Author Topic: Rebuilding controls, need photos  (Read 4166 times)
Offline dgilling
« on: December 04, 2014, 08:14:15 PM »
Does anyone have pictures of the left control on the inside?  I took some but they don't have enough detail.  I got the start/kill switch back together based off
Offline dgilling
Re: Rebuilding controls, need photos
« Reply #1 on: December 04, 2014, 08:15:48 PM »
Sorry I hit enter and it posted..... anyways, to continue.  I rebuild the start/kill based off Sohon's rebuild thread but I need the other side and I can't find anything on the left hand controls.  There's a lot of parts in there.
Offline fmctm1sw
« Reply #2 on: December 04, 2014, 08:57:19 PM »
I was going to say there's an excellent thread somewhere about those control but it's probabaly the one you're looking at...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline chewbacca5000
  • I polish covers!
« Reply #3 on: December 05, 2014, 05:28:16 AM »
If you going to mess with the left control be sure to lay it out on a towel as those little balls can get lost easily never to be found again.
Offline dgilling
Left Control Rebuild Tutorial
« Reply #4 on: December 05, 2014, 10:47:01 AM »
Well, I think I got.  It took me a long time, but i'm pretty sure this is correct.  I was missing a spring and that was throwing me off so I made a new one out of a spring in a pen.  Those are perfect size replacements.
Since there wasn't a write up for the left controls I took the time to do this, hopefully people find it helpful.  It will not be as detailed as Sohon's but hopefully it will give you the visual that you need.
This is the Rebuild for a 1977 left control with hi/low beam, horn, and L/R signal switch:
My controls started out very faded so I painted them when I was painting the rest of the bike.  I used the same SEM Hot Rod Black.
Little parts everywhere so be sure to work in a place that you won't lose them.  I worked over a box with foam in the bottom.
First I put the Hi/Low switch back together since you can do this outside the control enclosure.  This gives you better room to work on it.  It took me about 4 tries but I think I got the right orientation since all the other ways seemed like something just didn't fit quite right.
Then Pin goes through the board side into the switch lever.
using the bracket that has an L shape to it and two holes on one side, this will go on the other side of the switch and secure the switch to the control enclosure.  Notice the ball bearing slides between hole one or hole two.  On the switch it goes Ball - Spring - Copper plate.  The copper plate is on the opposite side of this photo and contacts the paths on the PC board of the other side as you move from Hi to Low beam.
Next I assembled the slider switch for the L/R signals.  I didn't take much apart on this in the cleaning sequence, and it's pretty easy to get this piece back together like this.  I did however lose that spring that goes behind the ball bearing.  I pulled a spring out of a regular pen and it fit great with some trimming.  It actually added a lot of tension to the switch and there's a much better feel to the switch now.  Getting the ball to stay in was probably the most tricky part of the assembly.
Put the ball in the hole and push the spring down.  Then push the ball against the back wall of the enclosure to hold the ball in place.  Slide the control down until the ball falls into the V grove and push the rest of the assembly to the bottom.  It will take a few tries but over all not really that bad.  It helps to hold the control enclosure up in the air above the assembly to get started.
Secure the slider switch with it's bracket.  you can also install the piece of the switch that rotates it back and forth and give it some test runs.  There was two washers I had from the disassembly.  I assumed they went here, because there was a gap without them.  I'm not hundred percent sure on their orientation but the switch operates as expected so I left it and moved on.
Add the bracket to hold the cable back.
Back to the bottom part of the enclosure, install the horn switch.  There is a cone spring that goes in between the button and the plate.  It's pretty easy to figure out, but I don't really understand how the horn actually works.  The button doesn't seem to connect anything to complete a circuit, it just touches the pad.  When bolting down the horn switch this one will have the longer different screw from all the other brackets.
For the Hi/Low switch you put the bracket you see here on top of the L shape bracket from a few pictures up.  This secures the switch to the enclosure.
After that there is one more cable secure bracket that is a larger plate, shown on the second photo.  I secured it in the only orientation that it would fit on the last available hole, on the same side as the hi/low switch.  Sorry I forgot to take a picture but it's pretty intuitive how it goes.
I hope this is helpful, as this forum is so helpful to me.
« Reply #5 on: December 05, 2014, 11:01:50 AM »
I did the same with my controls.  Cleaning the L/R switch made a huge difference.
Nice photos...
  • I polish covers!
« Reply #6 on: December 05, 2014, 01:23:04 PM »
Thanks for the tip on the pen spring you should post in tips and tricks so it is not lost in the archives.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #7 on: December 05, 2014, 03:48:08 PM »
Excellent walk-through, thanks for taking the time :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #8 on: December 07, 2014, 11:19:39 AM »
Look really good. Only red left to fill in with.
I replaced all wires in my old controls back in the days when I changed to higher handle bar. Probably one by one. Today easier to take photos first.
I did not trust the crappy electrical connections for headlight and ignition plus the after market ignition key switch.  Several amps thru those...?
NO... I installed some relays ( 2 for headlight + 1 for ignition + 1 for horn) so the controls are just handling very low current.  Despite no problems back in the days.
Offline dgilling
« Reply #9 on: December 07, 2014, 06:58:38 PM »
I did notice some melting of the plastic Hi/Low switch.  Something to regulate current probably isn't a bad idea.
Offline RandyBMC
« Reply #10 on: February 06, 2016, 05:51:38 AM »
What grease do you use in the controls?  Dielectric grease?  Brake parts grease?  The stuff that was there from forty years ago looks more like crust than grease, so it isn't easily recognizable...
Thanks for the write up!
Offline disco
« Reply #11 on: February 06, 2016, 03:23:33 PM »
Nice write up! That will be very useful to others who have to do the same.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline Flyin900
« Reply #12 on: February 06, 2016, 09:00:27 PM »
Nice write up on the switches. The horn button completes a path to ground when you press the button contact against the green wired positive contact on the back of the switch.
Your L+R turn signal lever is upside down and should be the other way around with the smooth part facing up. Been there and done that too, it is easy to do when the switch is upside down when you are working on it.
The relays are a very good insurance policy mostly on the headlight circuit to reduce the current draw through these old contacts to a milivolt draw instead of amps.
« Last Edit: February 06, 2016, 09:04:08 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
