Author Topic: So THAT'S why Honda put a front fender there...  (Read 2817 times)
Offline Bob Wessner
  • "Carbs Suck!"
Re: So THAT'S why Honda put a front fender there...
« Reply #25 on: December 07, 2014, 08:38:16 AM »
How do you make that "rule" do that.  You computer experts are slick   ;D
When you hit 'reply " to a thread look above the text entry box an you will see any number options including text modifiers. Second row shows a moving "M" which will output two tags. Put the text you want to scroll horizontally between the two tags.
« Reply #26 on: December 07, 2014, 09:19:13 AM »
Thankyou
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #27 on: December 07, 2014, 10:03:42 AM »
You're welcome ;).
« Reply #28 on: December 07, 2014, 12:16:48 PM »
I start laughing just thinking about all that
+1. I miss Fenders....
« Reply #29 on: December 07, 2014, 03:25:12 PM »
Five dollars says he still peeks in as a guest.  Heck he may be a newbie again.
« Last Edit: December 07, 2014, 03:27:20 PM by ekpent »
« Reply #30 on: December 07, 2014, 03:38:41 PM »
Yeah, there was a newbie that I suspected could have been him. He was such an easy target...
« Reply #31 on: December 07, 2014, 09:24:07 PM »
 ;D ;D ;D ;D ;D 8)
Offline WhyNot2
  • I'm finally an
« Reply #32 on: December 08, 2014, 03:35:06 AM »
~~~kewl~~~
Glad I had my fender on when I got caught in a big rain storm.
The 750 rode like a dream in all that water, surprised the crap out of me, how well it handled.
Offline lrutt
« Reply #33 on: December 08, 2014, 05:32:42 AM »
so what was the problem with the running????? Inquiring minds want to know. I'm just guessing water on the plug wire but would be interested to see if the Dyna really #$%* the bed.
Offline tfrasca
    • CB550 Project
« Reply #34 on: December 08, 2014, 11:39:47 AM »
Problem solved!
After drying everything out and making sure I had spark at all four cylinders, the bike would still cut out after a few minutes of riding. First cylinder 2 would stop firing, and the bike would run on 3 cylinders, but relatively smoothly. Then after 30 seconds or so, it would start having a fit and sputtering and wanting to die. It was bad.
I pulled the #2 plug cap to measure its resistance. It is only a couple months old, but I remembered that I didn't put the rubber seal on the wire side when I installed that cap. The wire is very short, and the insulation wouldn't allow the seal to slip on- if that makes any sense. Anyway, that cap measured ~11k ohms!
I replaced the cap with an old 5k that is still in the 5k ballpark, trimmed the insulation, and installed the rubber seal. So far, so good. I think the missing seal let water into the cap/wire connection and somehow shorted/burnt the cap. I can only assume that the bad cap was causing the intermittent firing issues.
As of now, the bike runs like it used to- pretty great. But I'm going to take all of your advice and install the fender as soon as it shows up, and I'll probably seal the ignition cover just to be safe.
Thanks guys!
TF
