Author Topic: chain breaker tool  (Read 1209 times)
DH
chain breaker tool
« on: December 05, 2014, 08:12:04 PM »
Looking for advice on chain breaker tool, the kind that's not overly priced, and of good quality. What are you folks using? Seemed like there was an unlimited number of them on line. I'd like to have the ability to do a drive chain and/or cam chain. It won't get much use. Any suggestions?
Offline dhall57
Re: chain breaker tool
« Reply #1 on: December 06, 2014, 06:06:49 AM »
I got one of these at Harbor Freight several years ago DH and works great.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline chewbacca5000
  • I polish covers!
« Reply #2 on: December 06, 2014, 06:34:53 AM »
Is that a riveting tool?
DH
« Reply #3 on: December 06, 2014, 06:38:31 AM »
Thank you gentlemen. Dhall, I've been looking at the one from HF since its readily available. Is the pin small enough to do a cam chain do you think?
Calj, I looked at the Emgo one online, and watched their tutorial on youtube.
The guy demonstrating it made it look so ez. Then I read other reports of failures like your describing. A shame, cause it looked like it was of halfway decent quality.
The quality and how well it works is the critical factor as to weather I use it for cam chain replacement. Motion Pro makes several versions, incrementally priced, with replacement pins of different sizes available. Does anyone know if the pins will work with all the different versions of the tool? A basic tool with only the sized pins I need would be nice,, but unsure if that's possible?
Offline dhall57
« Reply #4 on: December 06, 2014, 01:18:38 PM »
Can't answer the question about the cam chain DH. But it worked fine taking links out of #530 chains on my 750KO and K6.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline gerhed
« Reply #5 on: December 06, 2014, 03:34:58 PM »
I generally use a hack saw--takes forever but it can be done!
          83 XL600R in CB360 Frame
Offline sniper1
  • SNIPER1
« Reply #6 on: December 06, 2014, 04:20:08 PM »
Just used the motorcycle chain breaker and rivet tool, ordered it from amazon last week on my '01 VFR. $44. It worked great. Follow instructions and you will have no problem. Check, check and then check again when pressing plates and rivets.
Offline Vinhead1957
« Reply #7 on: December 06, 2014, 07:08:06 PM »
I normally grind the rivet head off before I use the tool and had little problems
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #8 on: December 06, 2014, 10:35:16 PM »
Yeah you can dremel grind the head off till it's flush then use the cheapo HF tool and the pin pops easily.   Don't forget to use safety wire around the master link clip on your new chain, and be sure the "u" end of the clip is headed toward the direction of the chain. So the open end of the clip trails behind
Offline youn6372
« Reply #9 on: December 09, 2014, 02:50:56 AM »
1973 CB750K
1982 CB900F
1983 VFR750
1983 CB1100F
1988 CBR1000F
DH
« Reply #10 on: December 09, 2014, 05:58:56 AM »
http://www.motionpro.com/motorcycle/partno/08-0058/
Can't go wrong here.
That's a nice set. I may have to go that route. Any idea if the different pins that it comes with (available separately as well)will fit any of their other less expensive basic tools? A basic tool with 2 specialty size pins is all I need. Not sure if it'd be cheaper, or even possible(?)
Offline youn6372
« Reply #11 on: December 09, 2014, 06:37:46 AM »
All I can say is that this has replaced all my other chain breaking and riveting tools and it saves a ton of time.  It does take a bit of time to get used to.  I used an old chain, practiced a bit and within 15 minutes it made sense...and I'm an idiot just ask the wife.   ::)
-Michael
1973 CB750K
1982 CB900F
1983 VFR750
1983 CB1100F
1988 CBR1000F
Online PeWe
« Reply #12 on: December 09, 2014, 11:16:13 AM »
It's easier if you grind the rivets flat before pressing them out of the chain with the breaker tool that will survive.
Offline P.abrera
« Reply #13 on: December 09, 2014, 06:10:01 PM »
Just used a cheap chinese chain tool ($5.50) works fine as long as you grind the rivets flat, as others have said, before pushing the pins out.
Offline xntrik
« Reply #14 on: December 09, 2014, 07:19:40 PM »
+2 for harbor freight breaker. Has served me well for years.
