Author Topic: Battery Earth Cable?  (Read 1698 times)
schmidbc
« on: May 24, 2005, 08:01:21 PM »
Hi guys, any idea where/ how to connect the battery earth cable and where to ground(?) it?  This is a cable approx 37cm in length with a connector on one end bent at a 90 degree angle, and another larger connector on the opposite end that has no bend from where it contacts the cable.
Any help is appreciated!
Cheers, -Brian.
Offline Warlock
Re: Battery Earth Cable?
« Reply #1 on: May 24, 2005, 09:45:55 PM »
Greets,
The cable runs from the negative battery post (90 degree end) to the rear upper engine hanger through bolt (round terminal end). The hanger bolt is passed through the terminal eye when installed...
Ride On...
« Reply #2 on: May 25, 2005, 08:35:13 AM »
Make sure there is no paint on the engine hanger where the cable is .
schmidbc
« Reply #3 on: May 26, 2005, 04:48:23 PM »
Thank You!
