number 4 carb was set a little low.  It now runs beautifully.
Russ
Offline MoMo
  • Ride like you're invisible
« Reply #14 on: December 06, 2014, 07:26:37 AM »
Check air filter for mice nest
Sent from my iPhone using rapper talk
Offline nzdreamer55
« Reply #15 on: December 07, 2014, 02:50:55 PM »
Thanks everyone.  The last post about mice is really funny because that happened to me when the bike was stored for a while.  Now it is all clean.  So built a little sync tool and got the cylinders as close as I could, however #2 (which cannot be adjusted) won't play well with the others.  I am not sure why.  I also wanted to know if the fuel routing is correct.  It seems a little hard on the hose angle.  Is this the correct petcock for this bike?  I have seen where the output points into the middle of the bike.
Thanks again for the help and ideas.
-S
Offline Bailgang
  • Scott
  • Indiana
« Reply #16 on: December 07, 2014, 03:20:40 PM »
You probably already know this but I'm saying it just to make sure you know but being the #2 carb can't be independently adjusted from the other 3 then you have to get the other 3 adjusted to whatever the #2 carb is reading. The #2 carb is the base carb so to speak so all the others have to be adjusted around it. I also built a DIY manometer like the one you have and can tell that although it works it can be a PITA, try to borrow a gauge type manometer from someone and try it instead. My kid bought a gauge type manometer for his bike and he let me try it on both my 78 cb750 and gl1100, I had the carbs on both bikes synced in a fraction of the time it would've taken me with my DIY manometer.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline nzdreamer55
« Reply #17 on: December 07, 2014, 03:38:51 PM »
Thanks.  I have a spring dial gauge carb sync tool (like in the manual) but it is difficult to read as the needles bounce around.  The home made is super smooth and moves very nicely.  I realize that the number 2 is the base carb and cannot be adjusted.  I cannot get the other carbs to match #2.  This is the best I can do.  I suspect that I will need to pull the carbs and go through them.
I have isolated the power issue to when I am at speed and holding the throttle.  Never when accelerating or idling.  I don't think it is a tank cap issue (tried riding with the cap off and still had the problem).
Any thoughts on the fuel line routing (was the OD of fuel line in the '70 smaller because the line I get now has an OD that is very tight putting on to the carbs) and the petcock.
Any links to new intake boots (replicas are ok) for a '77K (this is the engine and carbs that are on the bike) that won't melt?
Thanks
-S
« Reply #18 on: December 07, 2014, 03:44:42 PM »
Stock fuel line is 5mm, I use 3/16" and it's a tight fit, no clamps needed.
Fuel line routing does look odd, but I don't know the F's.  Why do you have the filter? That can cause issues.
Offline nzdreamer55
« Reply #19 on: December 07, 2014, 03:47:37 PM »
I like to know that I have fuel flowing.  I guess I could swap it out for a clear connector without a filter.  In the past it has never been an issue and I put on a new one before testing today.
Offline tlbranth
« Reply #20 on: December 07, 2014, 07:39:37 PM »
Yessir those filters can be troublesome. It seems logical that as long as the bowls are below the tank, fuel will flow unimpeded. I had 2 filters like yours and had trouble with stalling, loss of power etc. 'til I removed the filters. I think they get an air bubble in them or something and it slows down fuel flow.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #21 on: December 07, 2014, 07:53:34 PM »
On my 78K I use Tygon which allows for better routing since it is more flexable and does not require clamps. I routed mine so the gas runs downhill and the the filter is actually betwen1 & 2 carb.
To do a proper carb synch you need to do a valve adjustment. Timing also.
Offline nzdreamer55
« Reply #22 on: December 07, 2014, 08:04:23 PM »
On my 78K I use Tygon which allows for better routing since it is more flexable and does not require clamps. I routed mine so the gas runs downhill and the the filter is actually between 1 & 2 carb.
Cool.  So what type of Tygon tubing.  The name Tygon is a brand of tubing not a specific type.  What type of tygon tubing did you use?  It looks like tygon fuel line is yellow.  Are you saying you put yellow fuel line on your bike?
-S
« Last Edit: December 07, 2014, 08:11:03 PM by nzdreamer55 »
Offline Bailgang
  • Scott
  • Indiana
« Reply #23 on: December 08, 2014, 03:49:15 PM »
It sounds like your dial gauges are missing the damping valves that I'm pointing to in the pic, without them the needle will bounce all over. However that's not the point, if you're pleased with how your homebuilt manometer works then by all means keep using it. My DIY manometer is a PITA because if there is ANY difference in vacuum between the carbs then it's going to show it making it damn near impossible to get all 4 carbs on the same level. I think I used too small of a dia tubing on mine which is why it's so sensitive.
Scott
71 cb350 twin
77 cb750 F2
« Reply #24 on: December 08, 2014, 05:38:16 PM »
-S
I usually get it in places that repair small engines, like Lawn tractors and snow blowers. It comes in a few colors. I have yellow on there now and you can't see it. It comes out of the petcock into a filter with a 90 degree bend that sits between # 1 & 2 Carb. It goes down hill in a fairly straight line.
